My Panasonic NA 148 VA2. Does not tumble instead in keeps spinning in the tumble cycle empties a bit of water (or so it sounds) then spins until it stops and shows 13". The hard spin is not there
Panasonic NA 148VA2 washing machine
SOURCE: washing machine
Please check if the drain solenoid is functioning. This may caused the problem.
chris
Posted on Mar 24, 2008
  • 1073 Answers
SOURCE: Maytag Washing Machine Stops after wash cycle...
sounds as if you have abad contact in the timer
advance the timer to a different spin cycle and see if it spins
then bo back to where it stops
if it will spin in the other spin cycles but not where it stops the the timer will need to be changed
Posted on Apr 21, 2008
SOURCE: Whirlpool Model LSV6234AWO
door switch bad?
Posted on Oct 18, 2008
mgprice
  • 744 Answers
SOURCE: Loud clacking sound from the washing machine as spin cycle starts
Yes you either have a whirlpool or kenmore...since you didnt mention the make I guessed :) It sounds like you have a bad coupling, have included a link giving you instructions for replacing the coupling and a link where you can buy the coupling.
http://www.thisoldappliance.com/howto/Motor_Coupling.htm
p.s you don't actually have to remove the cabinet, the motor, pump and coupling can be accessed by tilting the machine back and wedging something under it so it does not fall on you while your working on it.
you can purchase the part from:
http://www.appliancepartspros.com/part_details.aspx?part_id=3963893
Hope this helps.
Posted on Jun 23, 2009
  • 4 Answers
SOURCE: washing machine won't spin and drain
the drain pump is not working,after wash cycle the washer should drain the used water,if it does not function-all the next cycle will not commence.
Posted on Mar 20, 2010
Is it normal for the washing machine to start and stop the spinning while the machine is in each cycle? Should it take over an hour to run one wash cycle?
Yes...they use less water...so they start, tumble, then cycle again adding more water. I use the fastest setting on all my clothes which is 1/2 hour. It also does start and stop during spinning to tumble the clothes. It speeds up as it goes thru each stop till it spins real fast. All my clothes wash perfectly on fastest cycle.
Aug 13, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
No tumble just spin faults on Hoover WDM 120
plz recheck you connection and clean the connecting points otherwise you have to call a service person for the servicing
Sep 01, 2008 | Washing Machines
After wash cycle, tube will not drain water?
Probably a blocked empty pump filter. Spin won't kick in until all the water is evacuated. If there is a little left, the machine will do the slow turn cycle that it does just before spin starts but not start the spin cycle because of the water in the drum.
You need to locate the filter and clean it. That should fix your problem. Once this is done, remember to keep the filter clean every few months.
Jun 23, 2011 | Whirlpool Washing Machines
Not spining properly on daily load cycle
Make sure door mechanism is working at fine. So next is to check whether the motor tumbles both directions.
The spin bearing might be a problem, but normally you'd hear a problem here first. Have you heard any freight trains passing through the house in the spin cycle?
One thing to check for this problem is the spin speed switch. If the spin speed switch is bad then the control won't know how fast to spin, and so it will just not spin at all.
The drain pump must be draining all the water out. If the water doesn't drain out then the pressure switch won't read empty and that might prevent a spin cycle.
I hope this helps.
Please reply with additional details for further assistance.
Shane
Mar 26, 2011 | Whirlpool Washing Machines
My kenmour washer stopped spinning
I hope this helps.
Shane
Mar 26, 2011 | Kenmore Washing Machines
Will not spin
I hope this helps.
Shane
Mar 10, 2011 | Bosch WFK 2401
No spin cycle
I hope this helps.
Shane
Shane
Mar 01, 2011 | Hotpoint WMA76 Front Load Washer
Roper rtw434osq0 not spinning/draining water
Set the timer to spin manually and turn it on.
Does it spin?
If not,
Your lid switch is bad and must be replaced.
If yes it does spin.
The timer is bad.
Mar 12, 2009 | Roper RAX4233PQ Top Load Washer
Bosch Maxx WFL2260
Here are the symptoms: - Wash cycle seems ok but can not be sure. When complete the rinse commences but am unaware what happens next. This is what I have done Started washing clothes and waited for cycle to end(!) or problems start. Switched off and set program knob to rinse. At this point I select spin and after a while the water starts to empty. When a sufficient amount has emptied I stop the spin (no spinning has began), and set the knob to wash again. This now allows clean water to rinse the clothes and when I think it has rinsed enough I set the knob to off then spin again until all the water has emptied. When the drum is empty the spin cycle should continue but does not. What happens is there is a clunking sound and the activity light goes out again, when it comes back on the machine tries to start the spin again and the sequence is repeated.
Mar 24, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
paul
paul
