Question about FUJIFILM Cameras
Fujifilm finepix F31fd. Some pictures have a ripple pattern of part of a circle imposed on them. Others are ok. Fault is seen when the pics are viewed in the camera as well as when uploaded.
SOURCE:
SOURCE: my finepix camera will not upload pictures
Mine doesnt have this problem - sorry it sounds like it is a malfunction.
If u dont wanna lose ur pics u can use ur cardreader, if you have one. But get the camera replaced.
sorry
Posted on Dec 30, 2008
  • 3 Answers
SOURCE: I got a pink Fujifilm Finepix Z20fd and pictures won't download
You don't have to use the software that came with the Fujifilm. I have the same camera. If you're on a laptop that has a slot for SD cards, (if you have an SD card) you can just put your card straight into your computer and load the pictures that way. Also, if you have an SD card reader, you can use that. And if you're on a desktop without either of those options; once you plug your camera into your computer, go to your start menu and click 'My Computer,' then your camera should come up as a removable disk device in the folder. From there, you can drag and drop the pictures onto your desktop or your My Pictures folder.
Posted on Jan 08, 2009
SOURCE: Lost software disk for the Fujifilm finepix s700, can't upload?
have lost the software to upload my pictures from my s700 fuji camera how can you help me
Posted on Mar 10, 2009
Steve5
  • 423 Answers
SOURCE: Have a fujifilm finepix Z20. What do the signs on
You can download the camera's manual here; http://www.fujifilm.ca/x617.xml?XID=x15936
Those dials/buttons set the various camera functions, such; zoom, flash, image quality, playback etc. The manual will give you all the information you'll need to set and use your Z20.
Posted on May 30, 2009
  • 4 Answers
SOURCE: My FinePix S1800 Fujifilm Digital SLR camera says Frame No. Full''
Go to set up then Frame and change to RENEW. It is probably on continuous. My camera did the same thing and this solved it.
Apparently even thought the card is empty if it is on continuous it will start the picture numbering where you left off last time.
Posted on Oct 23, 2010
My Fujifilm FinePix A800 is not displaying any image
This camera needs to be sent away forrepairs. Just like a motor vehicle, some repairs to your camera require atechnical specialist to fix your problem.
Apr 18, 2012 | Fuji FinePix A800 Digital Camera
What is wrong with my camera?
The display being black can be due to failure of the LCD or the CCD which is the optical sensor of the camera. So to confirm check the older picture to be seen on the display. Confirm this by checking the card on your PC. If the images/picture is seen to be of good quality, then the LCD can be faulty, fault on the linking cable or the control board.
However if the older images are seen well then the LCD is working correctly and the fault can be failure of the CCD- charge coupled device in the camera. If you have accidently exposed the camera directly to high intensity light / sunlight, then it is possible that it is damaged. Remove the battery and keep the camera aside to reset and try as a last resort. Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Nov 21, 2011 | FUJIFILM FinePix AV100 Digital Camera
Print FinePix F31fd INSTRUCTIONS
You can download and print the instruction manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Aug 04, 2010 | Fuji Finepix F31FD Digital Camera
F31fd webcam on windows 7
http://www.fujifilm.com/support/digital_cameras/software/finepix_viewer/ver55win/download.html
Oct 03, 2017 | Fuji Finepix F31FD Digital Camera
Fujifilm finepix f20le. circular grainy pic loss of sound
First go to the SETUP menu and make sure that the PLAYBACK VOLUME setting is set to a value greater than 0. Try increasing the shutter speed of any photos as CCD's will notoriously produce grainy images on slow shutter speeds. Grainy videos will indicate poor light, camera shake during filming or moving too quickly so the autofocus cannot function correctly, or using too low a resolution and will be especially noticeable at 640 x 480 when viewed on a large high resolution screen. If all the above make no difference then you may need to get the camera serviced.
Oct 08, 2009 | Fuji FinePix F20 Digital Camera
Pictures Readable on Camera, but NOT on computer
I found the solution to the problem. Connect the camera with the cord supplied. Do not open Finepix. Open Photoshop if you have it and go to file>import>via f31 or f30 and choose the pictures you want to import. Done !!!!!
Jun 09, 2008 | Fuji FinePix F30 Digital Camera
Card not initialized
Kyle850. I have a fujifilm finepix camera myself, and just recently had the same problem. The camera worked fine until one day I turned it on to take a picture and there was the "card not initialized" message. To fix the problem, just turn on your camera, push the menu button and use the right/left arrow buttons near the zoom button in the top left corner of the camera. Push the right arrow button until you come to the "option" window in the camera's view finder and use the "up" function of the zoom to highlight the "set-up" window. Press "ok", and use the right arrow button scoll over to the "2" tab and press the ok button again. Then use the "up/down" function of the zoom button to scroll down to the "format" tab. Press ok button again and use the "left" button near the zoom in and out button to highlight the "ok" option in the format window. By pressing the ok button here, it will reformat and reinitialize your picture card. If you do have pics already on your pic card, you may want to take your pic card to a photo center and see about recovering these pics before you go through the reformat process because there is a good chance that when you reformat your pic disk any pics on it will be gone. Good luck. SG
Feb 26, 2008 | Fuji FinePix 30i Digital Camera
Fujifilm finepix a 201
Ok your computer should have the software needed to view the pictures already installed, so maybe you are having trouble actually getting them out of the camera and into the computer?
You may need to download the file for your operating system from here.
http://www.fujifilm.com/products/digital/download/01/index.html#windows
After installing that you should just be able to plug the camera into the computer and let it copy the photos for you. On the PC the software is called "Scanner and Camera Wizard" (on windows XP) which can be found under All Programs, then Accessories, and on Mac I photo will do tthis for you.
Good luck
Nov 15, 2007 | Fuji FinePix A201 Digital Camera
Cameras Logo
Top FUJIFILM Cameras Experts
Falling star
Marvin
Marvin
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
