Perfecta won't pump water, the pump comes on but doesn't push water
    Top Expert:
  • Washing Mach... Master
  • 60,649 Answers
Why would the jacuzzi perfecta toilet handle comes off and now won't fill, just keeps running
Handle retaining nut either came loose or broke off. Check the flapper valve, if its not completely closed water will keep running out, and fill valve will stay open trying to fill the tank.
Aug 30, 2014 | Jacuzzi Perfecta White Round 2-Piece...
My Little Giant OPWG-71 after six months of trouble free use has stopped pumping my pond. It comes on, with no obstructions allows water to be pushed through it but won't pump. And yes even when
Hi don-eyre300.
Double check your suction side of the pump for obstructions if not then it is time to replace your pump...sounds like the impeller and housing is worn beyond repair.
Bud
Apr 20, 2013 | Garden
My lg intellowasher wf t8501tp won't go into a
Check the pressure switch and hose. Pressure switch is what turns the pump on and off. Trouble is usually in the hose so check it first. Look for the hose to be unattached or clogged.
Jan 13, 2013 | Washing Machines
Delonghi Perfecta won't froth milk or allow hot water to come out from waterspout
Aug 20, 2012 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Tub not draining in washer
If it won't drain, something is plugging the drain system. Start from the hose end. Make sure the hose is open at the end. Try lowering the hose to almost floor level. Make sure you have a pail handy. The water from the tub will be higher than the hose end and the blockage might come squirting out. Put the hose back into the sink or drain pipe it was in.
If water comes out of the hose, but the washer still doesn't "drain," turn it on to a point in the cycle where it should be draining (spin cycle). Listen to hear if the pump is running. If it isn't, there might be something caught in the pump, the pump impellers (that push the water through the pump) might be stuck or broken. This will require a service person.
A third thing you can try if you feel really handy, is to figure out how to open the top of the washer. (Do this with the washer unplugged.) This is often a couple of spring clips near the front edge. Push in on these clips with a putty knife or something else thin, while lifting the top. Once you get it open, scoop out the water between the tubs if you want to. Other wise reach in between the tubs and find the drain hole where the water leaves the outer tub. This happened to me once and there was a child's sock in the hole. Pull out the blockage, reassemble the washer, plug it in and see if the pump check works.
Like I said, it's the outer tub, the pump or the drain hose usually. Good luck.
Jun 14, 2012 | Maytag Washing Machines
Why is the pumpo not pumpin water to tile saw
Take the hose off the pump, put it in water and turn it on. If it moves water, look for a blockage in the line and nozzles leading up to the blade. If it doesn't move water there may be a small peice of tile or enough of the tile 'mud' in the impeller that it can't spin. Depending on what type of pump you have, if you can, take the cover off the impeller and remove anything that would keep it from spinning. If it does not come apart you may have to force water through it backwards in an attempt to flush out whatever may be in there. If it won't come out sometimes giving the pump a firm wack on the side will knock things loose.
Dec 31, 2011 | Saws
I shut off my pump yesterday and water shot out of the skimmer. when i turned the pump on it wouldn't work, the pump basket has water in it but it isn't pumping anything, no water coming out of...
I suspect you had air trapped in the filter. When the pump shut down, the compressed air in the filter pushed back, turned the pump backwards, and unscrewed the impeller off the motor shaft. This particular pump doesn't use an impeller screw which prevents this from happening. You will have to pull the pump apart to see if this is the cause. I have seen this happen many times.
Sep 15, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
Machine stopped mid cycle, won't spin or did not drain, no error code displayed, tried unplugged and restart. no luck
next time send the model number,open the door,look around the opening where you put the clothes in and you'll see a tag with the model and serial numbers,it has to drain first before it will spin,check the pump,get a shop vac and vac out all the water,remove the bottom panel and look at the pump,if the middle of the pump can be removed turn it counter clockwise slowly until the water starts to leak out and vac it up until all the water is out,then remove the middle part of the pump and clean it out,if the middle doesn't come out remove the hoses and check the pump to see if anything is in it and check the hoses,after you remove any debries you find fill it with some water and put it into a drain to see if the water drains,if it doesn't you can check the pump again to make sure you cleaned everything out,stick your finger in and fell around the impellar to make sure it's clear,if it's clear replace the pump.usually an error code will come up but if it fills and agitiates but won't drain i would start at the pump.hope this helps.
Aug 15, 2011 | Maytag EPICz 3.7 Cu. Ft.
I have a Zoeller Water Ridd'r II Model 48 Sump pump. The pump comes on okay, but will nit shutoff. The float is not impededd, it's just laying on the bottom of the sump. Is this a defective...
If I undrestand your description, when the resevoir is empty, the float lays on the bottom of the resevoir but, the pump doesn't shut off, after water is pumped out? You have to look at this as opposite of a toilet tank filling with water. In a toilet, the water rises and the foat turn the water flow off. In a sump the water will rise, and the float will turnthe pump on until the resevoir is empty, then it will open the system and turn off the pump. If the float doesn't rise, the resevoir will overflow and the pump won't come on at all. If the float rises and the pump comes on but, the float does "not" drop, the pump will continue to run after the resevoir is empty.
http://www.zoellerpumps.com/ProductByCategory.aspx?CategoryID=3
This is Zoellers link. I don't see your pump but they do have a support link. If the float rises and falls with the height of the water, turns pump on, then drops "all the way" and pump doesn't turn off, the switch is bad not the float. Make sure there is nothing in the way of the float dropping to it's full down position.
Jul 03, 2011 | Home
Kenmore dishwasher won't drain. Can hear motor trying to cycle but it sounds like it's locked.
Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Hope it helps...
Jun 23, 2011 | Dishwashers
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
paul
paul
