SOURCE: LG Spilt A/C
medev,
there is a lot of reason why your LG split unit would not work by remote control.
first likely trouble is the remote itself. it could have drop from a height and broke the remote, or corrosion has set inside the remote if you left an old battery for a long time and it could have broken it.
secondly which is not more likely to happen is the remote receiver in your unit got broke that is why it can not communicate with your remote controller. it could happen if someone has serviced your evaporator and could have disconnected wires to the receiver , or wires were just left not connected.
you can test the remote if you have an identical unit which is working with a working remote. use the working remote to your unit then you can decide.
i hope i was able to help.
SOURCE: Honda VTR 1000 Low fuel sensor problem
yes i bought another tail light and could not figure out whish wire went to what. After connected like when I bought the used bike whether a turn signal or brake like something always seems not to work. I have a 2002 honda vtr is there any way I could get the tail light wiring pattern or something. thanks
SOURCE: I have a hunter remote
There is no way. Only the manufacturer can reconfigure thw remote. That is part of the defect of this product.
If it works fine, leave it and just continue to use it.
Cheers.
SOURCE: remote control wall unit does not turn on Monte
Are the manual switches on the fan in the 'on' position?
Select the maximum fan speed on the remote and then operate the manual switch on the fan. Set that to the highest speed then control it with the remote.
Same theory applies to the light.
If this is not the problem then the remote receiver on the fan is probably faulty.
Hi
If clean light is blinking 7 times then it may be an issue
with heater circuit, door switch or wash pump. If yes then please reset the
power to the dishwasher. After, 5 minutes check if you are still getting the
same error. If yes, then it is a water heating fault. To resolve this error try
pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High
Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi
Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and
then you press the Cancel/Drain button and allow it to completely drain and
reset.
If this doesn't work then it's an issue with the wash pump not pumping the
water past the heater efficiently or due to lack of water to heat. Please make
sure that heater is not open circuited and is heating the water efficiently.
You'll have to check the heater using a multimeter; the meter should read
between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is
fine then make sure water pressure is optimum and fill valve is working
fine.
Hope this helps... Please post back for further assistance.
Daniel
