Hello Mark, ask, do you do this with FM stations, like with AM stations?
If so, you may have a power problem with the radio stage, if it is only FM, check the antenna connection or you may have a problem in the Multiplex decoder circuit
If you can not solve it, I suggest you go to a specialized technical service
Greetings Franco Dosil
Hola Mark, pregunta, te hace esto con las estaciones de FM, como con las de AM?
Si es asi puedes tener un problema de alimentaci?n dela etapa de radio, si solamente es en FM , verifica la conexi?n de la antena o podr?as tener un problema en el circuito decodificador Multiplex
Sino logras resolver, te sugiero ir a un servicio t?cnico especializado
Saludos Franco Dosil
https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Kenwood-KR-820-Service-Manual.pdf
SOURCE: Radio stations
Set the station you want to wake up to in the "AL" preset memory. You can download the manual from the link below: http://157.254.235.130/public/rp3722.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: can't set the tuner radio stations
After finding the station press the memory button and then the station preset you want to save it to.
SOURCE: Set Radio Station Presets
Try just holding the button of choice down. In my Audi, when I had a factory head unit, to set for example, preset 2, I'd just tune to the station I wanted to program, and then hold down the number 2 preset button until the display stopped blinking. It was then preset.
SOURCE: i dont know how to set the radio stations... please help..
press the number for 3 second
example, if you want a 104.7 in number 6, press # 6 for 3 second.
