Will not respond to my fingers -touch screen.use mouse& keyboard,works but cumbersome,fix touch screen
SOURCE: touch screen not working
there is a problem with dust and dirt getting between the casing and touch screen. get an old toothbrush an give it a brush all the way around that should cure it
SOURCE: keyboard and mouse inoperative
its the battery. disconnect the battery, plusg it up and start you computer. the mouse and keyboard should work fine.
SOURCE: Touch screen not working...
Hi guys,
i post this solution for those wo will be in the same situation in th next future. I had the same problem with my HTC TyTN (Herm 200). The touch-screen was simply not working. I read many 'solutions' on the net but none worked. I did not try the hard-reset because i was convinced this is not a software problem, and resetting the WM5 will not help. So i brushed the corners, looked for small particles which were pressing on the cover of the touch screen. but it did not work. finally i found one post (i don't remember where exactly) where a guy used a credit card and pushed it all around the touch-screen under the metal case (a bit harder). i tried it and it worked. i pressed harder especially in the lower part, above the buttons. and simply it worked ! no problem since then.
SOURCE: Touch screen is not responding on my x1
ur TOUCH PANEL IS FAULTY kindly go for warranty claim or tell me i can give u link for the out of warranty replacements
SOURCE: The Touch screen on my Sony HDR-SR12 stopped
A flexible board (seems like a strip in pale yellow color) worn out and it needs replacement.
The detail of part is given below:
187480611 PWB, FP-807 FLEXIBLE
This part number needs replacement.
Thanks
