Question about Luxor Televison & Video
My Luxor smart tv 40 inch has started closing down after a minute or two the red light continues to flash and then the tv comes back on this is repeated until the set is turned off any ideas?
  • Rich White Mar 15, 2019
    Mine has just started to do the same last night. It only happens on TV mode. Netflix or any other source it seems fine. My TV is only 2 years old.
  • 18,002 Answers
This is caused by the power supply detecting an over current condition. The condition could be a bad LED in the back lights. Since you did not post the exact model number, that is all.
Posted on Mar 15, 2019
ctf1800
  • 4402 Answers
SOURCE: jvc 52 inch hd-ila hdtv widescreen
you have a bad lamp or balast
Posted on Jan 22, 2008
SOURCE: Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Posted on Oct 21, 2008
SOURCE: tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Posted on Mar 24, 2009
dsacco86
  • 1077 Answers
SOURCE: my sony bravia tv is flashing red stand by light
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 29, 2009
welcomejee
  • 10594 Answers
SOURCE: sony wega 55 inch tv turns on fine but after one
This kind of problem occurs when lamp becomes weak that means near to end of working life hours but still not dead nor broken.
Replacement of lamp in tv will solve your problem, lamp replacement procedure is easy and would be written in user manual.
Thanks.
Posted on Oct 30, 2010
Testimonial: "Thank you- this answer was Very helpful !"
Hi my luxor tv won't come off standby and the red light flashes 35 times? Model number LUX0140001B/01
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://electronicshelponline.blogspot.com/
If blinks continue without any pause, the main board is faulty. 35 times flash can be considered as continuous.
Sep 21, 2017 | Luxor Televison & Video
Can you add apps to luxor smart tv's?
yeah look for the icon on the screen that says market and then just use the buttons to look through the apps
Apr 12, 2014 | Televison & Video
Tv wont power on red light continuously flashes
Hi,you need to have the capacitors in the powersupply replaced
Oct 15, 2013 | Samsung UN46D6400 46 Inch 3D 1080p Smart...
Luxor tv will not power up and red light just keep flashing
I just pull out the mains plug for a few seconds then put it back in. The red light keeps flasing for a while (be patient) then stays solid red. When I then switch on again with the remote it is fine. I often have to do this.
Jul 27, 2012 | Televison & Video
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
My hitachi ultravision is a 60 inch tv and when i try to turn on the tv the blue light flashes and then the red lights flash up and down but the tv wont turn on please help!!!
Good Day, peraltap73;
Lights flashing like crazy? First try unplugging the A/C cord from the wall for 3 to 5 minutes then plug TV back in. If that does not FIXYA TV, please call an Authorized Service Center To come out to your home and give you an estimate of the repairs.
Good Luck, big IRISH.
Aug 16, 2008 | Televison & Video
Televison & Video Logo
Top Luxor Televison & Video Experts
Sp Gupta
 Mike M
Mike M
sureshd2008
Are you a Luxor Televison and Video Expert? Answer questions, earn points and help others
