Question about Ricoh Office Equipment & Supplies
I have ricoh mpc6000 ..when i use side tray for printing , when i press copy/print button the paper turn back ..moves reverse order.
Please give the solution emedietly
SOURCE:
  • 25 Answers
SOURCE: My HP LaserJet 4200 prints fine from tray 2, but will NOT print envelopes from tray 1. It WILL print on regular paper from tray 1, but will not print envelopes. What gives? I've already rebooted the
Are there settings on the control panel of your printer?
Is the tray 1 the MP tray? (The one that flips towards you)
If so, can you change the settings of the Tray 1 to Envelope on the control panel?
I hope this helps.
Posted on Aug 14, 2008
  • 25 Answers
SOURCE: paper tray full message and not printing
there is a black tab in the center where the papers come out that is the tray full sensor arm that is more then likely stuck
Posted on Jan 07, 2009
  • 32 Answers
SOURCE: Functional Problem SC321-00
the sc320 code would indicate that the polygon motor should be replaced. when you turn on the machine, the normal high pitch buzz will not be there the motor is not spinning up. that's the reason for the blank copies.
the sc321 code is a "no laser writing signal (f-gate) error". which would caused by the polygon motor not spinning.
replace the polygon motor.
Posted on Apr 03, 2009
SOURCE: My MFC8460N Brother won't print. It makes this
Gears on the tray is broken, or the gears that lift the tray. (thus the clicking noise). And the no paper is due to the actuators underneath not being activated because of the non lift.
Posted on Mar 11, 2010
SOURCE: GRINDING NOISE or PAPER JAM
Lub rails front and back. Make sure ribbon isnt seized.
MarkR
Posted on Oct 30, 2012
Paper always jams even without starting,,,,specially when im going to print cardstock, it never works
Jams from where? Need more info. Cardstock must be printed from the Bypass Tray ONLY. Make sure you select the proper paper type from the Printer Properties tab in the driver.
Oct 13, 2014 | Ricoh Genuine Aficio Mpc6000, Mpc7500...
Trey 1 is giving a message out of paper when they is paper inside
The message "No Paper" will appear on the LCD display if the Brother machine does not detect paper in the paper tray(Tray#1 or Tray#2) or MP(Multi-purpose) Tray.
Resetting the Brother machine may resolve this issue. To reset the machine, unplug the power cord from the AC power outlet for approximately 10 seconds and then plug it back in.
Note
For MFC users :
The Brother machine can be powered OFF for up to 4 days without losing faxes in memory.
If the message "No Paper" continues to appear on the display follow the instructions listed below:
When printing from Tray#1 or Tray#2 :
Pull the paper tray completely out of the machine. Go to STEP2.
When printing from MP Tray :
Go to STEP4.
Note Tray #2 is the optional LT-5300 paper tray.The MP Tray is just above the main paper tray and can be accessed by opening the MP Tray door. To open, pull on either the left or right side of the front door by the circular cut out.
2. While pressing the blue paper-guide release lever, slide the paper guides to fit the paper size. If the back of the paper tray doesn't move, the tray lock button may be in the lock position; slide the lock button to the unlock position and pull out the back of the paper tray again. With the paper removed, you will see the LTR (letter) marking on the plastic plate on the bottom of the paper tray to indicate where the moveable rear guide (with protruding arrow) should be moved to for letter size paper. There is also a marking for legal size paper. Make sure the guides are set at the correct mark. Reload the paper in the paper tray. Make sure the moveable rear guide does NOT push tightly against the paper. It should be adjusted to the LTR (letter) or LGL (legal) position, depending on your paper size. If the moveable rear guide is pushed too tightly against the rear edge of the paper, the paper will get stuck in the tray and a loud plastic snapping noise may be heard when feeding paper.
3. Move the tray lock button to the lock position (slide the button towards the paper).
4. If there is no paper in the tray, reload the paper.
The tray can hold up to 250 sheets of 20lb paper. Do not overfill the tray. There is a maximum paper mark located on the top of the right and left paper guide. It looks like a V cut out in the plastic.
Note
If you are using special paper and the machine has problems feeding it from the paper tray, try the paper again using the manual feed tray. Make sure you insert the paper far enough --about 1 inch- under the gray plastic bar in the MP Tray until it stops or it will not be fed and the machine will display the message "No Paper".
