Question about HP Computers & Internet
Computer do not booting only 5V AUX LED CR1 blinking
Hello, I have a 404794 MOBO of an HP DC5700 computer, the issue is that the computer does not turn on, no booting, no LEDs, no Fans after pushing the power button. Only the 5V AUX CR1 LED is blinking all the time. Power supply is working fine when you test it alone. Does anyone have an idea what can be wrong. I am afraid some kind of electrostatic discharge could cause some damage, because it was working and ON but when my baby touch the back of the chassis the computer shutdown. Thanks in advance
    Habit-Forming:
    New Friend:
  • 7 Answers
1. This is a quite old motherboard. After years of usage the capacitors next to the processor might pop out and no longer work, therefore the processor does not get the required power. Check these capacitors. I added a photo of faulty capacitors. Check them. The top surface of them has to be flat without any electrolite(brown stuff) leaked out. This is a hard to fix issue because you need to solder them out and replace them with capacitors of the same type.
2. Make sure the button is working. It could have gone wrong too. You can test it by disconnecting the connector of the button (it is connected to two small pins) and connect the pins manually with some metal object or the end of a screwdriver for a moment. If the pc turns off the button is faulty.
3. If these suggestions wont help some people reported that putting the whole motherboard in the oven for a specific time on a given temperature can fix things.
Computer do not booting only 5V AUX LED CR1 blinki - 3_15_2019_7_19_30_pm.jpg
Posted on Mar 15, 2019
joecoolvette
  • 5660 Answers
SOURCE: Hello, I have a Gateway model GT5662, stock setup - Will not boot
Usually, if it's a motherboard that has a failed component on it, you will see failed Electrolytic Capacitors. The small aluminum 'Cans' on the motherboard.
Note*
The Electrolytic Capacitors that surround the Processor, should have special attention payed to them. These capacitors are Voltage Regulators for the Processor. If even One is bad, the Processor won't receive the correct amount of voltage, and won't turn on.
Most of the time Electrolytic Capacitors will show visual signs of failure.
There are rare occasions that they do not.
In this case the Electrolytic Paste has dried up in the capacitor, and no outside visual signs will be shown.
I realize that it may look like I'm typing a foreign language here.
This is more information about Visual Signs of Capacitor Failure,
http://www.capacitorlab.com/visible-failures/index.htm
The Gateway GT5662 Desktop PC uses an ECS MCP61PM-GM motherboard.
As you can see in the photo below, it does use Electrolytic Capacitors, and not solid capacitors,
http://www.skyline-eng.com/index.cfm?fuseaction=product.display&Product_ID=6470
ECS motherboards are not reliable, and known for capacitor issues.
HOWEVER,
I believe your problem directly stems from a bad power supply.
Power supply has a Weak Voltage Power Rail.
Reasoning for this diagnoses?
Computer tech who has seen this problem at my shop over the years, occur more times than you can shake a stick at.
Would rate it at 70 percent of the reason for computer failure.
It is also rated at that percentage all over the internet.
The diagnoses you stated is correct for this type of problem.
Weak voltage power rail:
Your Gateway GT5662 can come with one of three power supply's.
1) Bestec - Part Number - 6506056R300 - 300 Watt
2) HiPro - P/N - 6506055R300 - 300 Watt
3) Delta - P/N - 6506054R300 - 300 Watt
(P/N's are Gateway numbers)
These are cheap generic power supply's. They have cheap components inside.
Cheap Electrolytic Capacitors,
Gauge of wiring is too small,
Rectifier Bridge is of low quality,
and the list goes on.
When you pick your power supply up, you can feel how light it is in weight.
You can literally feel the difference in weight, when you pick up a decent power supply in comparison.
These power supply's have three main voltage rails. (Very common)
1) The 3.3 Volt power rail
2) The 5 Volt power rail
3) The 12 Volt power rail
The Electrolytic Capacitors used inside the PSU, (Power Supply Unit), are used in the Input stage, and the Output stage.
Used for the incoming 120 volts AC from your house, in the Input stage.
Used for the outgoing DC Volts that have been converted, inside the power supply in the Output stage.
[A computer power supply converts AC electricity, into DC electricity for the computer.
3.3 Volts, 5 Volts, and 12 Volts are DC.
Alternating Current and Direct Current. A flashlight battery is an example of stored DC]
With a weak voltage rail there isn't enough power to turn on the processor.
1) ALL the lights use less than 1 Watt
2) EACH fan uses 2 to 3 Watts
3) A typical Processor uses 55 to 125 WATTS.
