Question about Motorola Talkabout T6200 (14 Channels) 2-Way Radio
QT mode I'm not sure what the QT means on the display of my T6200, but it seems to keep me from being able to receive calls from my friends unless I call them first. How do I disable this feature?
  • Funky1 Nov 28, 2007
    Thanks for the help Neto!
  • 123 Answers
Hello QT means Quiet Tone and is used to keep the radio muted until some call you using QT programmed on their radio.
To remove this feature press the Menu key for 3 seconds until the channel number blinks, then press menu agai until you reach the QT function (QT will Blinks or appear) on the display, then press up/down keys to turn it off, then ptt.
Good Luck
Posted on Nov 27, 2007
Won't Receive, is there a setting I acidently activated?
You want to make sure you radios are on the same channel (big number on the display) and your Interference eliminator code (small number on the display) are the same. Also, make sure when testing that your QT is turned off.
May 04, 2015 | Motorola MR350R Two Way Radio
My Uniden walkie talkie keeps saying L very time I push a button
You've set the keylock feature on your walkie talkie. From the Uniden manual...
ON/OFF Press and hold the call/lock key until the "L" appears. After 1 second, the LCD will return to the channel display. To exit Keylock on mode, press and hold call/lock again. Note: While in keylock on mode, it will still receive transmissions.
Feb 10, 2014 | Uniden GMR-1035-2 2-Way Radio
I cannot set QT filltering on..why?
Here are the instructions from the manual:
To transmit to a radio that has QT noise filtering turned on:
1. Select the same channel and Interference Eliminator Code as the other radio.
2. Press 'musical note' button to send a call tone. This allows your voice to pass through the QT
noise filter on the receiving radio.
3. Press the PTT and speak normally.
Note: If you skip step 2, the beginning of your message may not be heard on
For a 30-second period, starting after the last transmission, all transmissions
received on the selected channel and code will pass through the QT noise filter.
Also, your QT filtering will NOT work if you are in scan mode.
Best regards.
Aug 06, 2011 | Motorola Talkabout T5720 (7 Channels)...
Diff between creative t6200 and t6160
t6200 is old 70 watts
t6160 is new and award winner but 50 watts
May 03, 2010 | Creative Labs Audio Players & Recorders
Kenwood head units show "protect" when there's a problem with the speaker outputs. This might mean a shorted speaker wire, a blown speaker, or an internal defect in the head unit. Once the condition that's causing the "protect" mode is fixed, the CD player should be back in normal mode the next time you turn it on.
If it's staying in "protect", then you'll definitely have to remove the stereo and do some troubleshooting to fix it. Many car audio stores will do system troubleshooting, for a fee. If you want to do it yourself, here's what you need to do:
Pull the Kenwood unit from the dash and disconnect all the speaker wires. Turn it on and see if the "protect" message displays. If it does, the stereo has an internal defect and will need to be serviced. If it doesn't, then turn it off, and re-connect one speaker. Turn it on again and see if it displays "protect".
If it works with a single speaker connected, keep re-connecting the others until you identify the speaker that's causing the problem. There may be a wiring problem or defective speaker in that location.
If it displays "protect" with a single speaker connected, then disconnect that one and try a different one. If all the speakers cause a "protect" mode, then you're probably back to a defective head unit, unless your friend managed to blow all your speakers at once.
Dec 09, 2009 | Kenwood KDC-319 CD Player
If you are talking about a new from the factory radio, there is no way to increase volume. If you are talking about an existing radio which has lost volume over time, short of cleaning the grill of debris, and using a known good battery, there is no fix for low receive audio.
Jun 28, 2009 | Motorola Talkabout T6200 (14 Channels)...
Cannon Fax JX200
The JX200 has four modes of fax receipt - Fax/Tel, Manual, Answering Machine, and Fax Only. The Fax/Tel mode, which appears to be your setting, is meant to let the fax machine automatically switch between fax and voice calls. Documents are received automatically, and the machine rings for voice calls based upon the times that are input in the settings of the machine. It would seem that the best thing to do would be to lengthen the times involved - particularly at step 7 below. I would imagine it is set at a low number - perhaps 10 seconds or less - and needs to be increased to give you sufficient time to answer the call.
Set the mode by pressing [Receive Mode/Resolution]. Every time you press [Receive Mode/Resolution], the mode changes cyclically.
If you set Fax/Tel mode, you can control precisely how the fax handles incoming calls by adjusting the following settings:
• Adjust the time the fax takes to check whether a call is from a fax machine or a telephone (<RING START TIME> setting).
• Adjust the length of time the fax rings when the call is a voice call (<TEL RING TIME> setting).
• Set whether the fax switches to receive mode after the ring time set in <TEL RING TIME> has elapsed (<DEFAULT ACTION> setting).
1. Press [Menu].
2. Use arrows to select <DATA REGISTRATION>, then press [Start/Copy]. The LCD displays <USER SETTINGS>.
3. Use arrows to select <RX SETTINGS>, then press [Start/Copy]. The LCD displays <ECM RX>.
4. Use arrows to select <FAX/TEL AUTO SW>, then press [Start/Copy]. The LCD displays <RING START TIME>.
5. Press [Start/Copy]. The LCD displays <8SEC.>
6. Use the numeric buttons, or arrows to enter the time the fax waits before ringing when it receives a call, then press [Start/Copy] twice.
7. Use the numeric buttons, or arrows to enter the time the fax rings while waiting for someone to pick up the Handset, then press [Start/Copy] twice. The LCD displays <RECEIVE>.
8. Use arrows to select <RECEIVE> or <DISCONNECT>, then press [Start/Copy]. This setting tells the fax what to do if the Handset is not picked up within the specified ring time set in step 6.
9. Press [Stop].
Setting ends and the fax returns to standby mode. The machine will now handle calls as indicated in the settings you input.
It may take a few rounds of going through these steps to get the settings just right for your situation, but it should definitely solve your problem. If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently, and I will gladly help you until we have reached a definitive solution.Thank you for using and rating FixYa!
Jul 13, 2008 | Canon FAX-JX200
Protection on display
disconnect everything from the unit and see if it still does it.
if it does i would check the output transistor (ic).
Jan 25, 2008 | Denon AVR-1506 Receiver
Stoneware insert
I found the solution to the problem for parts.The web site is this is the site for replacements. The part number for the Model # 3745-4.5 qt is #238-180-GR. BUT it is out of stock at this time so I called the 800# and was told that it will be available the middle of January. You can order it on line then or call 1-800-323-9519. Price is $10.00. Hope this helps everyone
Nov 17, 2007 | Rival 3745 4.5-Quart
Motorola Talkabout T6200 (14 Channels) 2-Way Radio Logo
501 people viewed this question
Top Motorola Radio Communications Experts
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
