Question about Pentax Optio E10 Digital Camera
Pentax E10 6.0
Hi, I cannot get my computer to recognize my camera. I just bought a new usb cable but still no luck? Any suggestions would be great!!
  • 556 Answers
This depends on the operating systemPentax E10 6.0 - 1.gif. Only Win98 and Win98SE need software
Review quick start guide for how to download2.gif pages 10 and 11 seem to be of interest.
Quick Start Guide
http://www.pentaximaging.com/files/manual/Optio%20E10_QuickGuide_01.pdf
Manual
http://www.pentaximaging.com/files/manual/Optio%20E10_web.pdf
Posted on Dec 18, 2007
  • david Dec 18, 2007
    In order to read these manuals you may need to download and install adobe reader from
    http://www.adobe.com
How do I connect my K7 to a 1394 socket
Your Pentax K7 lacks firewire (1394) connectivity, so a connection to a fireware jack will not be possible without purchasing an inexpensive Firewire to USB adapter . From the manual:
Available Ports:
  • USB 2.0 hi-speed, AV out, HDMI out, DC in, cable switch, 3.5mm stereo microphone.
  • Video out: HD (1080i30, 720p30, 480p30), NTSC, PAL
  • Printer interfaces: n/a
The I/O (input /output) panel on a Pentax K7 camera.
You can connect a USB cable from the "PC/AV" on the camera to your computer's USB port with an appropriate cable to transfer image files for editing, etc. Additionally, you can send video directly to a TV with an appropriate cable via the camera's HDMI jack.
I hope this helps!
Oct 04, 2013 | Pentax K7 Digital Camera
Bad USB conection?
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Feb 11, 2009 | Pentax K100D Digital Camera
Black screen
Was the camera turned off, it must be turned on and set to USB to PC in settings menu.
Jun 20, 2017 | Pentax Optio S5i Digital Camera
Power surge
Connect the camera whilst it is switched off....then when you power on...it will ask if you want to connect via PC or bridge....if that still throws up power surge...you need to use a different cable as the power ballast on the cable is faulty.It is much easier to just use a card reader....cheap off eBay.
Nov 20, 2017 | Pentax Optio S40 Digital Camera
USB connection problem?
The Best solution is to get an SD card reader. Then you take the SD memory card out of the camer, put the Sd card into the reader and plug directy into a USB port.  They are very cheap to buy and quite handy.
Sep 05, 2008 | Pentax Optio M20 Digital Camera
Fine pix s6500 fd camera
first thing i would do would be to make sure you plug the cable first into the usb port with the camera off then turn on the camera, see if it is recognized by the computer. If not the next step is to check your usb driver to make sure it is working. Try some other usb device. If it is recognized then i would make sure you have seated the memory card properly in the camera as well as the cable. I know that sounds dumb but that little usb cable to the camera has to be well seated. You may have to update your driver for the usb port.
May 15, 2008 | Fuji FinePix S6500 Digital Camera
New computer does not recognize pentax 33l
Optio 33L and Vista
Plug camera into USB port using the cable supplied, and switch the camera on. Computer will display the "found new hardware" sign, and ask you to insert the disk that came with the 33L into the disk drive. That done, the drivers will be installed in the usual manner. AT LEAST, THAT'S HOW I DID IT - AND IT WORKS!
de VK5QV
Feb 18, 2008 | Pentax Optio 33L Digital Camera
Pentax problems...
load any software first before installing hardware
Aug 09, 2006 | Pentax Optio 60 Digital Camera
USB cable
My Optio uses a standard mini USB connector - you can buy them for a tenth of the price for example, here in Aussie I bought one for $2 at a local computer mart
Aug 30, 2005 | Pentax Optio S45 Digital Camera
Broken connector cable for Pentax Optio 450
Yes. The cables are sold too. I got a deal by buying a dock from compgeeks.com and it was cheaper than just the cable. So, go shopping.
Aug 30, 2005 | Pentax Optio 450 Digital Camera
Pentax Optio E10 Digital Camera Logo
113 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
