Question about Mitsubishi Televison & Video
Green light comes on and blink's twice and go's off Mitsubishi ws-55411 year 2002
    Top Expert:
  • Mitsubishi Master
  • 1,116 Answers
SOURCE:
  • 192 Answers
SOURCE: Mitsubishi WS-55411 55 in. No Power up
Error code 12 means normal operation. On these models we have found that a switch is bad on the control panel not allowing the set to turn on. Disconnect the control panel. You will be able to use the remote on set. To find the plugs for the control panel: Remove the speaker grill and front panel, then follow the wire to the connection. You can use an ohm meter to find the bad switch.
Posted on Jul 04, 2007
  • 1030 Answers
SOURCE: Green blinking light on Mitsubishi WS-55813 HDTV
generally this means a bad digital module.. as a techinican the first thing that we would check are what is know as standby voltages. if they were there we would replace digital module.! question. Does it blink for more than 70 seconds. This unit comes with a lockout feature. to unlock press and hold menu down for 10 seconds on front panel.
Posted on Jan 08, 2008
Slinteriors
  • 8617 Answers
SOURCE: mitsubishi TV WS-65713
you can get the service manual and detailed instructions on that repair by going to the following link.
http://servicemanuals.vstore.ca/
Posted on May 31, 2008
SOURCE: mitsubishi WS-55859
Easy to fix this problem, I did 1 mounth ago. 30 min and $20 dollar
Posted on Dec 30, 2008
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi WS-65869 BLINKING GREEN LIGHT
ONLY 1 of 2 things can cause this problem----
First thing to do is remove front speaker grill--it should pull out and is secured with plastic pegs--behind it you will find an inspection plate---
Notice the one or two pairs of wires coming from the front keyboard of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---
These sets have a Receiver that is called a DM board--(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up. It is called the DM board.
If disconnecting the keyboard allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and/or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---
You can call them and get a quote for repairing the receiver.
Let me know what more information you need--I am here to help.
SD TECH
Posted on May 02, 2010
Mitsubishi ws55411 wont power up
Is the led just blinking non stop green? If so you need the DM repair kit for that model which is available from www.tvrepairworld.com the kit contains the upgraded caps and the CD with repair instructions.
Apr 30, 2011 | Mitsubishi WS-55411 55" Rear Projection...
My mitsubishi tv wont come on and green timmer light blinks fast
Try the blinking light repair kit from http://www.tvrepairkits.com/xcart/home.php?cat=2658 . This kit has fuses and capacitors that are designed for your TV.
I hope this helps.
Apr 24, 2010 | Televison & Video
TV wont turn on, the power light turns green for a second then blinks three times and turns off?
That blinking light represents an error code,give Mitsubishi a call they will help you troubleshoot and diagnose your problem and if needed help you set up service. 1-800-332-2119 Good luck !
Nov 29, 2009 | Mitsubishi WS-55411 55" Rear Projection...
Same exact problem.
this set should have a built in self diagnostic--if you try to turn it on and the green power light comes on for a moment and then goes off---on the front of the TV press and hold Device(input) and Menu both and hold for 5 seconds and then release both---green power light should blink in a sequence---most common is 2 blinks, pause and 2 more blinks---most common reason for this error is one of the convergence IC's is shorted.
Aug 06, 2009 | Mitsubishi WS-55411 55" Rear Projection...
Do have power and sound, do not have picture
this unit has a self test check you can do
when the set shuts down or when the set is turend off.
press and hold , onthe front of the set the input or device button, and hold the menue button for bbout 5 seconds.
the set will flash a 2 digit blink code at you.
12 blik = no problem
21 blink = xray protect
22 blink = short protect
23 blink = loss of deflection.
regards,
daniel.
Jan 15, 2009 | Mitsubishi WS-55411 55" Rear Projection...
TV not turning on after left on
ok 6 hours is not long but i would deffintly say u have a power issue now with the box inside over heated and burnt out will have to be prfessionaly replaced
Jul 18, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi turns on for 3 seconds then shuts off..after power surge
try holding in the menu and input buttons together on the front panel for about 8 seconds to see if the self diagnosis feature will blink a two digt code then let me know what happens
Jun 05, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Powers off
these set have lots of bad conections and have a problem with two bad caps in the 9 volt reg curcuit one is right behind the reg
Nov 03, 2007 | Mitsubishi WS-55411 55" Rear Projection...
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
