Question about Refrigerators
Ice maker leaking
My icemaker leaks water that forms a large icicle in the icecube tray. whats the problem causing this? i have to remove the ice formation at least once a day. Ive tried changing the filter. Nothing has worked. water is leaking from inside icemaker to left side of refrigerator
  • 2 more comments
  • SOPHIEDK Nov 27, 2007
    kenmore model# 10672104107
  • jkdhild Aug 09, 2008
    My icemaker leaks into the icebin. It freezes up and renders the dispenser unusable due to the ice that surrounds it.
  • agapee4us Dec 19, 2008
    I have a Maytag Ice2O that leaks water from the icemaker. It all started when my kid removed the bin. I turned off the water supply to the ice maker and changed the filter but it still leaks if I turn the water supply back on. It's stainless, so you can imagine how hard it is to clean when the despenser starts leaking.
  • mstoller Feb 01, 2009
    I have the same problem. Our refrigerator is a GE side by side model # TPX21BRXABB from 1995. When the water fills the tray, it runs all over, freezing in the bottom of the bin, causing the auger to be frozen in place, and a trickle of water to run in the dispenser area on the outside of the refrigerator.
  • 213 Answers
What brand refrigerator?
Posted on Nov 27, 2007
Ice maker leaking into ice storage tray
start with hose replcement buy parts at sears water hose to main ice maker might have crack in it or the stopper is bad get in ther look close with brite light
Oct 14, 2008 | Refrigerators
Icicle are forming around icemaker port inside of
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Sep 17, 2009 | Kenmore 53542 / 53544 Side by Side...
Icicle are forming around icemaker port inside of freezer compartment drips seem to come from around inmaker feed water area.
Sep 17, 2009 | Kenmore 53642 / 53644 Side by Side...
Icemaker leaking causing icicles
Is it overfilling with water? If so, it may be an problem with the fill valve leaking slightly. I say slightly because if it were a large leak, the freezer would have frozen puddles in it. Also check the water chute to be sure the water is all going into the freeze tray. Sometimes they can work loose.
If the seam is leaking, there could be a crack in the housing - not sure that's repairable - sometimes epoxy will work (5 minute, 2 part) but it can be difficult for glue to hold on the type of plastic used in an ise maker housing.
Mar 27, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water leaking underneath icemaker, dripping into ice tray
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the first one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Feb 20, 2009 | Amana DRS2462B Side by Side Refrigerator
Kenmore refer #70162990 ice maker leaking into storage tray
Please confirm you have given the complete model number.
If the icemaker has a bail wire to control how much ice is in the bin, there is a fill switch inside the front cover of the ice maker which allows you to increase or decrease the amount of fill.
You may also have a cracked or corroded ice mold. Check by filling the icemaker with water manually, and watching to see if it drips once the initial overfill stops dripping. This would also be indicated by the ice cubes being smaller than usual.
Jan 04, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
please check the small hose that guide the water to the ice tray. see that it is in good condition and no cracks or damage what so ever. then look closely at the ice tray, there maybe an ice that would not fell. could have been stuck in there that is why every time water would flow, it would just flow anywhere.
tnx 4 using fixya,
drcool
Sep 30, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker leaking
what is the model number of this fridge?
HTML clipboard_______________________________
http://www.subzerolosangeles.com
Los Angeles Sub-Zero refrigeration experts
May 19, 2008 | Sub-Zero 632 / S
Ice maker leaking
Sometimes the frozen chunk of ice in the back of your ice tub is caused by the tub being overfilled. The ice cubes pile up so high that they come in contact with the defrost heating element in the bottom of the ice maker. This melts the already formed cubes and form a blob of ice in the rear of the tub.
If the "icicle" is forming even when the tub is relatively empty, then it is probably a leaking solenoid valve. This is an electric water valve that opens and closes according to demand. Like any valve, it has seats that eventually leak, especially in areas with hard water. This will need to be replaced. Water filters go a long way in increases the usefaul life span of the valve and will also improve the ice quality.
Dec 02, 2006 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
840 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
