Question about HP Pavilion dv4000 Notebook
Bright points on my DV4000 Display
Hi there
I bought a DV4000 from a Friend some time ago but i didnt touch it four about 4 Monthes. Yesterday i went to try to repair it and i noticed a bunch of bright white points on the Display that weren't there four Monthes ago.
Do you have any Idea why those Bright points appeared from nowhere? Is there a way to repair the Display and make them disappear? In worst case, is there a way to enmask it a little maybe playing with the colors?
Please i really need help on this one, i would be very greatfull.
Thank you
Peter Saints
  • 324 Answers
Re: Bright points on my DV4000 Display
Hey, Picas!
So you have a pixel problem, huh? OK, you said a "bunch" of white points. How big is this bunch? Are they all in 1 area or are they scattered around?
There are a couple of things that you can do that may help. First, you can try to massage them away. You find a cloth that is soft enough that it won't scratch the face of the LCD. Then you wrap this around you finger, press somewhat firmly and "massage" the area where the problem pixels are located. Some people use a quarter rather than their finger.
The second thing that you could try is to run a screen exerciser that I found online. But, I don't remember where I got it. If you send me your e-mail address, I'd be happy to sent it to you. It's a small exe file that lets you do a number of things to your screen, and supposedly will help by repairing pixels. I've not had a chance to try fixing pixels with it yet, but have used it for other purposes.
Posted on Nov 27, 2007
0 characters
3 Points
I have problems with my quick touch buttons. The volume will adjust itself randomly, locking the mouse etc.. Also the wifi button will stop responding sometimes and randomly start working again.
Try this,
1. Click combination of buttons on your keyboard Windows+R -> Type MSCONFIG -> OK -> Continue -> Go to Startup Tab in the System Configuration -> Uncheck "HP Quicktouch On Screen Display Item" -> Restart Your computer.
It disables the on screen display of the volume control.
If this helpful, please give a testimonial and vote by pressing button four thumbs up
Aug 28, 2011 | HP Pavilion dv4000 Notebook
Hi..i am using compaq presario cq 40 and screen is flickering.i had it checked and they told me lcd is the problem but they didnt even bother to check.they just turned it on and they told me that i have to...
When it flickers, can you still see the text when the screen goes dark?
May have to use a bright flashlight set right on the display to see
the text on the screen beside where the light sits.
That will tell you if it's the backlight.
You can also look at a grazing angle into one of the edges to see if the
backlight is flickering when the display does.
When it's cold, does it start with a slight pinkish color? That can be
a sign of backlight going bad.
Anything interesting happen when you flex the cable by moving the screen?
I'm not saying it's impossible, but I've never seen software cause
consistent screen flicker. And if the vga port doesn't flicker, sw is
even less likely the problem.
If you bet the odds, you'd bet on a bad display cable.
Won't hurt to try replugging it.
If that doesn't help, then your monitor may be dying....
Jun 20, 2011 | PC Laptops
One of my friends did something to my computer and i think it inverted the colors. i had to change the display settings to actuall see the screen but now certain colors, or it might just be white or black,...
Right-mouse click anywhere on your "desktop wallpaper".
Click Properties.
Did your friend change a "theme", via the 'Theme' tab?
Did your friend change something via the 'Appearance' tab?
Did your friend change the 'Settings' (down to 4 or 16 colors) ?
If you connect an external monitor to the VGA-output port,
do you get the same colours, or do you get "proper" colours?
If you get "proper" colours, it could be that your internal LCD screen is damaged.
If all else fails,
click Start
Click All Programs
Click Accessories
Click System Tools
Click System Restore
Select a "restore point" one or two days ago, before your friend touched your computer, and "restore" your computer to that date/time.
Jan 05, 2010 | Dell Latitude D520 Battery PC Notebook
i have acer 4736zg ;that i bought 4 months ago my computer gets heated and shuts down automatically; it works nicely for a week; and gets heated and shut down automatically 3 to 4 times in a day; i am using windows 7 and kapresky anti virus before my computer has windows vista and mcafee antivirus. yesterday my computer showed blue screen death for six times each time i connected net ; i checked the memory status and now its ok but it shutdown for three time in last 12 hours; can u plz help me out
Dec 16, 2009 | Acer Aspire 4720 Notebook
A thin line appears in the display
It could be the video card or the LCD display is going bad. I would suggest contacting HP support regarding this matter. Hopefully you registered it with them when you bought it. Most computers have a one year warranty from the manufacturer. Did you buy an extended warranty with this machine? If you have an extended warranty from the place you bought it, contact them.
Dec 01, 2009 | HP Pavilion dv4000 Notebook
Hi there, I bought an Acer Aspire One netbook two days ago. That evening I installed AVG anti virus and Online Armor. Everything seemed to be working fine. I shut the netbook down. Yesterday evening I...
yeah I'll give you the best suggesstion since you have just bought your acer notebook take it back to the store and have them re-installl windows for you,since its just been two days they will do anything for you
Oct 11, 2009 | PC Laptops
DV4000 display is in XGA mode does not fill the screen
Please check the unit with the external monitor>If the External monitor works fine >Its an issue with the LCD of the unit you can replace it
If the External monitor is also actining in the same way>It could be an issue with the system board.
After all the driver updates this is the finall step,
If not possibel to replace the LCD, try to reinstall the OS
Jul 03, 2009 | HP Pavilion dv4000 Notebook
Hi Friend,
Open the Laptop at the top u will be having a wireless symbol ,kindly press it for 2 to 5 sec,the bluetooth will be activated,i.e.,bluetooth will be ON.
Jun 04, 2009 | HP Pavilion dv4000 Notebook
My touchpad didnt work at all, how?
Good to know that enabling the touchpad with the FN and mouse key solved the problem. Your very welcome Cathy. :) Rate me please when you get the chance. Have a great week!!!
May 05, 2009 | Acer Aspire One Netbook 8.9" Notebook
HP Pavilion dv4000 touchpad problem
Im having the same problem. It didnt start until i had to turn my lap top upside down and such trying to get the battery to work, taking it in and out and so forth.
I push down on the left hand side by the touch pad and it works fine. If i dont press down, my typing will not show, music will not play, the whole pc freezes even the time on it.
Oct 21, 2008 | HP Pavilion dv4000 Notebook
HP Pavilion dv4000 Notebook Logo
82 people viewed this question
Top HP PC Laptops Experts
Brian Sullivan
Brian Sullivan
Michael Thomas
Michael Thomas
Are you a HP PC Laptop Expert? Answer questions, earn points and help others
