Question about Olympus FE-170 Digital Camera
Olympus fe-370 saving on camera instead of on card
I cannot figure out how to get my camera to save on the card instead of on the internal memory, i have formated the card and it still saves to internal memory
    Genius:
  • 1,234 Answers
Hello ==)
# Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
# 2 Open up 'My Computer'. You should see it under the list of available drives.
# 3 Check its contents first to make sure that you have the right drive.
# 4 In 'My Computer', right-click on the drive and choose 'Format'.
# 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
# 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Posted on Aug 27, 2010
SOURCE:
CARD FULL with 3 pictures
Have you tryed eraseing / formating it in the 740?
Make sure the camara uses the card instead of internal memory
it might be that its saveing the images into the cameras internal memory witch is probably just about 3-4 shots.
Mar 09, 2008 | Olympus Stylus 740 Digital Camera
I don't know how to transfer pictures from my camera to my memory card
With no card in the camera, go into the menu and find "format". Follow the on-screen instructions to erase the internal memory. After that, your card should work properly.
Nov 10, 2011 | Olympus FE-370 Digital Camera
Trying to transfer internal pictures to memory card
Hi. you should already have the memory card in. it automatically saves to the memory card
Feb 20, 2011 | Olympus FE-370 Digital Camera
My camera wont take pictures when i have my memory card in it it says write protect. but when i take the memory card out it will????
When you remove the card, the camera is using its built-in internal memory which is very small and won't hold many pictures. Does your card have a slide switch on the side? If so, it should be in the unlocked position.
Nov 28, 2010 | Olympus FE-370 Digital Camera
Transfer internal memory to memory stick. Olympus camera
Place a memory stick in the camera. Next, go to MENU, then press BACKUP. This will save your internal images to media card.
Jan 11, 2010 | Olympus FE-280 Digital Camera
Usb cable for olympus fe-370 digital camera
Hi
It sounds like the fitting has distorted for some reason. As its unlikely to be the cable that has distorted (you could try someone elses?) I think the best solution is to buy a card reader (they are very cheap nowadays) and use that. Some people do this as a matter of course to save wear and tear on the camera anyway.
Hope this helps,
Marti
Sep 19, 2009 | Olympus FE-370 Digital Camera
Olympus FE-370 I have 10 pictures on the camera (tok pics without realising there was no card inside!), but I cant seem to save them to the memory card - I have lost the lead for the camera. Is there...
See page 34 of the manual (available for free download from Olympus below).
http://www.olympusamerica.com/files/FE-370_X-880_C-575_Instruction_Manual_EN.pdf
Or in short, select the "Setup" (tools) menu, and then select "Backup". You'll need to have the memory card installed for the transfer.
Jul 04, 2009 | Olympus FE-170 Digital Camera
Internal memory
The camera has a Memory Back-Up function located in the Play menu. Please refer to the Reference Manual on the CD-ROM for this procedure.
Aug 31, 2005 | Olympus Camedia D-370 Digital Camera
Olympus FE-170 Digital Camera Logo
57 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
