This problem should be removed because:
Problem with Lexmark X2500 All-In-One Printer
Can the Lexmark No 14 and No 15 cartridges be refilled and reset? Is it just the A version that can be reused?
Solutions (8)
Best Solution
Yes Yes Yes it worked for me too. I have a Lexmark x2670 with #14 (black ink cartridge) the one that came with the printer and I put tape on the bottom 4 points of the cartridge and went through the install cartridge steps that automatically came up including scanning what was printed and it is printing now. When printing you will see a question mark on the black printing status bar but who cares anyway. Praise the Lord!
It works, just used my #14 lexmark after refill. I put tape on the 4 bottom points of each sides. You will see 1 alone at the bottom and 3 in a group in the middle, tape the 4 and do the same on the other side. Put it back in the printer and it works... It will dispay a '?' on the ink cartridge level and status when you print.
I tried this fix, worked like a charm.. I counted 4 dots up on each and covered them with clear packing tape. I guess any thin tape would work. I wrapped around the edge so it wouldn't get lost in the machine .. And yes the level say "?".. but who cares
thank you very much this worked. i gave been having problems with my lexmark x2670 working with 14a cartidge. i did exactly as you said and works like a charm thanks a bunch
It's a totally bizarre solution, but it works. But please, Lexmark? Fix it properly?
Our problem is,we bought new cartridges which is number 14 and 15. Ever sins that happened we have been stragging to print. It flashes C5E. PLEASE HELP!!!!
dssadsa
where is 4 bottom points do you mean?
can you explain it with some images?
If you tape over the Four vertical contacts of the nr 14, (on the right of catirage, so it makes contact with the left 4 vertical contacts on the printer) it will fool the printer, however i have done this and it does fool the printer, Still gives me a error saying that it needs replacingand won't finnish print job, will try and restart both printer and computer.
plsss show me the trick with some pictures
I am from greece and i don't understant a few things such as what tape ( i use scotch tape) and where we have to put the tape. can you please explain what to you mean the Four vertical contacs of the number 14 (it has no only four but 27... wich four of them??? pls help me)
That tape trick doesn't work, it only tells the printer that, there is an error with the black cartridge, then the printer wil use the colour cartrige to make a black colour, by mixing colours. I bet if u remove the colour cartridge, it won't print wit the black cartridge.
does not work lexmark x 2650
does not work lexmark x 2650. is there any way to reset old refilled cartridges no.14 and no.15
refilled my lexmark cartridges but still dont work
I have just refilled my lexmark cartridges 14 & 15 but printer still says you need to refill.
I have an ink refill kit and have used it with a
I have an ink refill kit and have used it with a different printer, however now that I have the Lexmark x2600, I need to know if I can...
I have an ink refill kit and have used it with a different printer however now that I have the Lexmark x2600 I need to know if I can refill...
Add Your Solution
Getting an old HP Deskjet 932c to actualy print...
I'm trying to get get an old HP Deskjet 932c to actualy print something in Win7 Ultimate 64 bit. I'm not...
can't send or receive faxes.
can't send or receive faxes. The status of the faxes are "No dial tone". my phone line is connected to my...
who to reset cheps lexmark
who to reset cheps lexmark cartage #36 and #37
how do i connect my
how do i connect my wireless hp photosmart printer to my toshiba c660 laptop as this model isnt listed when i try to...
Fix-O-Meter
3,363
3,363 people viewed this problem
- 10 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Lexmark Printer Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
