Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Red light flashing
I have a Philips 37PF7320A/37 and there is no picture and no sound. It clicks on for about half a second then a red light appears goes off and then comes back on 4 times in rapid succession, two second delay, then it repeats. I called Philips and they would tell me what that meant. Any suggestions?
  • 3 more comments
  • chappy2121 Jan 19, 2008
    I have a Philips 37PF7320A/37 and there is no picture and no sound. It clicks on for about half a second then a red light appears goes off and then comes back on 4 times in rapid succession, two second delay, then it repeats. Nothing happens when I enter 062596 info/menu.
  • theskidder Feb 01, 2008
    I have this same problem also and have been told by the repair shop that they need to replace the main power supply board ($180 + labor + $100) kind of an expensive repair for a tv that isn't even 2 years old and easily received less than 10 hours of viewing per week.
  • Sandy Morris
    Sandy Morris Mar 14, 2008
    same problem
  • mayfei Mar 28, 2008
    I have same problems. I would like to have a copy of service manual if it is possible. Thank you.
  • skolvikes Apr 11, 2008
    We had the same problem with our 47" Phillips I powered down and unplugged it and it was fine when I started it up again
I had the same 1-4 blinks with my Philips 37PF7320A/37 after 2.5 years. After contacting Philips customer service through their website, they got back to me within 2 days. They recommend leaving the TV unplugged 30 minutes and try again. I unplugged it overnight. The problem was still there. They, then, gave me phone numbers of local Philips service areas. I dropped off the TV last week. They told me that the problem was a faulty audio board. The cost was $267 (parts and labor).
Posted on Mar 08, 2008
Ctf1800,
I would love to have that service manual. My Philips 37PF7320A died 4 days ago with the typical 1-4 blinking lights. The fuses are fine but I found a 100 ohm 1/4 w resistor that was dead and replaced it, but no change. Now I have looked closer at the "dead" resistor and after the brown-black-brown and there is a poorly applied green band before the gold one, so I'm not sure what I have. I guess I need to get a high resistance tester off eBay.
jcarthur@verizon.net
Posted on Jan 31, 2008
    President:
  • 4,402 Answers
The TV is in some kind of protection mode, the blinking LED show you an error code.
Try pressing 062596 and then press menu button (do these in quick motion, don't let them to time out while keying)...see what happens
Well I think that if you would have a service manual for this set that would help a lot, I can send it to anyone who wants it via email/gmail. Let me know if anyone want one.
I also heard that this problem appeared with some people because the of the burnt fuse in the TV. To fix that it has to be taken to the tech shop. Red light flashing - mecry.gif
And yes I also heard about this issue many times, seems like this TV set is very popular with this kind of problem.
Posted on Dec 06, 2007
Philip tv no picture no sound
I have the model Philips 37PF7320A/37 won't turn on and MOST articles on the Internet say it's the Capacitors capictors capictors..I checked all of them. My tv just blinked red lights, had the clicking sound at first power on, but then goes black. No sound. No picture. Nothing. Just blinking red lights.
MINE WAS RESISTOR no. 3318 , a 100 OHM RESISTOR ON POWER SUPPLY BOARD.
I BOUGHT REPLACEMENT FOR .99 CENTS SOLDER IT, AND EVERYTHING WORKED!!!
THAT WAS ALL IT TOOK.
JUST A SUGGESTION..
1. CHECK FOR BULGING CAPACITORS (90 PERCENT OF THE PROBLEM)
2. THEN CHECK FOR RESISTORS WITH MULTIMETER ( FALLS INTO THE OTHER 10 PERCENT OF THE PROBLEM.)
TELL ME IF THAT HELPS..normanw1@yahoo.com
Oct 30, 2011 | Philips 52PFL7422D/37 TV
Screen goes black but still sound
JUST A SUGGESTION..
Oct 23, 2011 | Philips 37PF7320A 37 in. HD-Ready LCD...
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
May 20, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
42pf7321d/37
relay clicking is a power board failure --- part of the board still works to supply power to the flashing lights--- the lights are related to an error code while in protection mode
Oct 12, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
No picture when television heats up green light is then changes to red after 3-4 minutes
Do the set has sound and how many times are the led is flashing on the front of the set.
Jun 06, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
TV not turning on.
Mine was doing that and I ordered a replacement power supply board for it and now it work. It's fairly easy to replace.
http://www.partstore.com/GetModel.aspx?MfgName=Royal+Philips+Electronics&BrandName=Philips&ModelNumber=37PF7320A37&page=16
Mar 14, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
546 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
