Question about Whirlpool Washing Machines
Whirlpool fl 243 500 stopped in the middle of the washing cycle from no4
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 36 Answers
Maybe its because youre timer
Problem or timer contact or fuse blowing coz of heavy load ,unload and check the power supply
Posted on Mar 15, 2019
defrankond
  • 66 Answers
SOURCE: Getting ''FL'' error code w/Whirlpool Calypso
you can try unplugging the washer and letting it reset the system. thenplug it inand press the spin/drain button. if it still gives you the flood condition chances are the pump is faulty and needs to be replaced. it may be covered under whirlpools warranty for the law suite against the washer. otherwise you can get the pump off ebay for cheep and install it yourself. its just a little messy so if you do it yourself make sure you have a shop vac around to **** up the excesswater.
Posted on Nov 29, 2008
  • 85 Answers
SOURCE: washer stops during middle of cycle and post 02 F
f 02 is the error code for taking too long to drain the water disconnect power remove 3 torex 20 screws from lower front panel revove cap from pump asm to check for any obstructions beware there will be water in the pump
Posted on Dec 16, 2008
  • 351 Answers
SOURCE: whirlpool super capacity washer spin cycle stop working
Sounds like you need a new lid switch. Click HERE for prices.
Posted on Apr 19, 2009
rylee_smith
  • 8619 Answers
SOURCE: stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 29, 2009
57 varieties
  • 1653 Answers
SOURCE: My whirlpool duet front load washing machine stops in mid cycle
F21 = LONG DRAIN ERROR
If the drain time exceeds 8 minutes the water valves turn off. After 4 minutes the “Sd” error will be displayed, then 4 minutes later the F21 error code will be displayed.
Press PAUSE/CANCEL two times to clear.
Procedure:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
5. If the above does not correct the problem, go to step 7.
6. Unplug washer or disconnect power.
7. Replace the pump.
Alternative Procedure:
If the machine cannot be forced to its diagnostic mode then:
1. Disconnect the washer from the power supply and water supply.
2. Remove the top panel by taking out the three screws in the back of the washer. The pressure switch is right on top.
3. Remove the Molex connector from the water level switch / pressure switch.
Refer to the picture below.
4. Reconnect the power supply but not the water supply.
5. Power the machine. The machine will enter diagnostic mode.
6. Power off the machine.
7. Replace the water level switch / pressure switch.
8. Reconnect the water supply.
9. Power on the machine it will work without error
Posted on Oct 02, 2009
What dose a FL code mean on whirlpool cabrio platinum
I will try and help for some reason Whirlpool likes to flip letters around which differ from the service manual FL would be an LF long fill or is it a F1 the model doesn't show in the Whirlpool data base nor parts suppliers I suspect wtw6600sb1 does the machine from initial start fill correctly then wash if so we can eliminate the pressure switch and hose after wash cycle unit should drain then fill with rinse water if the inlet valve does not let water into the machine to satisfy the pressure switch the control times out and flashes a long fill code this unit has a log valve system possible you have a bad inlet valve on the bank of valve or a bad control not outputing voltage to the valve, hope this points you in the right direction
Jan 14, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
The wash machine stopped working and is flashing FL
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
Jun 13, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso top load washer GVW9959k stuck on FL
FL=FLOOD CONDITION
I bet I know what the root cause of the problem is. TOO MUCH DETERGENT. Why do I yell that? OK here is what happens. Suds make the computer monitor work overtime to wash the clothes. The the computer measures the amount of water being used. The computer is also trying to correct the suds problem by adding water during hissy-cycles. (I call em hissy cyles.) Solution: Clean the soap dispencer use HE soap and use the right amount which is:
HE: (2) Tablespoons Per Wash load
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
Calypso Service Manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 12, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Every wash cycle FL shows on the screen, I have to extend the spin cycle to get all of the water out.
FL
Flood condition
"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Check the over fill switch hose for weakness or, damage if the FL code continues. if the hose is ok, replace the Over fill switch..
Jul 15, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My calypso stoped and FL flashes and will not cancel,
The FL error code means:
Flood Condition:
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 15, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Nov 23, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
24 people viewed this question
Sal De
Marvin
Marvin
jimorris77
