Question about Brother MFC 420CN All-In-One InkJet Printer
HELP!!!! ME!!!!
Im a constant printer user and whenever the color yellow is used my brother mfc 420cn prints green! I cant figure it out and my only other option is to take the whole thing apart. Does anyone have advice or a similar problem? I would really appreciate your help.
  • 383 Answers
Have you tried to re-start the printer /1st unplug and re-start again this might help but leave unpluged for 60 seconds.
If this dont work try a other ink cart. same color to see if this helps.
Posted on Nov 27, 2007
My printer is only printing out one color green
I cant advice properly about ur fax problem bt about ur miss-printing of ur printer its may b cause of ur colout cortex,change it with new one or fill colour.
Jun 18, 2014 | Brother MFC 420CN All-In-One InkJet...
I need to figure out how to use the scan feature on my brother MFC-420CN USB printer? Where is the manual available on-line?
Here's a full user manual and specifications of your Brother MFC-420CN thru this LINK. You should find your answers through this manual. Other features available for reading.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
TIPS: Is your computer slow? This might help
(for Windows only)
Mar 06, 2011 | Brother MFC 420CN All-In-One InkJet...
Black ink on my Brother MFC-420CN is faint and streaky
You said you replaced the cartridges. Were they Genuine Brothers' Cartridges?
My Brother MFC-240C, does not like Generic Printer Cartridges. That sounds like your problem. Also I had with Brother's was problem with Color. Color that should be Yellow, will turn out Green, or Blue Green, etc. The Generic Cartridges, also printed lines thru the words. That's what the Companies do., so they can keep selling the ink cartridges.
Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY, or Take them to have them filled.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for the PRINTERS.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 03, 2010 | Brother MFC 420CN All-In-One InkJet...
My brother mfc 420cn printer quit printing...
I'd venture to say that if you haven't used it in a while the ink dried up and clogged the print head. It is probably a job for a service center. Good luck
Aug 05, 2009 | Brother MFC 420CN All-In-One InkJet...
When i run a test pattern on my mfc 420 it will not print the yel
Clean the yellow printer head with the self cleaning function. Try printing yellow from a computer, etc. Check ink level, make sure it is not telling you low ink.
Jan 12, 2009 | Brother MFC 420CN All-In-One InkJet...
Want to print with black ink only using Brother MFC-420CN
I see it's been a while since you posted your question but in case anyone else is wondering about this, I'll answer.  The information is not in the User's Guide booklet but in the Software User's Guide which should be available on your software disk, or you can view it here
Basically, you go to the advanced tab under the printing preferences and select grayscale.
Dec 17, 2008 | Brother MFC 420CN All-In-One InkJet...
MFC-420CN does not print black
My yellow cartridge was doing the same thing as your black. So I took the cartridge out, and took a flashlight to see how it works. There is like a little straw on the right hand side which goes up into the printer cartridge, this I assume is to measure the ink. I took a needle and cleaned that 'straw' thoroughly. Reseated the ink, ran cleaning and test print, and then the printer found the yellow ink! You could give that a try. It might work for you too. (I have never used any ink but Brother ink in the printer, btw.)
Apr 20, 2008 | Brother MFC 420CN All-In-One InkJet...
My brother mfc 420cn printer won't print
i reset the printer to the original factory settings, and now it works. thanks for your concern and help, richard
Feb 20, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-420CN All-In-One
unplug maqchine from power. take all carts out. wait 5 minutes. connect machine to power. insert carts as demanded. give the right answer if machine asks if the carts are changed. machine will do some cleaning.
do you use generic ink? in that case you might have clogged the printhead with wrong ink. The ph cant be cleaned anymore.
nevertheless try this (carts should be nearly full!):
press menue then start mono (blue copy) then fourtimes arrow up. machine will be in maintenance mode. press 7 then 6 then 4. Machine will display init_all. press start mono. machine will refill tubes and
ph with fresh ink and do some cleaning. after that press 7 then 6 then 3 and start mono. machine will do a powerpurge.
press zero then 9 to do a quality test print. If it cant do the job leave maintenance by pressing 9 then 9. do the test print manually by pressing ink etc.
If you still do not see any colors the ph is clogged and cant be fixed anymore. It has to be replaced.
Dec 03, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
143 people viewed this question
James Cagle
James Cagle
Jim Keysor
