Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Freezer door opens just a tiny bit when i shut the fridge side anybody know how to fix this
  • 26 Answers
I was the guest who wrote about the cracked cam plastic on the freezer door hinge above. I found that the replacement hinge part was $50 and said no way. I unscrews the bolt and allowed the cracked parts to come together again and use JB Weld to make sure it all will stay in place. Let it cure for a few hours and then wound the hinge back into alignment carefully with the holes and tightened it up again. Now when my family slams the right to the left door opens a bit but closes again like it should. It used to stay open. The hinge is designed to pull the door closed when it is almost closed but not work against you when it is open wide.
If you want a picture of how a glued it let me know. HarryF
Posted on Dec 22, 2007
I have a Fridgidare side by side and just found out exactly why mine started doing this. There is a spring that is supposed to help keep it closed that works with the top left hinge and the plastic that connects the spring to the hinge and the door has fractured. It is under the decorative cover. They want 50 bucks for the replacement assembly. I am going to try to glue my parts back together tomorrow with JB weld. There is an opening between the left and the right and this is where the pressure normally can push the left door open when you shut the right door open. There are other things that could be wrong but this might be something you can inspect for easily by standing on a chair and taking off the cover. If you have the same cracked plastic under the hinge then I can tell you if my solution works for me.
Posted on Dec 11, 2007
  • 213 Answers
To be honest with you, close the door more gently. there are air vents between the frig and the freezer, when you close the frig door its forcing air into the freezer which in turn forces the door open some. the air has to get out so thats what it does. i hear this complaint alot.
Posted on Nov 27, 2007
Samsung Fridge Freezer Door Handle Came Off - No screws is it vacuum based.
The screws are in the holes on the side. You will need an Allen wrench to tighten them
Sep 29, 2015 | Samsung RSA1SHPN American Platinum Inox...
GE refrigerator model #LTC19340ST freezer door not sealing
That is a common problem with over-under units. You can clean or replace the door seal or, tilt the unit back a TINY bit. The door pops open because there is a common airway from the freezer to the fridge. When the fridge door shuts too fast, it pushes a lot of air into the unit. It needs to go somewhere so, it pops the freezer door open. If you shut the freezer hard enough, you will be able to pop the fridge door open.
Jan 20, 2013 | LG LTC19340ST 19.0 cu. ft. Top Freezer...
My GE TFX22Z has served me well over the years. Recently, I noticed that the refrigerator side door has lowered about 3/4 of an inch when compared to the freezer side door. In other words, they no longer...
from the description given I came up with;
possibly the screws are lose on the top door hinge, the top or bottom hinge is worn, the door is warped or damaged.
Aug 21, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a kenmore top freezer refrigerator model 253 about 1 1/2 years old. The fridge door sticks at the bottom of the door and the bottom of the fridge inside. There are scratches on the fridge bottom...
i had the problem my self :)
you need to take the freezer door out then the fridg door and add small ring like 1mm to the hinges of the fridg door poot all back and see if it rais the door a bit....
what i did is on the top of the freezer there is option to move the door from side to side ...the plastic that go into the freezer body its a ring with long tube.. i cut the tube and use that plastic :) good luck
Jan 03, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Zanussi ZFC 45/30 SS is hot at front between the doors..
This is normal. This is a defroster to keep moisture from condensation from freezing the doors shut.
Jun 30, 2009 | Refrigerators
Fridge not cooling
hi there.
welcome to fixya.
initially try to defrost the ref and clean it.
Feb 26, 2009 | Amana ASB 2623 Side by Side Refrigerator
Vegetables in crispe are freezing
Check for blockage of the damper door which regulates airflow from the freezer into the fridge. It might have gotten some ice buildup there while the freezer door was open.
Jan 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Maytag MSB2354DRW
If door does not close at all, even if you push you need to replace the door pickoff.
If door stick a bit but does not stay closed you have to replace the door seal.
Here you find all diagrams for your appliance
See also here, there is seal and pickoff for the freezer, you can buy them from this site.
Aug 26, 2008 | Refrigerators
Freezer door won't stay shut
Could be the air pressure created from shutting the refer door is popping open the other one. There are are channels between the two so cool air from the freezer gets to the refer compartment. Try this as a test... s l o w l y close the refer door and see if that keeps the other door from popping open. If that works then it's likely an air channel is frozen up somewhere and you may need to turn the unit off for a day or so to let it thaw out. Moisture from leaking door seals, or doors that were left slightly open overnight can be sucked in and freeze up the air channels. I don't know if you are sort of slamming the door shut or not but the doors need to be shut slowly due to how air tight the new refers are.
Nov 10, 2006 | Frigidaire FRU17G4JW Refrigerator
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
128 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
