Question about LaCie Computers & Internet
LaCie d2 CD/DVD writer firewired to a 2007 iMac has stopped recognising there's a DVD in the drive.
I can see the d2 using Disk Utility in the Mac's Applications but it says there's no media loaded when there is. Is this a hardware problem with the d2 itself or a communication problem between the Mac and the writer?
  • 42 Answers
SOURCE: help
Take it in, controller may have malf'ed when it got unplugged, been known to happen.
Posted on Dec 09, 2007
SOURCE: lacie d2 external drive
I support the comments of (fire sine) I have the d2 120gb Lacie and it was down for two years.  I took it to my apple guys and they said that I needed to go to a data recovery service which would cost a gang of money.  Come to find out, when I decided to update my internal hard drive on my Mac Pro, I had to buy a SATA, IDE, USB 2.0 adapter to back up the internal and transfer to the new internal. Long story short, something said, Hey try and open the Lacie and bypass the board in the enclosure and connect directly to the Western Digital drive inside.  AND WHALA! I got my info, so all I need is a new enclosure.
Posted on Jan 08, 2008
  • 77 Answers
SOURCE: LaCie d2 Quadra drive... not showing up on PC after working on a MAC
You need to make sure the drive is formatted for the PC. The Mac will read and write to a FAT32 partition, but the PC cannot see a Mac formatted drive as you have seen.
The only problem is that there is a 32Gb limit per partition for FAT32 drives.
It's not ideal but it's the best you can do easily.
Posted on Jan 13, 2008
exspert
  • 55 Answers
SOURCE: cd dvd writer not working
ok " I would get a dvd/cd cleaner disk, has a tiny brush on it that cleans the lens in your drive.
Posted on Jan 27, 2008
  • 1019 Answers
SOURCE: CD/DVD Writer drive not detected
is it showing As Drive D:- Or E:- In My Computer ?
Mike @ Compurepair.
Posted on Feb 22, 2008
My Macbook Pro running Mountain Lion does not recognise My Lacie D2 Quadra V2 (301442a) after upgrade from Snow leopard
Here's a good start.
Plug your Lacie drive into someone else Mac or PC using MacDrive Pro and see if it shows up.
Dec 02, 2017 | Computers & Internet
Lacie d2 Quadra Ejects Itself
I've had issues with the lacie mini power supply before. I can cause some wierd issues. Unfortunately, it isn't the cheapest thing to replace but that's probably the best place to look first.
Oct 16, 2012 | LaCie 1TB D2 Quadra eSATA/USB 2.0/FireWire...
Firewire connector doesn't match
It sounds like you may have one of the newest MBPs that doesn't have a firewire port. If that is the case, it is still possible to connect firewire peripherals through a Thunderbolt to Firewire adapter cable.
Aug 06, 2012 | LaCie Super-writemaster Dvd Multi Recorder...
External Super Writemast DVD drive is connected via Firewire. The S.M.A.R.T. status says "Not Supported" on my imac os 10.6.6
The S.M.A.R.T. status is used to communicate information about a Hard Disk Drive.
Since your product is a DVD drive, it not does send S.M.A.R.T. information so MAC list it as "Not Supported" for that feature.
It is normal with a DVD drive and you have nothing to worry about.
Regards,
Jan 14, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Just got an lg ge20 not working on mac
I wish I could tell you that your Mac is compatible with the LG GE20 20X DVD Burner but unfortunately it is not.
Here are the system requirements for this burner
LG GE20 20X DVD Burner Technical Specifications
The CD included is not the only item that is not compatible with the Mac, it is also the DVD burner itself. It is only windows compatible I'm afraid.
However, I do know that the Apple.com online store, has a comparable DVD+RW burner, the
LaCie 22x d2 DVD+RW with LightScribe
which will work with your iMac.
This is a genuine incompatibility issue.
If you had an Intel iMac, there actually is a workaround process where virtual machine software, like VMWare Fusion or Parallels, could be installed, with a version of Windows XP, Vista, or 7, display as a 2nd terminal within a Mac OS X desktop.
What's makes this effective, is that the LG GE20 could work with a windows virtual machine and because software like VMWare for example, can share devices, including optical CD/DVD drives, the Mac could share that drive with the windows virtual machine.
But since you do not have an Intel iMac, unless I am reading the description of your Mac computer(Apple iMAC Mac Notebook) incorrectly, the LaCie burner information, I provided above, would be the best option for your model of iMac.
Again, if I have described your model of Mac incorrectly let me know and I will be glad to assist further.
Regards,
-Mactechtrainer
Feb 01, 2010 | Apple iMac Notebook
LaCie Case and new IDE drive not communicating with my MAC
It sounds like you have power but the communication method is not working. I assume it is a usb drive, (or it is firewire 400, firewire 800? How do you have it hooked up to the Mac? If you are using usb, I would try using a different usb cable. Same for firewire. You also might read your manual on the Lite-On drive is see if you have to throw some dip switch make it a master or slave setting on IDE.
Jan 23, 2018 | LaCie d2 DVD-RW Burner
Macintosh computer not recognizing the LaCie external hard drive
1. If you have another firewire device test this device with the same firewire cord you are currently useing for the LaCie. (if there is no reasponse form the other device then it is the cord it's self) If not then 2. Check the Leads on the back of the LaCie where the firewire plugs in if the copper looks tarnished use a ear swab dipped in Lime Away or CLR to clean it then wait for it to dry and try the cord again. 3. if these physical connections are in good connection with each other and the firewire in port on your computer and on the LaCie are good then. Run a "Permissions" verify and repair through the disk utility program on your Mac with the LaCie turned on and plugged in.
FINALLY if none of these options repair the LaCie you may have to open the LaCie up and check to make sure the soldering from the firewire to the chip set is still in tact. I hope this helps Happy Macing.
Mar 28, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Can't accept Quadra 500 on my owerMac G5 Quad
Scrap LAcie!! Sounds like in this case, it may have been jostled around during shipping. None the less, Lacie drives are nothing more than bricks waiting to fail. Go Western Digital, but if oyu can, zip straight for Seagates!!!! Professional grade!! ALways check the cables, the ones that come with them are bottom bin cables, made by little singapore children with no fingers..... Invest in a good cables...a drive is only as good as the weakest datalink.
Cash on the warranty!!!
Keep me posted.
Dec 13, 2007 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Computers & Internet Logo
23 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
