Question about Gateway MX3228 Notebook
Getting the backcover off my gateway laptop
I have removeed all the screws on the back cover but still can't get the cover off. I even took the screws on the hinge off. What else can I look for? the model is a MA2 Gateway told me that it was the same as an MX360
  • Anonymous Dec 30, 2007
    getting the backcover off my gateway laptop problem
  • 89 Answers
There may be screws on each side of the LCD, look closely with a flashlight.
Posted on Jan 11, 2008
Changing light bulb in panasonic microwave oven model nn-sn789s
The whole outer cover has to be removeed, after unplugging unit!!! Take off the special safety screws to remove the cover then the lam is in the air guide mounted to the magnetron.
Sep 09, 2017 | Panasonic Microwave Ovens
Tip
How to remove the hinge cover on a Gateway PA6A, MX8711 1. You will need to is...
1. You will need to is unscrew the two screws that are on the back of ether side of the hinge cover.
2. Next take small screw drivers gentle pry up on the right hing cover. Note this piece is designed to flex a little.
3. Then lift up on the hinge cover slowly and it should release. Note you may need to pop the left side cover with a screw driver.
At this point you should have the hinge cover off
on Mar 24, 2010 | Computers & Internet
Lexmark x6570 hinge is messed up so im getting cover open message
I have a Lexmark X6570 All In One Wi-Fi model. Just had the problem where I went to print and received an error message saying that the cover was open (when it wasn't). I noticed that the back right hand corner had slightly popped out of place for no apparent reason. Tried to push it back into place with no luck.
Here's what happened and how to fix it:
There are two plastic hinges at the back of the 6500 series printers that allow the top cover to open for access to the ink cartridge carriage. The lower ends of the hinges are cylindrical shaped and each contains a very stiff steel spring inside. They are designed to prop the cover of the printer up and hold it open when opened. As the plastic material ages, it may weaken and the tension of the internal spring may break the round end of the hinge off. This causes the printer cover to not fully close (even though it may appear so). There is a switch in the main printer body that detects when the top cover it open (even partially), and the printer won't work in this condition.
To fix this, open the top cover and carefully disconnect the 3 wire harnesses and the ribbon cable that run from the top cover to the base of the printer. Then remove the 'paper jam' hatch cover from the back of the printer. There are two phillips screws on the back panel of the pinter (one is located behind the paper jam hatch cover). Remove these screws (they secure the plastic hinges in place). You should now be able to lift the complete top cover/ scanner table assembly off the rest of the printer. Look for a steel spring about 3 inches long...remove this along with the round base of the hinge which may have broken off and remained down inside the printer. Glue this piece back onto the end of the hinge, but leave the spring out. Now reassemble the printer in the reverse order of disassembly and you should be good to go. Note that the top cover of the printer will not stay propped open on it's own with the spring removed, but this is not really an issue.
I am not sure if new replacement hinges are readily available from Lexmark or other sources.
Oct 05, 2011 | Lexmark X6570 InkJet Printer
Change doors from left to right
Depending on the brand, this "may" be possible. Look for a mounting bracket area on the side you want to change to. Is so, have someone help you, two person job!
Tips Provided by: www.HoustonRefrigeratorRepair.com Brian Gillespie (GOFAR Services, LLC)
Aug 26, 2011 | Refrigerators
Can't close doc cover properly - seems 'broken' at hinge - can I fix this myself?
The left hinge breaks often enough that Brother changed the part number of the part. I hope that means the new part is stronger; I haven't seen one come back for a second repair. Assuming it's the larger, left hinge that's broken (It always is.), you need an LP2403001 HINGE ASSY L. You can find it from a servicing dealer or online, and it's easy to replace.
Look at the back of the machine and find two large phillips screws in holes. They keep the hinge blocks from coming up all the way out of the machine. Remove both of them and lift the top cover up until it's connected only by its cable. It might take a helper to hold the cover, but you need to unscrew the hinge assy. from the top. The three screws are obvious and easy to reach now that the cover is loose. Put the new hinge on, lower the top back down so the hinges drop into their holes, and put those screws back into the holes in back. You're done.
Jul 11, 2010 | Brother MFC 8820D All-In-One Laser Printer
Loose hinge/lid on Dell latitude D410 laptop-lid does not stay upright and falls back flat and no screws to tighten...How can you fix this? Thanks
I took the hinge cover off to look for myself to see if there were in fact some set screws to tighten the monitor up. None were found, no suprise there. While on ebay ordering a new hinge set I noticed that the picture of the new hinges didn;t look the same as what I observed on the laptop. The pin on the right was sticking out on my lapto but in the picture on ebay it was flush.
I used a flat ended phillips tip screwdriver and pushed the pin back in while gently rocking the monitor back and forth. That seemed to solve the problem.
Jan 22, 2010 | Dell Latitude D410 Notebook
Left hinge is broken on HP officejet 6210
Let me know if you find a source for replacements. In the mean time, I kept my unit working by just removing the broken top half of the hinge.
You have to remove 5 screws using a TORX T10 screwdriver. First remove the small plate covering the back of hinge on the outside. Then remove the two vertical screws at the top of the hinge up under the hinge lip. Then open the cover (be careful to hold it in place so as not to damage the three flex connections between the lid and body) and remove the other two screws at the top of the hinge. Remove the broken top half of the hinge and lower the cover back down. Until you find a replacement hinge, you can put a piece of heavy duty tape on the back where the hinge was.
Nov 21, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Hinges for top cover for HP officejet 6210- Q5820A
Sep 06, 2009 | HP Officejet J5780 All-In-One Printer
Fridge door will not stay shut
Glenn,
Easy... The door alignment adjustment is done at the top hinge. Pull up a step-stool, then remove the hinge cover. Under there you'll see three screws, I think they're 5/16". Loosen these (since your door has dropped, they're probably already loose), then lift up on the door handle to align it with the other door... while keeping the door aligned, tighten the hinge screws (and put alot of torque on 'em to keep 'em from loosening in the future). Now just replace the hinge cover and your done!
SG
May 26, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Door does not close properly
the bottom hinge should habe 3 bolts.screwes in take the cover off of the hinge and masure the bolts.screwes have not come loose. if so tightn them back up.
Aug 16, 2008 | GE Profile PSW26P Stainless Steel Side by...
Computers & Internet Logo
114 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
