Fujitsu 18C1 Air Conditioner
Problem for Fujitsu 18C1 Air Conditioner
Same issue but how do I get the cover off the indoor unit?
By rlebedow on Aug 06, 2009
I have lots of water coming for all 4 units I have, only during the summer. Cant get the guys to come out again, they blamed the plumber for the problem. I dont buy that. Help it ruining my hardwood floors.
Solution #1
posted on Aug 06, 2009
Not Rated)
jones357
Rank: Master
Rating: 86%, 7 votes
do u have water draining on the outside wherever they ran the drain lines from each unit? if not , maybe they werent pitched correctly and are overflowing, those units have a tiny drain pan and must be pitched correctly on the install. Call a different contractor to check it out! And only during the summer because those units, as any AC does, remove a great deal of humidity, it isnt that humid in other seasons.
Was this helpful?
Yes
No
Popular Solutions for Fujitsu 18C1 Air Conditioner
Questions and Unsolved Problems for Fujitsu 18C1 Air Conditioner
Do you recommend Fujitsu 18C1 Air Conditioner?
Answer
Answer
unit will not turn even if manual switch is pressed on indoor unit
Answer
The wall unit won't respond to the hand held timer/control. Worked fine a month ago. Batteries... (More)
Answer
Timer and operation light flash similtaniously 5 times then 5 second gap then flash again. continues... (More)
Answer
evap is blinking two green light flash and condensor will not operate on my fujitsu aou30clx split... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fujitsu 18C1 Air Conditioner:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
