Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
Tv does not turn on
My tv does not turn on when i try to turn it on, the red light flashes fast and it try to but it does not turn on.
  • 383 Answers
Re: tv does not turn on
Unplug your TV Let it set for 60 seconds and re-plug up again .
Posted on Nov 27, 2007
0 characters
3 Points
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Standard (CRT) Televisions
JVC TV has flashing red light in front. TV won't turn on when red light starts flashing. After unplugging tv for a while, TV sometimes turns on but screen is shaking violently. Any flashing lights...
sometimes a leaky filter capacitor in the power supply primary section could caused this problem,or a loose solder connection in the power supply section
Jul 18, 2011 | JVC AV-32230 32" TV
Sony wega #KDF-55-WF-655 won't turn on: goes to standby mode
don't wory sir , may i help you .
this is a not mager problum but sum times technicean is parsnal baneefits besness and fast money making this rongh dignosis and canfused to castamer so don't wory ...
[1] problum is in side tv set in out put voltage form EHT becose your tv is red and green light is ok then SMPS is ok
pls. check with tv techicean and follow sum tips
* voltage check From EHT out put and canacting spear.
* H- out put tangester and cancting sperar
* H out put tarngester base tarminal voltage check if ok then 100% problum is EHT or canacting spaer so don't wory all spear is not very expancive pls.find Best tech.and solve this problum Esely
best of luck...
Jan 30, 2010 | Toshiba CZ36V51 36" TV
Flashing light
The LED used in most tv are dual color led,some have two lead, some have three. try to find the same size and replace it.
Jun 20, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv turns off but will turn right back on
Service Manual of KV-32XBR400 shows error info regarding red light flash 2, 3, 4, 5, 6, & 7 times only. Each flash corresponds to different problem in TV. Please check red lighe flash count again.
Aug 10, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
TV won't turn on, red light flashes twice
your tv has hardware problem and Sony service person can fix it.
Jul 16, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Toshiba TV, no power, red light flashing
Unplug the TV for 2 minutes and plug it back on.
It should work.
Feb 09, 2008 | Standard (CRT) Televisions
Remote won't turn set on anymore!
Hi Smittie, I had a similar problem with another type of TV set. All functions work well except power. The solution was to replace the batteries, perhaps they are running low. It will also reset the remote which might help as well. Hope this will work for you too. Cheers.
Feb 09, 2007 | Samsung TXN3271HF 32" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
434 people viewed this question
Top Sony Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Sony Standard (CRT) Television Expert? Answer questions, earn points and help others
