Question about JVC Audio Players & Recorders
I need to replace motor on jvc turnyable la -120 where can i find new motor
My husbands blood pressure is 100/30 is that normal
Lo recomendable es tener una presi?n sist?lica que no supere los 120 mm y la diast?lica siempre por debajo de 90 mm. Por tanto, una tensi?n arterial ?ptima ser?a la que se encontrara por debajo de 120 mm y por debajo de 80mm. La tensi?n arterial normal generalmente se encuentra entre 120 y 129 mm en la sist?lica y entre 80 y 84 mm en la diast?lica. Cuando los valores son iguales o superiores a 140 mm y a 90 mm, nos indica una tensi?n alta o hipertensi?n. Si por el contrario son valores iguales o inferiores a 100 mm y a 60 mm, se trata de una tensi?n baja o hipotensi?n.
May 26, 2018 | Health & Beauty
Coleman blower motor eb15b bought after market replacement, old motor no common wire on the motor but wire from capacitor to transformer. New motor has common wire directly from motor how do I hook it up?
Maybe this new motor is a multi voltage motor meaning it could work with 240 volts and also 120.
If needed for 120 then you used the common .if 240 you don't need it .
Most of the time wiring diagram is on the motor itself
Dec 22, 2017 | Coleman Heating & Cooling
How to remove Platter on JVC L-A120 Turntable
Hi Jeff...
The platter on the JVC LA-10 does not come off as most turntable platters do. It is attached to the spindle with a Philips head screw.
Here are the steps:
Remove dust cover from turntable. Unscrew hinges and lift.
00.jpg" alt="Remove dustcover at hinges.">Remove dustcover at hinges.
  • Secure tonearm to prevent stylus damage.
    00.jpg" alt="Secure the tonearm.">Secure the tonearm.
  • Remove slipmat from platter.
    00.jpg" alt="Remove slipmat.">Remove slipmat.
  • Turn the turntable on its side and remove screws that hold the top to its base. Remove platter by unscrewing the bottom plate from the turntable. The spindle bearing is held in place with a Philips head screw. Loosen it and the platter will separate easily from the spindle.
    00.jpg" alt="Separate the spindle from the platter by loosening with a Philips head screwdriver.">Separate the spindle from the platter by loosening with a Philips head screwdriver.
  • Loop replacement band around the pulley cylinder in the motor. Replace platter and bottom plate. Tighten spindle screw. Test the new belt by turning the platter clockwise two or three rotations. Belt should fit snugly and turn with little resistance.
    00.jpg" alt="Test the replacement belt by turning the platter clockwise.">Test the replacement belt by turning the platter clockwise.
  • Feb 05, 2016 | JVC Audio Players & Recorders
    LCD cracked & need to be changed I live in La
    In the cse of your unit it is much more cost effective to replace it than to fix the screen. A new one would run around 110$ where the repair would cost you 120$. So i would recommend upgrading to a newer unit.
    Hope this helps!
    May 09, 2011 | Garmin Nuvi 265W GPS Receiver
    Need wiring diagram for table saw motor LR 63420 Model D for 220V
    Mine is connected to 220v
    Connect leads 235 together.
    Connect lead 4 and 8 to the Neutral.
    Laed 1 to the Live/Line.
    Do you know theconnection for 120 volts ?
    May 07, 2011 | Garden
    My granddaughter has lost my instruction manual for my Zune 120.
    por error borre la informacion de mi reproductor zune 120 negro como puedo reintalarlo?
    Apr 25, 2010 | Microsoft Zune JS8-00001 Digital Media...
    JVC LA -55 Skipping
    How old would you say this turntable seems to look like?
    Jun 28, 2017 | Emerson NR303TT CD Shelf System
    JVC HX-7 (protect)
    The problem is that the output amplifier section has a problem and the protection circuits are shutting down the system to prevent further damage. This should be a simple repair for any local service shop. If you can't find someone local, look up at the JVC website for an authorized service center. Use your zip code to locate the closest one.
    Dan
    Sep 29, 2008 | JVC HX-C6 Shelf System
    Top JVC Audio Players & Recorders Experts
     Grubhead
    Grubhead
    stynger007
    Level 1 Expert
    Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
