Question about Hunter 19' X 21' Room Air Purifier Air Purifier
Controls are in lock
On my display it says lock how do I unlock my controls
0 characters
1 Points
The control card is displaying error ch-01
PDF]SERVICE MANUAL R?410A Ductless Split System Air ...
421 01 9204 00 1/03/13. SERVICE MANUAL ... Consult local building codes and National Electrical Code. (NEC) for special ..... 18000 (5970-22350). Heating Capacity (Min. - Max). Btu/h. N/A ..... Error Messages Displayed Front Panel. S.
Oct 08, 2015 | LG 18000 BTU Dual Zone Mini-Split Heat...
Dryer display blinks on ND OFF WHEN TURNING DIAL or pressing start and does not turn on
I appreciate your post, friend!
From the information you have provided your Electrolux dryer's displays blinks on and off when you turn the dial and it does not start. This sounds like a possible issue with your door latch or control panel. I would recommend for you to check the door strike and door latch to make sure there is no visible damage. If you do not see any damage this could be a wiring issue within your door latch or control panel. This is not a simple DIY job and I would suggest having a professional out to perform an accurate diagnosis. I hope this is helpful information. -Matt
Mar 01, 2015 | Electrolux EIMGD55I Gas Front Load Dryer...
Power Surge Electrolux double oven EI30EW45JS, now producing F11 code, installed new board, how to reset to see if problem is fixed?
Good Morning Jennifer Lynch, thanks for your post!
I see you have replaced the control board on your Electrolux wall oven and it is displaying an "F11" error code. "F11" stands for a shorted keypad, since you have replaced the board I would recommend resetting your wall oven. You can reset your wall oven by flipping the household circuit breaker off for ten minutes. If you need further assistance please feel free to reconnect. I hope this is helpful. -Matt
Oct 13, 2014 | Electrolux EI30EW45JS | 30" Double Wall...
Unlock pattern lock
Unlock Alcatel one touch
Jan 12, 2014 | Air Purifiers
Fresh Air Display on and NO POWER
possibly a bad control finger control board. had a problem just like that and that repaired it.
Mar 27, 2010 | Ecoquest Fresh Air Living Air Purifier
Digital display is locked and will not turn off
Have you held buttons one and two down at the same time, or buttons two and three, or one and three? There is probably a reset sequence that you might give a try. Also look all around it for a rest button. it would be as big as the head of a pin in either black or grey.
Dec 02, 2009 | Air Purifiers
My front control will not function. I have lost my remote. I have serviced, cleaned the unit several times but the unit always comes bak on and tell me it need normal cleaning . I cannot clear the display....
If the front control does not function, you can not clear the perform cleaning message from the display.
Contact the dealer whom you bought the machine he/she should be able to help you. The machine has a 3 year warranty.
Otherwise, contact the manufacturer EcoQuest at 1-800-989-2299 and choose technical assistance from the menu. You will be guided through some trouble shooting and if needed you will get an RMA number so you can send your unit in for repair.
Nov 11, 2009 | Ecoquest Fresh Air Living Air Purifier
Front display controls don't work
Sounds like the same problem I had with mine. I had to call and get an RMA number and they replaced the key pad, lcd display, and main board. This repair was covered under warranty. (Under 3 years old) They had it repaired and returned in about a week.
Sep 05, 2009 | Ecoquest Fresh Air Air Purifier
Air purifier locked in one mode
Hold both fan speeds for 3 seconds to unlock panel.
Dec 10, 2008 | Hunter 30755 Air Purifier
Hunter 19' X 21' Room Air Purifier Air Purifier Logo
50 people viewed this question
Top Hunter Air Purifiers Experts
Are you a Hunter Air Purifier Expert? Answer questions, earn points and help others
