Question about Tomtom GO 700 GPS Receiver
Tomtom GO 700 suddedenly the display was stopped
My Tomtom GO 700 stppped suddenly and the display was off. when i reset it still it does not work
  • 4,402 Answers
Re: Tomtom GO 700 suddedenly the display was stopped
Connect your TomTom to your computer via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
Copy the Yellow Folders one by one to your PC. Ideally, save all the folders under a new folder that you name.
You may find that the folder ttntools and gns may not be copied. This is o.k. if they aren't.
Format your Tomtom via MY Computer.
Copy the Yellow Folders from the backup you made in STEP 1 back to the TomTom.
Open TomTom Home
Click on Upate Now.
Install the latest update onto your TomTom.
Once installed, switch your TomTom off, then disconnect if from the PC.
Thats it. From now on, make a full backup using TomTom Home prior to any updates.
Also note, that copying all the files will take some time.
Posted on Jan 22, 2008
0 characters
3 Points
My tomtom 700 turns on but just stays on the green screan
Here is some more information for you to follow to guide you step my step. Device displays a white or red cross
If your navigation device displays a cross after you switch it on, it means that the TomTom application is not installed correctly.
Note: It is normal for the navigation device to show a cross while it is connected to the computer.
The solution depends on which TomTom software is used for updating. Check which software your navigation device uses for getting updates.
Devices using MyTomTom for updates
For navigation devices that use MyTomTom, reset your device.
Devices using TomTom HOME for updates
For navigation devices that use TomTom HOME, you can solve this problem by installing the latest application on your navigation device.Here is also a link that will help you more. This will answer all your questions Mike
Oct 05, 2011 | Tomtom GO 700 GPS Receiver
Tomtom 700 dead
After checking around around the web it seems that you are not the only one to get the green screen of death. My suggestion is to hold reset for several seconds, release reset and hold the power button button for 10 seconds. If this doesn't work the only other option is to let the unit sit for several days to let the internal battery completly drain, once drained theirs a good chance it will function normally, this allows any temporary memory to be cleared. Good Luck & hope this helps L8R
Sep 18, 2007 | Tomtom GO 700 GPS Receiver
TomTom 700 GPS, five years old. Suddenly refuses to start
Have you tried leaving it on charge then doing what you want to do ? as the internal battery may be naff
Mar 08, 2010 | Tomtom GO 700 GPS Receiver
Tomtom Go 700 won't turn on
It sounds as if it needs to go to a sat-nav doctor
Jan 30, 2010 | Tomtom GO 700 GPS Receiver
I turn on my tom tom go 700 and the screen appears with a picture of the tom tom in a green box and then it stops and i wont turn of
If your TomTom GO/ONE/RIDER is frozen, won’t turn on or does not behave as it should, it can be fixed by resetting or restarting your TomTom device.
A reset will not delete any data from your device, with the exception of SMS messages on TomTom GO500/700.
  1. Connect your GO/ONE/RIDER to the power charger. If you have a power charger, use it to power your TomTom GO/ONE/RIDER. If you do not have a power charger, make sure that the battery in your TomTom GO/ONE is fully charged.
    Note: You need to charge your GO/ONE for at least 2 hours using the 12-24V cigarette lighter adapter.
  2. Reset your GO/ONE/RIDER. To reset the unit, you simply have to push a straightened paper clip (or something similar) into the RESET hole on the device.
    • On TomTom GO 910/710/510, the RESET hole is located on the bottom of the device.
    • On TomTom GO 700/500/300, the RESET hole is located on the bottom of the device with the word RESET right next to it.
    • On TomTom ONE, the RESET hole is located on the bottom of the device, with the word RESET right next to it (just below the SD card slot).
    • On TomTom RIDER, the RESET hole is on the bottom of the device, behind the SD card door. When opening the SD card door you will see the RESET hole on the left, right underneath the SD card slot.
  3. Your TomTom GO/ONE/RIDER is now reset. Finally, press and hold the power button for 2 seconds.
Dec 16, 2009 | Tomtom GO 700 GPS Receiver
Touchscreen not working
You may be able to go the TomTom website and download the last update programming. If the problem is software this should fix it.
Jun 22, 2009 | Tomtom ONE 3rd Edition GPS
TomTom go 700 flashing cross at start up
U need just one original file from zour tomtom and that is ttgo.bif so keep that file safe and copy everything from working unit (even better with patched system) to your unit, !!!!! dont use TomTom Home !!!! just through drive (if its not there cant help), just possible that u need now maps activated for your unit, u can find info how to this anywhere,
Jan 25, 2009 | Tomtom GO 700 GPS Receiver
Tomtom 700 will not fully load
On the bottom of the TomTom there is a tiny hole that you stick a small paper clip into. This is a reset button. Its almost not visable you really have to look for it. I have the same problem but I hit the reset and it fixed the problem. This reset won't change or hurt any of your settings it just resets the hard drive.
Feb 13, 2008 | Tomtom GO 700 GPS Receiver
Tomtom 700 in a standby mode
Hi Juanin, just posted this for a near identical problem with a Tomtom 700; When you get this kind of problem with a Tomtom device always start with the memory card, so: 1: remove the card, clean the contacts and if you have an air duster (available from any good hardware store/electronics store) clean the card slot, then reinsert it. 2: make sure the card is readable on your PC to ensure it doesn't have a problem. if this doesn't help then 3: format the card and reinstall the maps & software on to it. 4: make sure the card is reinserted correctly. Next is the battery, leave the device switched on until the battery runs out, switch it on again and it should stay on for a moment then switch its self back off, repeat this until it will not switch on anymore and then charge it for at-least 16 hours before trying it again, this will re-calibrate the battery. Diagnosing a problem is a process and this is just the start of it, don't be disheartened if this doesn't help, just message back with the results.
Apr 18, 2007 | Tomtom GO 700 GPS Receiver
Tomtom GO 700 GPS Receiver Logo
183 people viewed this question
Top Tomtom GPS Devices Experts
Martin Murray
Are you a Tomtom GPS Device Expert? Answer questions, earn points and help others
