SOURCE: CAnnon Imagerunner 2800 Error code: E000002 0000
Hi Ofcgdss. This would normally require a tech, but I can help you reset the code. However, the code indicates a sub system within the copier that is critical and if the the problem still exists the copier will almost immediately display the the code and if that indeed occurs you WILL need service. Here we go.I am going to tell you a procedure that only service techs use, there is no harm in giving a one time shot as the copier will reset, attempt to recover and if the problem remains the code will return and prevent harm. Press the the " additional functions" button, then the numbers 2 and 8 simaltaneously,and then the additional functions button. This should be done in a smooth but timely 3 step sequence. This will bring up a new screen that will have several "blocks" and one of those will say "COPIER". Press the copier block. Now you will have a screen that has several " tabs" at the top and other crap in the main screen. At the top tabs you will see a block that says "function" Press function and you will get a new menu below. One of the blocks will say "CLEAR". Press clear and a new screen will appear. At this new screen you will see a block that says "ERR". Press it and then in the bottom right corner you will see a block that says "OK". Press the ok button and the copier will know that it needs to reset the code and attempt to recover from this "critical" error code.Unplug the machine, wait 10 seconds or so, and then plug it in again. The copier will assume everthing is ok and attempt to resume normal operation. Again, if the problem remains the copier will determine this rather quickly (< than 5 mins) and will return to the error condition. But without being even more long winded than I already have been, you have a decent shot at getting back to normal. I KNOW this will reset the code, I just hope it was a temporary glitch. Good luck and let me know if I can help further. ............sincerely.......SPINAL
SOURCE: Error Code E000 on Cannon Imagerunner 1600 Copier
Get into service mode by pressing.....
additional functions key (*) key and then...
ID(#) key...
Scroll down to PRINTER then press OK
Scroll down to PRINTER RESET
then indicate YES(*)
If E000 through E004 is indicated, the RAM on the image processor will
retain the error memory of the fixing assembly after the power switch has
been turned off an then on. Execute the following in service mode, and
turn off and then on the power switch to clear the memory: #7
PRINTER>#4 PRINTER RESET>YES=(*).
Any problems please get back to me
Thank You
SOURCE: Canon imagerunner 2200 error code E000602-0003
This is hard drive failure. If you another code other than 003 you may have gotten away with a scan disk, but not always. in your case the hard drive has died. a Canon Technician will need to replace it and re-install the machine's system software
SOURCE: Cannon Imagerunner 2200 Error COde: E000051-0000
There is information in the Service Manual to fix this problem. Make a service call and get a technician to fix this problem.
E051 is Horizontal registration HP detection error
0000 At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
Main cause: The horizontal home position sensor is faulty. The horizontal registration
motor is faulty. The DC controller PCB is faulty.
This problem should be handled by a technician.
SOURCE: Cannon Imagerunner 3300 Showing error
Error code E000019-0000 is a waste toner full error, so to get rid of this error you remove the waste toner bottle which is located left rear side of the machine and dispose the waste toner and dont forget to clean the neck of the bottle because the waste toner might obstract the toner sensor passege and then switch off then on.
good luck, hope it helps if so do rate the solution