This is why the Power On light comes on, the fans spin a few times, but no Operating System comes up.
(Windows XP is an example of an operating system)
No video signal from the computer, you get a No Signal on your monitor. No video signal because the computer isn't working.
When you press the Power On button, you are making a temporary circuit to the power supply, through the motherboard.
You are making a circuit that delivers 5 volts to the power supply. Just for a few seconds. Soft Power On.
(That's why the Power On switch is spring loaded)
The power supply comes on, and the BIOS program is activated.
(From the BIOS chip on the motherboard)
BIOS checks to see what devices are installed, does a Ram Memory count, turns the Processor on, and hands the computer over to the Operating System.
You don't even have enough power to activate BIOS now.
Why does a power supply fail?
Usually two reasons, or a combination of both.
1) Computer is dirty inside, and so is the power supply.
Computers should be cleaned inside, ( And the power supply), on a regular basis with a can of compressed air for computers.
(Computer unplugged from power)
2) Cheap components used in a cheap quality power supply.
Solution?
Replace the power supply, also insure that the computer is clean inside before doing so.
Do you have another power supply that is compatible, and is known to be good to use for a test?
(300 Watt ATX style with at least the same power cables)
Some of us have old computers around, that we can 'Borrow' one for a test, then put it back.
This would prove my diagnoses to be correct, and you will know what to buy.
Regards,
joecoolvette
WARNING!
This is NOT an invite to open your power supply.
The Electrolytic Capacitors used inside can hold a charge for Weeks, sometimes Months!
If your fingers touch the wrong spot, (Terminals on capacitor, or circuit one, or more are in), YOU could receive the charge!
Shock is Bad to Fatal!
Posted on Jan 08, 2010
  • 260 Answers
SOURCE: Flashing Green Light on Power Supply
get yourself a themaltake ps
make sure you remove the old one and take it with you to the shop or get the shop to do it for you if you dont have the expertise yourself.
hope this helps
Posted on Jan 01, 2009
  • 2427 Answers
SOURCE: power LED on but no boot up
it could be your power switch, veriy that it isnt the power supply by
1.) un-plug it from the main board
2.) look at the main board connector(one coming of the power supply)
3.) you should see green wire and next to it a black one
4.) using a paper clip bridge the too wires
5.) if it works proceed to net step if not get a new power supply
to check case switch and board switch
1.) plug in power supply to main board
2.) look at the pins where the power button connects to
3.) using a metal object (blade screw driver) bridge the pins
if the board should start up>
then its your power button on the case that is bad, you can try to repair it, chage it or buy a new case,
if it doesnt work.
1.) ensure that jcms(jumper to flash the bios) is set correctly
2.) unjack each drive one at a time to see if any is causing stalling
3.) get a new main board
Posted on Jan 02, 2008
Its the Mother Board..I had the same problem and had to have a new MB put in
Posted on Dec 04, 2007
SOURCE: Hipro HP-d3057f3r computer power supply broken?
I have the same problem. I found this:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bph06788&product=12455#bph06788_section_2
  • Replace the side panel, plug in the power cord, and examine the light on the back of the power supply:
  • If the LED is on solid and is not flashing, the power supply is probably good and the problem is most likely caused by a defective component (processor, memory, PCI card) or a defective motherboard. Have the computer serviced, or remove the components and replace them, one at a time, to find and replace the defective component.
  • Posted on May 18, 2010
    Have a 2005 a1250n Hp computer with Hp ver XP SP3 OS installed. MOBO failed. Can it be replaced by same p/n 5188 1936 using current all ready loaded XP OS. Will GUID be a problem?
    If you can get the exact mobo you may replace it. No driver issue will raise. You can also buy a new mobo with same chipset and replace it. Same chipset mobo will require to install Sound, ethernet and vga drivers
    Apr 12, 2016 | HP Computers & Internet
    How do i fix a problem of green power led continuously blinking in Hp compaq nc6320 laptop even when the battery is removed and the motherboard is outside the case?
    HP Notebook PCs - Troubleshooting LED Blink Codes or ...
    h20564.www2.hp.com/hpsc/doc/public/display?...na...
