Jackson 24 in. JPX-300H Built-in Dishwasher
Problem for Jackson 24 in. JPX-300H Built-in Dishwasher
Model JPX-300H, the unit does not fill, but it
By rodcody on Aug 06, 2009
Model JPX-300H, the unit does not fill, but it will drain if you fill with water from a bucket. Also when the unit drains there is water coming from under the unit. How do I check the fill valve for proper operation. Thanks
Solution #1
posted on Sep 27, 2009
Not Rated)
kurtmorganec
Rank: Guru
Rating: 91%, 9 votes
the fill valve is easy just take the coil off and there is a hole in it put a metel screwdriver in the hole and turn the unit on if it pulls the screwdriver like a mganet it works is more likely i bad diaphram now as for the draining it drains bu turning a valve dirverting the watter from the pump down the drain hose so you must have a hole or leak in the hose
Was this helpful?
Yes
No
Popular Solutions for Jackson 24 in. JPX-300H
Questions and Unsolved Problems for Jackson 24 in. JPX-300H
Do you recommend Jackson 24 in. JPX-300H Built-in Dishwasher?
Answer
Answer
I am looking for the "how to" manual to hook up the wiring for our new Maytag dishwasher. ... (More)
Answer
Dishwasher fills with water but the top and bottom sprayers don't spray or turn
Answer
It seems to run ok, but about 30 minutes into the cleaning process, we notice a burning smell that... (More)
Answer
how can i wire a jackson dish washer jpx 300h with out the relay useing a contactor
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Jackson 24 in. JPX-300H...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
