Hi my defy 600 automatic Daw 322 when I press wash it's turn off all plugs
    Top Expert:
  • Washing Mach... Master
  • 60,416 Answers
Call a repair service locally
Posted on Mar 15, 2019
  • 24 Answers
SOURCE: When I start the machine
remove hoses going to the back of the machine. There should be little screen filters inside where the hose goes. Remove them and clean, replace the hoses... This should fix the problem.
Posted on Aug 13, 2010
  • 6277 Answers
SOURCE: My Defy DAW 317 trips
Sorry but with such a fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer.
It could be the main motor as primary suspect, internal wiring/plugs sockets, control panel switches, control PCB, water inlet control valves.
I fear that you only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
Posted on Mar 16, 2011
SOURCE: WIRING DIAGRAM FOR A FRONT LOADER WASHING MACHINE
Diagram of internal wiring of ariston AV41washing machine
Posted on Mar 20, 2011
  • 6277 Answers
SOURCE: defy daw 366 washing machine
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 03, 2011
  • 75 Answers
SOURCE: Hi, I own a Defy Automaid 600 and when I run a
Hello
Remove the detergent tray and look in to the top were the tray goes in there is a water dispenser there with a lot of hole check that non of those holes are not blocked, if so use a tooth brush to clean the holes.
Thanks
Posted on Jun 15, 2011
My Defy Automaid 600 DAW 317 keeps flashing Pre wash light, door light stays on. The machine is not responding to anything. How do you reset it manualy and what might the problem be?
I don't know the model, but most electronics and hvac can be reset by simply turning off the circuit breaker. wait a few minutes and power it back on. I don't think you'll find another reset on it.
Mar 15, 2018 | Washing Machines
Hi, i am getting an E6 error on my defy washing machine mode DAW 327, what i causing this and how can it be resolved?
go to the manufactures website and download the user manual and go to the trouble shooters guide to find the answer eric
Jan 11, 2018 | Washing Machines
My defy daw 365 front loader washing machine won't start. The "end" indicating light stays on and the "door" light does not come on.
hi we just bought a second hand defy front loader washing maching can you please assist us how to use ot its Defy Daw 365 please
Feb 24, 2013 | Washing Machines
Our defy automaid 600 daw 322, will wash, but will not spin or rinse
My Defy Automaid 600 spin and drain without washing but only drain and do not spin with washing in (i have put only 1 t-shirt in - and still don't spin)
Jan 23, 2011 | Washing Machines
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
