Question about Rainbow E series Canister Wet/Dry Vacuum
Reset buton? HI was using the shampooer , the container got full, the vacum stopt before i could empty it and now it doesent turn back on, is the a reset button to hit
  • skkkfam Dec 02, 2007
    Same exact issue...there has to be some kind of safety switch..does anyone know?
  • 56 Answers
Hi painter1 and skkkfam,
even not knowing what Rainbow models are you using, I know that in the newer versions there's a red buton in upper side that is "Restore". Other case is a security shaft that makes the machine available when we turn it on, wich works only when the water tank is on it.
you'll need to see if that shaft is well sit in it's place and working perfectly (you'll ear a small click pushing a small insider black button in the lower side of the machine, when separated of the wet canister). If nothing of this works, you'll need to see the engine, because it's clogged.
Best complements
Posted on Jan 18, 2008
Bissell carpet shampooer model 9200-9 that is not dispensing cleaning solution
I had the same problem with my Bissell carpet cleaner. I tried all the recommendations but nothing worked. After reading all the blogs, I discovered that many people had the same problem. Fortunately, I still had the receipt from Costco which they honored and gave me a full refund. I was ready to throw it in the trash.
Oct 06, 2015 | Bissell 2X Proheat 9200 rug cleaner
Dyson DC14 animal shut down, now won't turn on
This coul;d be a couple thing, it could be that the machine is full and shut off due to a heat sensor. You should see if it has a reset button on it for the power head. I don't think it does so I would empty it out and clean the filter and try it again. Also did you try it in another plug in as you may have blown the breaker.also if the dirt container is not in just right it will not turn on as threre is a safety switch so it can not be run without the dirt container. Try these things and if you have npo luck write back and we will try again.
Oct 08, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Vacum cleaner flashes lights and goes dead.
Do you put it down before you turn it on? some vacs wont turn on in the upright position. Happened to me once til I stepped on the button to bed it back then powered right up.
Jan 15, 2010 | Electrolux Vacuums
What parts go to a Kirby Shampooer?
There is a shampooer head with shampooer brushroll, water tank, small hose that hooks to the tank, collection tray
Need to use the Kirby shampoo. It goes down as wet suds but you pick up the suds with the vacuum when it drys. Fill tank adding 1 cap full of soap (kirby soap only) per level on the side, this attaches on the side where the bag is attached
After using the shampooer you need to reattach the vacuum bag and main brushroll nozzle as though you were just vacuuming up dirt.
Lift the front of your kirby up (front part with light) open the handle on the dail in the front (if epquipt), remove the power head, put on height adjustment on highest level, turn dial on front of power head until you see 2 red arrows facing each other, unlock by turning knob, power head should come right off, get shampooer out the power head for shampooer with collection tray, make sure dial is set red on red, put on front of Kirby and lock in, turn dial to green on green arrows, fill tank adding 1 cap full of soap (Kirby soap only) per level on the side, this attaches on the side where the bag is attached, line up arrow and notch and turn, to hook up hose put Kirby down to lowest level, notched end of hose hooks in on tray other end on the tank,on/off switch refers to the foam, Turn machine on to lay the foam & scrub carpet, take shampooer back off to extract the foam once it's dry.
Good luck.
Aug 20, 2009 | Kirby G5 Bagged Upright Vacuum
Don't know how to use carpet shampooer
You should have the new aquamate, it has a blue top to fill with the water and water/soap solution that pops down into place. You will need to use your power nozzle hose and tube, connect it to your shampooer (make sure to connect the power connection just like the power nozzle). Fill your water up, large compartment is for cold water only and the smaller compartment is for one cap full of soap then the rest filled with cold water. Start with just a splash of water or an empty basin in the rainbow. The trigger will control your water spray and the brush underneath. There are two levers on the back of the shampooer marked with a shower head and a bar of soap. Use the soap with the shower head and the soap on and the water only with just the shower head on. You will want to also go over the area shampooed with both off to **** up the remaining water. Make sure to clean your floor thoroughly before shampooing.
Aug 13, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Kirby Manual
The spray gun instruction HERE but be very careful - try shampooing in an inconspicuous area first. This is essentially as if you would buy some of those "spray on" upholstery cleaners in an aerosol cans.
Good Luck,
Sep 19, 2008 | Kirby G6 Bagged Upright Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
122 people viewed this question
Top Rainbow Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
