Question about Compaq Presario M2000 Notebook
No battery connected still gets hot and cuts off
How do i resolve this problem
  • 55 Answers
Try to clean the vendilation holes with some compressed air/check if your vendilator still working
Posted on Nov 27, 2007
I have a 91 chevy s10 4.3 i had the truck running soon as i cut on the ac. The truck cut off there were no lights no nothing so i check the emcb fuse it was fine please help
Make sure battery has a full charge and battery connections all good, check fusible links, one of your positive battery connections should run to fusible links, where applicable. Ann\y fuses, not only check the fuses, check for voltage on the fuse circuit, use a testlite or something. Some fuses are hot all the time, some go hot with the key on.
Ground is also important.
Oct 23, 2016 | 1991 Chevrolet S-10
Tumbler drying not heating up but air blowing through
Check High temp cut off safety switch. If it's broke, not connected or? it will not let coil get hot.
Feb 27, 2015 | Dryers
How do i find the hot wire on my 2012 toyota tundras ignition switch
To be legal they must not operate when the high beams are on. Use a relay because of the current and connect them via the relay to the battery. Power the relay from the low beam power wire. Be sure you put a fuse in the battery line.
Nov 18, 2014 | Toyota Cars & Trucks
Bike cuts out at running temperature
You actually may have two problems. First, if you have a spark from a coil, find out why. May be a bad or loose connection. when coils get hot their resistance increases. A leak or bad connection will show up quicker when hot. If the spark comes from the body of the coil, replace it.
Second, your starter may be breaking down when hot. Check the brushes and coils in the starter motor. The same discussion about loose connections also will apply to the starter.
good luck
Apr 08, 2014 | Honda Varadero 125 Motorcycles
Starter clicks will not turn engine over
next is jumper cable jump start to good running helper car battery.
that cuts cause in 1/2 , 15min works.
car starts, your battery is bad, or not charging, running, or is only discharged. (left head lights on)
wont crank. now?\\
hot wire the solenoid, for cutting possibles in 1/2 again.
what transmission? in car?
see tricks here. (and the hot wire trick)
http://www.fixkick.com/nocrank.html#tricks
Feb 15, 2014 | 2005 Honda Accord 2.0
Car cut out like no ignition, now no power to starter circuit. Battery new & hot
No power to starter circuit.The starter gets power from battery to start.So check the connection between battery to starter.As you mentioned battery is new ,but still get the battery voltage checked.It should be 12 volts if battery is fully charged.If battery shows 12 volt then check the connection terminal from battery to starter.If connection checked ok then its most probably the problem of faulty starter.It has to be replaced.But if the starter checked out ok by meter, then the problem relates to faulty ignition switch circuit causing this problem.Checking all this possibilities will rule out the exact faulty part causing the problem.----------Thanks.Helpmech.
Dec 02, 2010 | 2002 Ford Taurus
Car cuts off
Recheck all connections at the starter and at the battery as well as inspect engine grounds ..sounds like a connection is getting hot and causing the Circut to go open..the old expansion and contraction with relation to temprature...
Jan 25, 2010 | 1997 Buick LeSabre
My 1992 kawasaki zephyr 750 cut out and died when
sounds like your battery has an internal short circuit, time to change it and hope nothing else got damaged
Oct 05, 2009 | 1992 kawasaki Zephyr 750
I HAVE A 92 BUICK LESABRE BUT KEY IN SWITCH TURN SWITCH NO POWER GOING TO SWITCH SIDE OF STARTER BUT WHEN I TAKE A WIRE FROM HOT SIDE OF BATTERY TO SWITCH SIDE OF STARTER AND KEY IN SWITCH TURN ON CAR...
You have no power from the switch to the starter. Check all you wiring that goes through the fire wall and look for burnt connections or just bad connections.
Aug 05, 2009 | 1992 Buick LeSabre
Van will not when hot 1997 gmc savana 1500, 5.0
Could be the battery and starter solenoid. Solinoids often heat up and can't make the required electric connection until they cool off.
Or, the battery can't hold a charge due to faulty alternator or other electrical parts. The only other thing I can think of is the head gasket or cooling sustem is bad allowing an overheat to take place and the moving engine parts lock when hot.
Frank K
Jun 29, 2008 | 1997 GMC Savana
Compaq Presario M2000 Notebook Logo
26 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
