SOURCE: remote does not work when plasma tv is on
It is a very strange case that you have.
I think that bose is correct, there is definetly an electromagnetic interference with the system, but the strabge part is that panasonic plasma tvs are not supposed to emit such EMI and they should be shielded.
one advice is that to verify this try putting on the tv, and bring a portable radio close to it and see is there is a change in the sound, if there is one, then definetly your tv is emitting EM fields. this could be due to a factory defect in the tv, have it checked by the retailer where you got your tv.
a second solution is to place the receiver of the bose system further away from the tv and try using both of them.
SOURCE: panasonic viera tv won't turn on. Power light
hello, you have a either your su, sd or sc boards fualty and it is a driver sos1 thats what the manual reads the best thing to do if your not electronically inclined or able to fix it is to get a service manual and make sure it is for your specific model and size you will find what the 7 blink codes mean, on my side i have a 42 in pana the service manual for this set and your is similar so since it is not the same model i cant tell you exactly what the truoble is but your best bet is to find a service manual find the 7 blink fualt then without getting ripped off you will know what the service man needs to do if you dont know or cant replace the parts yourself that is besides having to download firmware from your computer to a sd card and update your set but you need to solve the blinking code first it may solve the entire issue. the tv should come on when you resolve the blink codes or replace the fualty board or boards
SOURCE: Panasonic plasma 50PZ85 power led blink 10 times
Either a bad power supply or a bad processor board.
A Good Service Shop should know what the 10 blinks are indicating.
May be a repair cost between $200 and 400 dollars.
Be prepared -
Blessings,
A/V Media Guy
SOURCE: I have a panasonic 50 inch plasma th-50pz80u.
try to check power supply look for swollen capacitor it is the common trouble of plasma and lcd.
SOURCE: I have a Panasonic model
hi,
In your tv there some problem with power supply. you have to check the followin voltages. Sub 5v SOS ,Main 3.3v SOS A-Board,DTV 9v SOS , Tuner Power SOS. If any one of the voltage fails it will shows 10 blinks.
ok