5. Verify the correct size and type paper is being used:
If you are printing from a PC and using the paper tray, make sure that MP Tray is NOT selected in the application's print properties for Paper Source.
If you are printing from a PC make sure that the MP Tray is selected in the application's print properties for Paper Source.
Note: Please be aware that the setting in the printer driver will take priority over the setting made on the control panel.
14. If you have set the Tray Use settings for a particular tray, the machine will feed paper only from that tray. If the selected tray is out of paper, a "No Paper" message will appear on the LCD. You need to reload paper in that tray.
To set the Tray Use setting, follow the steps below:
a. Press Menu.
b. Press the up or down arrow key to select General Setup.
c. Press OK.
d. Press the up or down arrow key to select Tray Use.
e. Press OK.
f. Press the up or down arrow key to select the mode you want to use.
You can select Copy, Print or Fax(MFC users only).
g. Press OK.
h. Press the up or down arrow key to select the tray.
You can select Tray#1 Only, Tray#2 Only or MP Tray Only.
i. Press OK.
15. For MFC users :
To test, print the Help List.
. Press Menu.
a. Press the up or down arrow key to select Print Reports, and press OK.
b. Press the up or down arrow key to select Help List, and press OK.
c.Press Start.
For DCP users :
To test, print the User Settings.
d. Press Menu.
e. Press the up or down arrow key to select General Setup, and press OK.
f. Press the up or down arrow key to select User Settings, and press OK.
g. Press Start.
Note
If the problem still continues after following the above instructions,
I recommend you clean the Separation Roller, Pickup Roller and Separation pad following the instructions of the FAQ: My Brother machine mis-feeds paper.
Apr 21, 2012 | Brother MFC-8460N All-In-One Printer
I use a CM2320nf MFP connected to Windows XP. The unit seems to be defaulted to print 2 pages - and for double sided copies, it stops after 2 pages, then the Cleaning window pops up, then I get an error...
Problem 1 :
As far as the machine printing 2 pages per job. To fix this it's usually the default number of copies the printer is set to. To change/ confirm the setting is set to one:
Press the menu button
Arrow down to -> Printing, Press the green check to enter the menu
Arrow down to -> Copies Press the green check to enter the menu
Change or confirm the value = 1, (Based on your question this might be set to 2) Press the green save the value.
* If your number of copies is set to 1 and the machine is still printing 2 copies, then the problem relays in your print driver.
Problem 2: General Misprint Error message something like 41.3
2 things to check:
1st - Press the menu button
Arrow down to Paper Handling, Press the green check to enter the menu
Now you will see options like Tray 1 size - Tray 1 type. Here their will be a option for each tray installed on your machine. You will go into each tray option and confirm the paper size and type.
Example
Tray 1 Size = Envelope #10 (This is the manual feed tray)
Tray 1 Type = Envelope
Tray 2 Size = Letter
Tray 2 Type = Plain
To perform arrow down to tray X size press the green check to access the menu, arrow up or down to select your paper size. Once the paper size is selected press the green check to save it. repeat for each tray.
2nd -
Pull out your tray and remove the paper, towards back of the tray you will see a guide (Tab) in the middle of the tray which allows you to expand the tray to accept various paper sizes, Please confirm the guide is set to the correct type. If your using letter, make sure the guide is set to letter (LTR) you can see these codes by looking at the base of the guide, their is a little arrow pointer.
Hope this helps
Jan 14, 2011 | HP LaserJet 2420 Printer
All in one printer displays clear paper jam then press ok, but no paper jam can be found on printer. hp photosmart c5380 all in one.
There are a number of things that can cause a carriage jam. To prevent it from recurring, one should keep in mind a number of things. Always ensure that the paper tray is not overloaded as this might result in the paper being stuck inside. Also the paper being used should be as per the manufacturer's recommendations. Turn off the printer when removing bits of paper. If there is a broken gear, do not repair it yourself. Call an expert HP technician to mend it.
Sep 25, 2010 | HP Photosmart C5380 All-In-One Laser...
How do I use my printer as a duplex for making copies on both sides? Thanks Roxanne
The printer does not support duplex coping. If you want to do manual duplex copying, you can make a copy of the first page.
Then reinsert the paper upside down in the manual tray or paper tray, fil the page on the document feeder and make the back copy.
Aug 27, 2010 | Samsung CLX-3170FN All-In-One Laser...