    Hewlett?PackardHP Notebook PCs - Troubleshooting LED Blink Codes or Beep Codes During Startup or Boot ... HP Pavilion and Compaq Presario notebook computers built in 2009 or later use blinking LEDS to identify ... Press the power button to turn on the computer, and look for blinking LED lights on the keyboard. ... Continuous blink.Missing: green ‎nc6320
    HP Notebook PCs - Computer Does Not Start and Emits an ...
    support.hp.com/us-en/document/c01732674
    This document pertains to HP and Compaq notebook computers. .... light next to thepower socket or the light on the AC power adapter and note its condition: off, blinking, or constantly on. ... Battery power LED off, and Caps Lock/Num Lock off.Missing: green ‎nc6320
    HP 6735s won't boot, power LED blinks 7 times - HP ...
    Feb 03, 2016 | HP Computers & Internet
    Bootmgr is missing/dc5700
    What do you mean by installing driver after format?
    Format is a command that destroy all the data on your harddisk and creates new file system. This means that if you have formated your harddisk it is more or less probable that you don't have operating system anymore, so there is nothing to boot.
    I need more information to help you.
    May 28, 2012 | HP Compaq dc5700 Microtower - RU002UTABA...
    Usb powered aoc monitor is blinking
    Active USB cables boost the USB signal not the 5v power lines. After about 6 feet the 5v power lines will only provide 4-4.5 volts and this is not enough to power the monitor. For this to work you will you will need to also use a powered USB hub at the remote end by the monitor. The USB hub will supply the power and the monitor needs and the active USB cable will provide the signal.
    May 03, 2012 | AOC e1649Fwu 16" LED LCD Monitor - 16:9 -...
    I can't get my computer to boot up
    If the led is flashing then you can unplug the 20 pin or 24 pin depending on model and led stops flashing and becomes bright then most likely psu is ok and you have a mobo issue. Had 2 pavilions do this now and rather than replace mobo i fiddle with psu cord and mobo connector. If you can get the cpu fan to click and briefly spin you got connection and can power up unit. This takes a great deal of patience unless you just get lucky. Used to work every timefor me until i got smart and pavilions are all on battery back ups now.
    Oh ya btw this issue once it happens will generally happen every time you lose power hence the back ups good luck if if there is enuff demand for technique demonstration perhaps I'll make a utube video
    Feb 16, 2011 | HP Pavilion ze4300 Notebook
    I have a HP DV2000 model laptop that does not boot up sometimes:
    the hp dv series notebooks have had recalls for defects of not booting up from faulty motherboards and having to do bios updates, they have all the reacalls and problems on the hp support website hp.com
    Dec 28, 2009 | HP Pavilion dv2210 Notebook
    HP DV6110us: 4 beeps, no boot
    besides the beeps which indicate a motherboard timing issue. There should be LED blinking codes given on the front LEDs. I will include the blink codes below, but lets try to at least get the system up and running. First, I would like you to remove the RAM sticks from the laptop and just reseat one stick back in the machine. Try to boot with that one stick, if it does not, try the other alone. There have been issues when reseating the ram or re-installing it have temp. fixed the issue. If it does reboot, go to the HP support site, put in your model number of your laptop and download and install an updated BIOS. Below are the blink codes that may narrow down the problem.....
    HP DV6000 LED Blink Codes
    LED Component Error Condition
    Blinking battery power LED Battery Insufficient charge on the battery
    Blink: 1 - Caps Lock/Num Lock CPU CPU not functional
    Blink: 2 - Caps Lock/Num Lock BIOS BIOS corruption failure
    Blink: 3 - Caps Lock/Num Lock Memory Module error not functional
    Blink: 4 - Caps Lock/Num Lock Graphics Graphics controller not functional
    Blink: 5 - Caps Lock/Num Lock System board General system board failure
    Blink: 6 - Caps Lock/Num Lock BIOS BIOS authentication failure
    Oct 22, 2009 | HP Compaq Pavilion dv6110us Notebook
    Hp ze4600 will not power on
    Hello Mimmerfy, I have just read your problems, you checked almost every basic points. you should also read this link for more diagnose your computer issue:
    If you didn't get answer recommend to call me at +1 (833) 493-0111 (toll-free) number.
    Cheers
    John
    May 03, 2017 | HP ProCurve Switch 2650
    Samsung CRT Blank Screen
    1.Check O/P Voltages that time If U find abnormal voltage of vertical IC supply Pl change supply Diode&IC
    2. check 5V supply,change 5v Regulator.
    Aug 19, 2008 | Samsung SyncMaster 793DF 17" CRT Monitor
    Computers & Internet Logo
    24 people viewed this question
    Top HP Computers & Internet Experts
    Alun Cox
    pankaj rautela
    pankaj rautela
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
