Question about Creative Labs Zen Micro MP3 Player
Creative zen micro
I have a creative zen micro that i bought about two years ago and the battery just recently drained all the way and the player won't reboot. I figured the battery was dead, so I plugged it in and all I got was the creative logo screen then a blank screen. The backlight stayed on for a little bit, but shut off after a minute or two.
Is it the battery?
or the hard drive?
    Uploaded 30 video answers.
    Uploaded 5 video answers.
  • 72 Answers
Re: creative zen micro
Same problem with my first Zen. It's the battery. Now I keep a couple for spare batteries charged and ready to go. It's not the hard drive unless you've really whacked your Zen hard into a solid object.
Posted on Apr 26, 2008
  • 106 Answers
Re: creative zen micro - Creative Labs Zen Micro MP3 Player MP3 & Digital Media Players
Battery :D
Posted on Nov 27, 2007
0 characters
3 Points
My brother's MP3 player is messed up. When you boot it, it automatically goes to recovery mode. Here, it tells you the firmware and gives me a couple options: Recovery Mode Creative Zen Micro...
Couple things to try.
Let the battery drain completely, then do a full charge and try again.
When turning it on, don't hold the ON slide, just slide it to ON then let it go. Holding it will send it into recovery and reset mode.
Jan 25, 2011 | Creative Labs Zen Micro MP3 Player
My CREATIVE ZEN Micro doesn't play any media after i accidentally dropped it. Is there hope?
1. Ensure that the player is turned off
2. Remove the battery.
3. Move and hold the Power button to the Power On position and re-insert
the battery to the Zen Micro. Hold the Power button until the rescue
mode appears.
4. After 2-3 seconds the rescue menu will be displayed.
At this point the battery can safely be replaced and maintenance options
5. Four options will be displayed on the LCD screen:
? Clean Up - (To rearrange your stored data)
? Format All - (To format and remove all data)
? Reload Firmware - (Reloads your player's operating system - Do not
choose this option unless you have downloaded a firmware update from the
Creative website)
? Reboot - (Restarts your Player)
6. Select the Clean Up and then the Reboot option.
Now, please try turning off the player.
Jun 07, 2010 | Creative Labs Zen Micro MP3 Player
When its pluged in it cuts on its showing that its
if you have bought the player an year ago and used it continuously, you battery must have worn out...please take your device to an authorized service center and get the battery replaced!!!!
Oct 24, 2009 | Creative Labs Zen Micro MP3 Player
I can't upload musics to my mp3 or even charge it.
Creatives web site. Just follow the MP3 Player link and find your model.
Jul 01, 2009 | Creative Labs Zen Micro MP3 Player
when your mp3 player keeps turning of that means that there is no more juice in the battery and that it is time to go pick up a new battery, also if your mp3 player is not charged and it wont hold a charge you can try another USB cord!
Mar 24, 2008 | Creative Labs Zen Micro MP3 Player
Creative Zen Micro
vista is not supported . you can try this:
you should not have had to install anything for the Zen to work on Vista. If you have installed any Creative software, remove it. Reboot, plug your player in, open Device Manager, and remove the device that shows up representing your player (completely uninstall it). Reboot again, and plug in your player. It should be recognized now.
If that still doesn't work, then boot your player into Recovery Mode, and perform both a Disk Cleanup and a Reformat. Reboot the player and try plugging it in again.
if it still doesn't try another computer and upload the latest firmware to it and then try it on your pc after firmware is loade
Feb 09, 2008 | Creative Labs Zen Micro MP3 Player
Is it my battery or bad system?
I had the same problem a few years ago. Creative said that it was due to connecting the player to a lead that was plugged in to a socket which was already turned on. They recommended pluging in the player, then turning on the socket. They also had downloadable firmware to fix this problem.
Good luck.
John Parr
Jan 06, 2008 | Creative Labs Zen Micro MP3 Player
Creative Zen
Unfortunately, your hard drive is damaged. You should buy another player, since microdrives are so expensive.
Sep 18, 2007 | Creative Labs Zen Micro MP3 Player
Zen Microphoto frozen..
Solution ID # 4794 from creative site ZEN Micro and ZEN MicroPhoto 1. Make sure that the battery is charged. 2. Detach the ZEN Micro or MicroPhoto from the PC, and ensure that it is turned off. 3. Remove the battery. 4. Move and hold the Power button to the Power On position and re-insert the battery to the ZEN Micro or MicroPhoto. Hold the Power button until the Recovery Mode appears. The following options will be displayed: -Clean Up : Scans the player and removes invalid links from its music library.Does not affect music files themselves. -Format (All):Caution! Erases all content!Save a copy of your player's content before formatting. -Reload OS/ Firmware : Caution! Erases your player's firmware. DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install. Reboot Reboots the device.
Jul 29, 2007 | Creative Labs Zen MicroPhoto MP3 Player
Creative Labs Zen Micro MP3 Player Logo
192 people viewed this question
Top Creative Labs MP3 & Digital Media Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a Creative Labs MP3 and Digital Media Player Expert? Answer questions, earn points and help others
