Question about Kenmore Refrigerators
I have a Kenmore Coldspot model #10651122210 how do I remove the ice bucket?
SOURCE:
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
TheMobilian
  • 8220 Answers
SOURCE: Ice maker not working Kenmore model 106.55226400
Look for an ice cube lodged in the fingers IM. Get a hair dryer and melt that dude. No ice cube? Add some water to the IM mold. If it kicks out some ice but makes no more then you is gonna need a water valve. If it don't kick out no ice then you is gonna need a ice mold thermostat. Either one is very easy and cheap to fix. let me know Kimosabe.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 06, 2009
SOURCE: kenmore coldspot - How do you remove the ice maker box to clean
I have the exact same Kenmore and exact same model #77292798. It's the top freezer model with ice maker. Here's what I did:
Empty everything in the freezer.
Turn water to ice maker off from source behind unit.
Remove bottom panel (two screws)
Every screw in the freezer is the exact same size. I used a screwdriver style socket and, I think
this works the best.
Remove ice maker (4 screws) and unplug from socket.
Remove rear panel (2 screws).
My freezer was loaded with ice underneath the bottom panel. The ice scraped away easily. There is a tin pan underneath the coils that drains toward the middle where the drain hole is. Again, my freezer was full of ice beneath this tin pan and, I had to scrape away. You may be tempted to try and remove the coil because it would be easier to get to drain hole. I tried this and, it did no good. Don't try it. Once all the ice was scraped away, I realized that the drain hole was plugged with ice. I used boiling hot water and used a squeeze bottle to pour the hot water into the drain hole. I then wrapped a paper towel around a thin screwdriver and used that to soak up the now cold water in the drain hole. After doing this a dozen times or so, the drain finally cleared.
Then, reassemble. This was a much easier task than I thought it would be and, will take care of it much quicker next time.
Posted on Apr 17, 2009
  • 6 Answers
SOURCE: kenmore coldspot 106.556325 not making ice
could be your ice maker or your water valve
Posted on Aug 30, 2009
rogrrabbit
  • 986 Answers
SOURCE: Oue Kenmore Coldspot ice-maker quit working. Any
Wake up one morning and Boom no ice left in the bin. What happened and What can I do to fix it without calling someone? Some ice makers will get a piece of ice in the wrong place and jam the extraction. Get a hair dryer and heat up the ice maker to release the fouled ice cube and that baby will start going. No water in ice mold?Do this easy test: pour some water in the ice maker mold and wait. If it kicks out a batch, but it has no water in it, most likely the water valve is bad. water%20valve%20for%20water%20and%20ice%20through%20the%20door.jpg Watervalve for SxS box Since it is the cheapest part and you can do it yourself replace it. If it turns out you need a new ice maker then you have a new water valve already to go with it. What if the ice maker has ice in it but won't harvest any? One cheap and easy item for the do it yourselfer to replace is the ice mold thermostat. Check for voltage between T and H if you have 120 volts then the bi-metal (inside that ice mold thermostat) is bad. If it's good you will have 0 volts. ice%20mold%20thermostat%28modular%29.jpg Ice mold thermostat Located in the plastic housing and seated against the ice mold is that thermostat. This looks intimidating but is easily fixed by anybody who could change a spark plug. There is no wiring. One more thing to look for: You can put a jumper between L and V and this will activate the watervalve. Have rags ready! If you are a cheapskate and want to be frugal and not buy a new ice maker or a new head(brain) head1.jpg modular crescent ice maker you may want to remove the main gear and clean the copper plate behind it. That plate gets dirty and won't allow for a good contact with the water valve connection and does not power up the valve...Shhh! They will all be doing it! Modular crescent Icemaker test points: With NO power to the icemaker, and ice ejection fingers in the freeze position: Your ohm meter should read 8800 ohms between L and M, and 72 ohms between L and H. With power ON to the ice maker: If meter reads 0 volts between L and N you have no power to the ice maker. If the meter reads 120 volts then you have power to the ice maker. If you have 0 volts between L and H heater is off if you have 120 between L and H the heater should be ON. If you have 0 power between L and M the motor is off. If you have 120 between L and M then the motor should be ON. If you have 0 volts between T and H the thermostat is closed If the meter reads 120 between T and H then the thermostat is OPEN. If the voltage is 0 between N and V the water valve is closed. If the meter reads 120 water should be filling the mold.
Posted on Nov 11, 2009
Kenmore coldspot refrigerator model 52552100 makes ice but wont dispense it
Below is a fix by another owner of your make and model for the same issue.
Pulled out ice bucket; tried ice dispenser with door latch pressed in and solenoid engaged and motor moved. Tried again and nothing (couple of times). Tried water...all good...good closure of dispensor flap (air pot operated). Opened dispenser (pried off carefully from bottom on this unit not to take off the glued part) and saw the micro-switch broken off of the ice dispenser side. Checked micro-switch (all good). Replaced control bracket...all good to go.
Nov 25, 2016 | Kenmore Refrigerators
What would cause my Kenmore Coldspot ice dispenser to freeze up where the water enters from the tubing into the ice maker itself?
Small leak in the tubing. remove ice-maker, cut tubing about half an inch back and reconnect ensuring the tubing is completely on the ice-maker.
Jul 05, 2016 | Kenmore Refrigerators
Kenmore coldspot model 106.58902800 ice maker does not dispense ice
Ice maker will not dump ice, makes it but will not dump ice.
Jan 30, 2012 | Kenmore Refrigerators
Kenmore coldspot model 106 9445781 the icemaker motor makes loud noise. Sounds like its under a heavy load.
Suggest you take the ice maker out and defrost it. You propably have ice crystal buildup and causing it to labor harder.
Jan 16, 2012 | Kenmore Side by Side Refrigerator
Kenmore Coldspot Ice Maker Modle #106 56622500 I
these have to be in correctly to lock back in and allow the unit to function. Try removing the bin again and be sure there isn't any small pieces of ice trapped anywhere. Also make sure there aren't any broken pieces from the bin. Hope this helps. Good luck.
Aug 18, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My icemaker is turned on and hooked up properly but it doesn't work there is no metal lever inside the icemaker that needs to be lifted up, Kenmore Coldspot model # 106.56534400
your mod is probably type with wlect eye , if ice bucket is on door . this is the type you have , and no lever is on icemaker . the problem is with the eye .. replace the eye kit . this is a very common problem . new kit is revised / and works good .. mm feed back pls .
Dec 17, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Ice maker won't stop producing ice, even when bucket is full.
the arm that swing up and down maybe able to be ajst by bending arm and the water leaking down the icemaker. is it unlevel when if fills if not unlevel is it hooked up to an r/o system if it is when was the last time filter were replaced if not, does it have a water filter has it been changed lately.
Aug 20, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore Coldspot Model 70162990 - not making ice
You've either got a bad timer on the ice maker or the water valve is defective. You need to verify that the timer is moving first. If it isn't try pushing in on the dial on the end of the ice maker. It is under the white square cover at the end of the ice maker, usually towards the door, but in some units it points to the left side wall. If it begins to run when you do that, then the timer is broken. If not then I would say that the valve is defective.
Feb 01, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore coldspot not making ice, and not cooling in the bottom
Your refrigerator is frosted up. Remove the inside panel of your freezer. Defrost the ice out of the coils and check the heater and bi-metal. If both are good then your defrost timer is bad. If one is bad replace and you have it fixed. Good luck.
Michael Anderson
(865)945-3808
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
50 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
Jimmy
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
