Question about Sony Audio Players & Recorders
How do I get my sony reciever STR-K790 out of protection mode. I changed the fuse plugged it in then turned it on and it says protection
    Genius:
  • 1,563 Answers
Try unplugging speaker wires from unit then power on. If it still says it u have an internal short. If it doesnt hook one speaker up at a time and see if it says it. Might be bad speaker or wiring.
Posted on Mar 15, 2019
SOURCE: I NEED INSTRUCTIONS ON HOW TO CONNECT ALL COMPONENTS TO THE SONY STR-DE598 RECIEVER
codes for remote
Posted on Dec 23, 2007
  • 3 Answers
SOURCE: code for sony receiver model str d565 protect mode
If you need support you can log into:
http://esupport.sony.com/US/perl/support-contacts.pl?mdl=STRDG510
for free tech support on sony chat line
Posted on Jun 02, 2008
ginko
  • 19396 Answers
SOURCE: stuck in protect mode
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
Posted on May 29, 2009
tns_davao
  • 32 Answers
SOURCE: my reciever sony str-k740p reads (protect) and it
Grounded speaker wire check your lines going to the speakers
Posted on Jul 10, 2009
SOURCE: Sony STR-D611 receiver goes into
the protect is blinking
Posted on May 02, 2010
Can not get surround sound to work
Your Protection System probaly come on for some reason,Sony Is Known for that problem, Check on your screen if a red lit warning Staying (protect) Is on.If there is, Try hiting the reciever on the sides or the top of the cover fairly hard when it is turned on, Some times this will work to turn the protect light back off, Sony is bad for there amps end recievers going into the protect mode,
Sep 19, 2012 | Sony STR-DG600 Receiver
Sony home theatre system
Good enws is yout unit is not fried. Bad news is you need to get the protection fuse replaced...
Mar 04, 2008 | Audio Players & Recorders
Hi. my sony STR-DE 597 go in protect mode. how can I fix/repair this? Give me a tips.
protect mode means there is a shorted components inside your reciever it's probably the out put transistors take out the transistors and test it with a multimeter.
Jul 11, 2011 | Sony STR-DE597 Receiver
I HAVE A SONY RECIEVER SRT-DE597 6.1 CHANNEL AND I ITS ON PROTECTED MODE CAN YOU HELP ME UN PROTECTED
Amp output is damaged and needs repaired. Protect mode cannot be deactivated. When amp is repaired and operating normally protect mode will not be displayed.
Aug 29, 2009 | Sony STR-DE597 Receiver
Reciever on protect mode
Hold in power button until unit "clicks." Takes about 20 seconds.
Jun 18, 2009 | Sony STR-DE325 Receiver
Sony STR-D460Z receiver
A common cause are failures in the amplifier output stage, the drivers, and some of the support components. You will have to send the unit out for service.
Jerry G.
Feb 08, 2009 | Sony Audio Players & Recorders
I have an old 5 in one reciever sony; i dont see any fuses and my problem is that after turning on it goes to the protect mode flashing prptect. i disconted the entire reciever so i know there are no...
No reset will help this. The problem is an internal short most likely in in one of the amp circuits. This is a relatively simple repair for a service shop. Expect a parts cost in the $40 range. Add in the local labor rate for the total repair cost.
Dan
Feb 01, 2009 | Sony STR-DE475 Receiver
HI, I have a sony v555es amp and it gives me the following error message "protector OPT.....please power off"
You might be trying to push it too hard, or you might have a short somewhere. Disconnect everything from the reciever except its power cord and turn it on. If it still goes into protect mode, then try to find a reset switch (not sure if this is on the Sony, some recievers have them). If it's NOT in protect mode, then you had a speaker wire shorting out on the back. Make sure that you don't have any stray wires when you connect the cables on the back of your receiver. It only takes one strand of copper to short out the amp section. If that doesn't work then pull the top cover off and chech the fuses out. One of them might be blown.
Tom
Jan 01, 2009 | Sony STR-V555ES Receiver
Stuck in protect mode
Speakers shorted out, blew a fuse. Replace the unit or (cross your fingers and) open up the box and find the blown fuse.
Nov 23, 2007 | Sony STR-DE425 Receiver
23 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
