Question about Apple Cell Phones
Cleaning Apple lightning cable
There are small black ( oxidation) marks on the gold copper part on my Apple charging cable
Use alcohol on a cotton swab to clean it, if this diet work the use WD40. Spray the the metal parts of the plug give it afew minutes like 10, then rubb it gently with cotton rugg, it should dissolve all the oxides and loosen the dirt completely.
Posted on Mar 24, 2019
Testimonial: "I’ve trued that numerous times and it does not work. That was my initial method."
  • Charles Feinberg
    Charles Feinberg Mar 26, 2019
    I’ve been spraying on WD40 but not leaving it on for the time you suggested. I did try it again following your directions and it worked PERFECTLY. Thanks!
  • Apple Master
  • 26,436 Answers
Clean it with rubbing alcohol or vodka. They are gold flashed, so they shouldn't corrode. The black will be dirt.
Testimonial: "Wrong. It’s oxidation. I’m sure of that. I tried your method. Many people are having the same problem with 3rd party lightning cables as well as certified Apple cables."
  • 1 more comment
  • Andrew Taylor
    Andrew Taylor Mar 24, 2019
    Okay, you never said they were counterfeit. Genuine Apple cable are gold plated. Use chrome cleaner, like Flitz or Solvol Autosol.
  • Charles Feinberg
    Charles Feinberg Mar 24, 2019
    The oxidation is on an Anker as well as on an Apple lightning cable. The only thing that does anything is putting copper cleaner on the end of my Dremel tool with a felt bit. Some but not all of the black material comes off.
  • Andrew Taylor
    I have these but in 6 feet length. For the cost, I would just buy new.
    https://www.amazon.ca/Certified-Braided-...
SOURCE:
Why is my iphone not charging?
This means it's not getting a charge. I've just experienced this problem myself. I followed instructions online regarding cleaning lint from the charging port of the phone. Still no charge. I bought a charging cable that came with a car charger made by Belkin, this worked in the car, also allowed me to charge the phone from the pc, but wouldn't charge from the original plug. So I purchased an original Apple branded lightning cable today and it works. At last. So it turns out that my cable was faulty and another branded cable would not work with the Apple plug. So you need to try a known working Apple cable and plug and failing that clean out the port on the phone as lint is a common problem.
Jan 02, 2015 | Apple iPhone 5S
My iphone is pluged up and it is supposed to have a lightning bolt beside the battery life and it doesn't . It is almost dead and this phone is brand new. What do I do?
When charging the lightening bolt should be shown in the middle of the battery symbol! Are you using an original Apple charging cable and is it a USB mains or computer charger?
Dec 26, 2014 | Cell Phones
I phone 5s won't charge 6mts old
Check lightning cable with another phone and your phone with another lightning cable to figure out whichone is faulty!
Aug 24, 2014 | Apple iPhone 5S
My iPhone is flashing battery and beeping
I assume it is on the black screen with the empty battery. If it doesnt come up with the little lightning bolt to show it is charging then it is likely the cable or charger are dead. try laptop USB charging port instead. Note I have had faulty cables that would lock up each USB port tried until I rebooted. try a friends charging rig that you know works. Another thing to check, is pocket fluff in the charge port which may prevent you inserting charging cabel correctly.
Aug 04, 2014 | Apple Iphone 4s I Phone 4 S Factory...
LN46A530P1FXZA has a problem with the screen in that the while the right side of the screen is normal the left side of the screen stays in a darkened condition. This problem use to correct it's se
AmanStino Lightning Cable [Apple MFi Certified] 1M Nylon Braided Charging Cord - Black
  • [Apple MFi Certified] 8 pin Lightning Cable using original connector from Apple Inc, 100% compatibility to transmit data stably and fast without error message.Apple MFI Certified ID:211755-0249.
  • Complete charge and sync compatibility with iPhone 6s6s Plus6 6 Plus 5s 5c 5,iPad Air Air 2,iPad mini mini 2 mini 3,iPad (4th generation),iPod nano (7th generation), and iPod touch (5th generation).
  • Sturdy and tangle-free design-covered with braided-nylon fiber jacket and anodized aluminum shell which is durable and sturdier than the normal lightning cable but also flexible and tangle-free.
  • 1M in length is ideal for varied usage, you can still use your iPhone or iPad while charging on a wall adapter in your bedroom,kitchen,office and more.
  • What You Get:1M Nylon Braided USB Cable with Lightning Connector.
AmanStino Lightning Cable Apple MFi Certified 1M Nylon Braided Charging...
Feb 27, 2013 | Samsung LN46A630 LCD TV
Why doesn't Iphone recognize usb cable
Hi There,
Its not only happen in you IPhone cable other USB equipment also get this error, This error will come when the USB cable have a fault, so change the USB cable and try again.
Thanks
Oct 20, 2011 | Apple iPhone 4 Black Smartphone
Cell Phones Logo
402 people viewed this question
Top Apple Cell Phones Experts
jacobcheatha
Level 1 Expert
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
