Question about The Computers & Internet
Corbin runs slower than Marvin but faster than Manuel. Linda does not run slower than Marvin. Who runs the slowest?
    Top Expert:
  • The Master
  • 60,649 Answers
Who cares , not anyone on this website repair forum
Posted on Mar 16, 2019
5 Suggested Answers
mowerman1857
  • 389 Answers
SOURCE: mower getting slower and slower
If the dealer doesn't have a clue, I suggest finding a different dealer or reputable repair shop
Posted on Sep 17, 2009
jhoicee_01
  • 113 Answers
SOURCE: Ever since cafeworld apparently runs
Hi!!
To optimize your Facebook experience, please download the most up-to-date version of your Internet browser. For more information on upgrading your browser, follow the instructions listed here.
In addition, please try the following steps to troubleshoot the issue you're experiencing:
  1. Click out of the application (e.g., click Profile or Inbox at the top of any Facebook page), and then re-open the application.
  2. Refresh the page (Ctrl + R on PCs; Cmd + R on Macs).
If the above steps did not resolve the issue, please contact the developer of the application through their Profile Page if:
  1. The application hangs during the loading screen.
  2. The application loads, but is really slow.
  3. The application loads, but will constantly be out of sync.
If the issue you're experiencing is happening with multiple applications and with Facebook Platform in general, please report it to us here.
Lastly, if you are seeing an "Offline mode" or timed out error in your browser as if they're not connected to the Internet when you try to access you third-party application, you may be experiencing connectivity issues. We'd recommend that you talk directly to your network provider in regards to this issue.
Thank you for using fixya! I hope I had helped you with your problem. May you have a good day!
Posted on Mar 26, 2011
  • 885 Answers
SOURCE: dw999 sds drill seems to run slow then if you keep pulling trigger runs faster then back slower thanks
A common failure item the switch is going bad. You need Dewalt part number 152274-19SV. They're not hard to replace but shop around the web for one, these switch usually run between $45 and $60 plus shipping.
Posted on Dec 30, 2011
sinlacera
  • 12 Answers
SOURCE: when doing line work what should your power box be
105? 105 what? VOLTS? no more like 7-12V for lining slower, shading faster. most power supplies don't even go past 18V
Posted on Aug 27, 2012
Have a Neff D9610 cooker hood. Has 3 separate speed switches. Slowest speed switch does not work other ok. No noise from motor when slow switch on. Is the problem with the switch or the motor?
When on high speed the motor is running at it's normal speed.
When a slower speed is selected (mostly) there is external circuitry to reduce the current to the motor so it runs at a slower speed, though in some cases the motor could be specially wound for multiple speeds. The latter way is unlikely to be found in a cooker hood or extractor fan or other small appliance.
The fault with your appliance could be the switch or the current reducing circitry. It is only by delving inside and testing that the fault could be found.
Oct 02, 2016 | Cars & Trucks
When doing line work what should your power box be on,and do you run it slower or faster for shading
i believe your power box should be between 110 and 120....and for shading you should run it slower....somewhere between 75 and 85.
Oct 15, 2010 | ART Cast Iron Coil Tattoo Machine Liner &...
Mower getting slower and slower
Sep 17, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Running hot
Sounds like Clutch in your fan
The coolant level is right on, no hoses are leaking and the accessory belt is intact. You start the engine, let it idle and make a visual inspection. There's no sign of belt slippage.
If your car is like most, the cooling fan is mounted to its drive pulley via a clutch. Clutch fans operate at different speeds under different conditions to help reduce drain on the engine and to save fuel. When the engine is hot, the clutch fan runs nearly as fast as the engine. When the engine is cold, the fan runs much more slowly.
The fan clutch operation is regulated by a valve that is opened and closed by a thermostatic spring. The valve controls the flow of a viscous silicone fluid between chambers in the clutch assembly. When the engine is cold, the clutch is essentially disengaged, which is why the fan runs at its slowest compared to the engine's speed. As the engine warms up, the air flowing to the fan assembly becomes hotter. The hotter air causes the thermostatic spring to unwind and open the valve. Silicone fluid from the reservoir chamber flows into the main chamber, engaging the clutch, and the fan spins faster (though it's still slightly slower than the engine.
Hope this helps!
Nov 30, 2008 | 2002 Pontiac Aztek
Need Marvin Heater replacement element (model 2060)
Marvin replacement elements are available from Quartz Infrared for $17.95.
http://www.quartzinfrared.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=Marvin
Nov 23, 2008 | Marvin 2060 Compact Heater
Ddr ram for my motherboard
PC2100 is DDR266 memory. PC2700 is DDR333 memory. PC3200 is DDR400 memory All are backward-compatible with PC2100. Memory is designed to be backwards compatible, so generally you can safely add faster memory to a computer designed to run slower memory, but... your system will operate at the speed of the slowest memory module or system component. Keep in mind that the memory does need to be the same type, for example, SDRAM cannot be mixed with DDR, and DDR cannot be mixed with DDR2. ZT3000 "Beta tester of "0"s and "1's"
Aug 25, 2007 | EliteGroup P4VMM2 Motherboard
RAM Support
if it works there is no problem, as the system would not boot up, but your memory will run at the slower of the two speeds, which will be PC266 and not PC333, as the faster speed ram is backward compatable because it always runs on the slowest speed.
Jul 30, 2007 | EliteGroup P4VMM2 Motherboard
Memory Issues
PC2700 (DDR333) memory and PC3200 (DDR400) are backward-compatible with PC2100. Memory is designed to be backward-compatible, so generally speaking, you can safely add faster memory to a computer that was designed to run slower memory. However, your system will operate at the speed of the slowest module or system component (the "lowest common denominator" effect). One thing to keep in mind is that the memory does need to be the same type-for example, SDRAM cannot be mixed with DDR, and DDR cannot be mixed with DDR2. Let me know if you have any questions. Good Luck, Tim
Mar 01, 2007 | ASUS P4GE-MX Motherboard
Computers & Internet Logo
18 people viewed this question
Top The Computers & Internet Experts
Inky Fingers
Inky Fingers
Fred Sops
Jorge Smith
Jorge Smith
Level 1 Expert
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
