Question about Kodak Cameras
For the kodak camera,can you put new batteries in when the old batteries is dead?
  • Kodak Master
  • 5,936 Answers
Which particular model of Kodak camera had you in mind ?
Posted on Mar 22, 2019
SOURCE:
SOURCE: kodak easyshare cx 6330
Easy Share CX6330 zoom button came off and is lost. Where to get a new button and can I put it on/
Thanks
PF
Posted on Feb 09, 2008
tjjfitz
  • 8 Answers
SOURCE: Camera battery clip
Well, I got the latch and spring back into my DX7630, and so far (half an hour after) so good.
To do this, I had a replacement latch from U.S. Camera ($10 total, latch plus shipping and handling) and the original spring on hand. I took all of the eight screws holding the camera body together. I also pulled off the "rubber" hand grip on the front of the camera. I'm not sure if that was necessary or not, but in doing it I broke off one of the "claws" that secure the grip.
Then I turned the camera so the battery door was on top, opened the door, and gently pried the camera body halves apart. I used "square" wooden toothpicks to hold the body apart so I could get at the latch area. (The battery was not in the camera during all this work.)
There are two small slots in the camera body where the latch is held and pivots. The latch pivots can be slipped into those slots if the toothpicks have the body wedged open widely enough.
The hard part of the assembly is getting that latch spring properly mounted. The spring fits over the rod of the latch. The spring wire has two ends: one is shorter. The shorter-end goes behind the latch on the memory card side. The longer-end makes the job difficult. It must be held so that the spring is under tension while the battery side latch pivot is slipped into its slot, then the memory card side latch pivot is slipped into its slot. The longer spring-end presses against the camera body.
The latch and spring only flew away into the darkness of this room once during the effort, and that happened because I tested the latch a few times before closing the camera body. The body halves should be closed before doing any latch testing.
I put all the screws back into the camera snapped the rubber hand grip back in, put in a battery and a memory card, and at this writing, all seems to be working as designed. Hooray!
Posted on Oct 21, 2008
  • 15 Answers
SOURCE: kodak c613 will not switch on put in new batteries had this camera since xmas
use rechargeable batteries with your camera.alkaline batteries can cause power issue. Make sure batteries are inserted correctly, please check manual
Posted on Dec 05, 2008
RattMur
  • 53 Answers
SOURCE: Kodak Z812 shuts off automatically
It is a high-powered camera, also knows as a GREAT camera. Use CRV-3 lithium duracell batteries. I have the same camera and the same "problem", but when I use that battery it lasts forever.
Posted on Jan 16, 2009
SOURCE: My Kodak EasyShare DX4530 camera dock not charging batteries.
There was an issue with the 4000 series and the NiCd batteries I remember that had to do with the contacts in the camera.  The charging circuit is in the camera so you have to make sure that the battery contacts are clean, both on the battery and in the camera.
Posted on Jan 26, 2009
Not coming on
Make sure batteries are not dead or too old and/or your display is not broken.
Jan 01, 2014 | Kodak EasyShare C140 Digital Camera
Kodak easyshare m320 charge light is green, but not charged
Hello Dead Battery, Well this sounds pretty easy compared to most questions I get. If the camera says the battery is dead, then the battery is dead !! the problem with batteries is they loose their capacity over time. The charger can not put any more in it and says it is charged. Just get a new one and give it a full charge and this should do the trick.
Best Regards, Russell
Sep 29, 2012 | Kodak EasyShare M320 Digital Camera
My camera is less than a year old.I have put in new batteries.Sometimes it will turn on,sometimes not.
I bought a kodak c182 for my daughters wedding. it work wonderfully, but now I have a problem with the batteries. I can put in new batteries take 1 picture, then it says low battery and shut off. I have place seveal new batteries in and get the same results. Could it possibly be a promblem with the memory card.
Mar 15, 2011 | Kodak Easyshare C182 12MP Digital Camera
No power or dead set,no function at all even i put new batterries
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 23, 2009 | Kodak EasyShare CX6200 Digital Camera
Camera wont turn on
go www.kodak.com/go/stepbystep
after following the troubleshooting steps
process repair thru the website
just follow the procedure
after submitting the repair process
it will generate email for you on how to send camera for repair > check your email
Sep 23, 2009 | Kodak EasyShare C913 Digital Camera
My camera worked perfectly fine until the battery went dead. it wasnt the original battery that came with the camera and i charged it with the charger that did come with the camera so i thought the charger...
your battery area is infected with the chemicakl that is leaked from your old battery.
get it cleaned by an expert with chemical treatment.
also fornat your emory after cleaning
sagar
Jul 29, 2009 | Kodak EASYSHARE M763 Digital Camera
Kodak DX3900 camera can't get power from battery
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Mar 13, 2009 | Kodak EasyShare DX3900 Zoom Digital Camera
Easyshare 721 battery problems
You need high-power re-chargeables - 2300 mAH or 2500 mAh
May 13, 2017 | Kodak EasyShare CX7430 Digital Camera
KODAK Z1285 BRAND NEW BATTERIES ..WHEN I TRY TO TURN IT ON THE SCREEN BLINKS THEN GOES DEAD .. THE CAMERA IS ONLY 3MO OLD AND NEVER DROPPED OR ANY DAMAGE ..
Only specific batteries can be used with this camera, look closely at the battery door. Alkaline batteries are NOT listed. You MUST use NI-MH or Li-Ion. Hope this helps...
Aug 19, 2008 | Kodak Cameras
Wont Turn ON!
I returned mine to Kodak (warranty) and they replaced it - was not fixable. :(
Sep 17, 2007 | Kodak EasyShare Z740 Digital Camera
Cameras Logo
Top Kodak Cameras Experts
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