A3 prints - printing on A4 - Ricoh C4500. When users print to our Ricoh C4500 using RPCS the print comes out as a cut off A4 print, so it does not seem to be detecting the fact that it is needing to use...
Enter on the computer the follow path:
1. enter start menu
2. enter printers and faxes
3. enter by right click into properties
4. enter paper size settings
5. set the paper size for the tray or trays and press update then apply and ok
after thet it will work
Also see on the printer menu enter the same paper tray settings and set the trays by size but more important is to set the compute settings
Jul 08, 2009 | Ricoh Aficio SP C410DN Laser Printer
Ricoh prints everything in left Margin
Check the printer properly and see what size paper the printer thinks is in there, or check at the controll panel.
-Carl, please let me know if this helps.
Jun 25, 2009 | Ricoh CL3500N Laser Printer
Not printing double sided
check the driver
does not print from bypass tray (manual feed)
does not print on thick paper (check paper type)
Apr 01, 2009 | Ricoh Aficio SP C410DN Laser Printer
Paper jam
Solution
Step one: Remove any lose paperRemove any lose paper from the paper tray. CAUTION: Do not remove jammed paper at this stage. Step two: Clear the jam from the back of the product
  1. Remove the paper from the paper tray.
  2. Press the power button (c00636182.gif ) to turn off the product.
  3. Disconnect the product power cord from the electrical outlet.
  4. Remove the rear access door. Press the handle to the right, and then pull out the door.
  5. Remove any paper that is inside the printer by pulling the paper out from the back of the printer.
  6. Replace the rear access door.
  7. Load paper in the paper tray.
  8. Reconnect the product power cord to the electrical outlet.
  9. Press the power button (c00636182.gif ) to turn on the product.
  10. Try to print. If the product prints successfully, the issue is resolved. If it does not, proceed to the next step.
Step three: Open the top cover and clear the jamIf the paper jam cannot be removed from the back of the product, try to remove it from the front.
  4. Raise the product cover, remove the paper jam from the front of the product, and then lower the cover. CAUTION: Remove the paper jam carefully because it is possible to damage the printer when removing paper from the front.
  5. Load paper in the paper tray.
  6. Reconnect the product power cord to the electrical outlet.
  7. Press the power button (c00636182.gif ) to turn on the product.
  8. Try to print. If the product prints successfully, the issue is resolved. If it does not, proceed to the next step.
Step four: Make sure that the carriage can move freely
  1. Press the power button (c00636182.gif ) to turn off the product.
  2. Disconnect the power cord from the back of the product.
  3. Raise the cover and try to move the carriage from side to side by hand. 1 - Carriage holding ink cartridges
  4. If the carriage does not move, the product needs to be serviced. If the carriage does move, proceed to the next step.
  5. Make sure that the ink cartridges are locked into the carriage and have not come loose. Make sure that there are no obstructions under or around the carriage to prevent it from moving.
  6. Make sure that the carriage can move freely across the width of the product by gently pushing the carriage to the left and to the right.
  7. Close the product cover and reconnect the power cord to the back of the product.
  8. Press the power button (c00636182.gif ) to turn the product on.
  9. Try to print. If the product prints successfully, the issue is resolved. If it does not, proceed to the next step.
Oct 22, 2008 | HP Office Equipment & Supplies
H.P laserjet 4100 series.
Printout a copy of your printer configuration. Press the right-side of the MENU button once, then the right-side of the ITEM button twice, and press the SELECT button once. This will print out a configuration page. In the lower right part of the information on this page, it will give you stats on the Paper Trays and Options. Standard settings on these should be "Default Paper Size: LETTER, Tray 2 (LETTER). If either of these says anything different, I would do a cold-reset on the printer to reset it to factory defaults. If you have a network card installed, you need to pull it out before doing this. To do a cold reset, turn the printer off, then hold down the GO button and turn the printer on. Wait about 5 seconds, then release the GO button. Also, you need to check your print setup on your PC. I am assuming you have a WindowsXP machine. Click START, SETTINGS, PRINTERS&FAXES. Right-click your printer icon and select PROPERTIES. Click the PRINTING PREFERENCES button at the bottom. Click the PAPER tab. Check the boxes at lower left. "Size is should be Letter", "Source is & Type is should both be Auto Select". Click OK, click OK, and exit the Printers Window. Lastly, I would make sure that you have Letter size selected from the application you are trying to print from. Hope this helps.
Feb 26, 2007 | HP LaserJet 4100n Printer
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
