Question about JVC Audio Players & Recorders
My JVC TV (LT-55n776A) keeps rebooting, it seems like the software is corrupt. It doesn't even get to the home page. I tried very resets, no joy.
Any firmware or software that I can reload via USB stick?
SOURCE:
bluegreenash
  • 661 Answers
SOURCE: Firmware Upgrade Problem
the code 37,024.42 suggests a hardware failure
according to the error code manual
https://www.office.xerox.com/partners/products/Phaser8500/SQRG/03_error_codes.pdf
Drum heater relay board disconnect.
Both drum heater relay coils are not drawing the expected power from the supply.
I hope this helps
Posted on Sep 27, 2008
Geekman
  • 32281 Answers
SOURCE: Linksys WMB54G: No Connection Via the Software Utility
It appears the configuraion IP address you are using is wrong it should be 192.168.1.100 or 192.168.1.1
Posted on Jan 03, 2009
SOURCE: can't connect to usb port
Hi all! I had the exact same problem - the remote recognized the USB connection but my computer (MacBook with Leopard) / Logitech software did not.  I took the advice of  bfuzcsvxvgk  and it worked like a charm.  I wasn't sure what the "Home" folder that he or she referred was, so instead I entered "Logitech" into the Spotlight finder and the Logitech folder came up.  There was only one file (usblancognac.cmd) in the folder and I deleted it. After that I reopened the Harmony Remote software and it opened! THANK YOU THANK YOU THANK YOU!  Hope this helps if you are having problems!
Posted on Jan 16, 2009
  • 105 Answers
SOURCE: REmote control RM-C1257G not working even after trying new batteries
Try this
1. Get camera phone
2. set camera phone to to take picture
3. point remote at camera and look at the camera display
4. press buttons on the remote, you should a light from the Remotes IR.
5a. If NO light is seen, your remote is broken. you can try replacing the batteries to double check
5b. if Yes, light is seen. Your remote is working and you may have a problem with the TV.
As a double check, get a remote you know is working and try the same thing to verify that you are checking the remotes correctly.
Posted on May 27, 2009
  • 308 Answers
SOURCE: Corrupted Firmware on Philips HTS3555 Home Theatre System
Only posibility is finding a service shop that services Philips....
Posted on Mar 23, 2010
I Have a 2year old JVC LT 24c340 HD which switches off after about 15 minutes , then after a minute or two the standby light comes I have reset the 'TV to factory mode but it still switches off
warranty requirements , on hidden defects.
no defects are expected within 4 years for just domestic use.
call your dealer , write to the importer, about the fault its not a JVC point to make products for only 2 years lifetime.
JVC LT 24HS340 Instructions Manual Page 2
Nov 18, 2017 | JVC Televison & Video
How to reboot cherry mobile spark tv?
Here`s how to hard reset you Spark Tv
1. Turn off the your Cherry mobile Spark
2. Press power button, Volume down and home button at the same time.
3, Wait for a Spark TV logo then release power buttons and continue holding Volume down and Home.
4. Scroll down and select wipe data then press home button
5. Select reboot and your phone will be unlock but all files in the internal storage will be deleted.
or try this
SPARK TV cherry mobile HARD RESET too many patterns attempt solution
POWER ON + VOLUME DOWN BUTTON press together in 20 seconds or until the Android system recovery <3e> appeared
Press volume down to wipe data/factory reset then press power on
Press volume down Yes -- delete all user data then press power on
Press power on to reboot system now
After reboot HARD RESET was done
May 20, 2014 | Nokia E Cell Phones
37" JVC LCD Stuck at logo
Just do a hard reset to this set and check. It seems that, the software has been corrupted. In most cases, a hard reset should make it right. Unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so. This must make it a hard reset. If this do not help you, a software update might be necessary. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Pull up older posts there, either by its left side bar, or see it in Timslide option.
Jun 23, 2013 | Televison & Video
JVC TV (LT-32E478) Stuck (loops) in standby mode...? Buttons on TV have no effect... Will not turn off?
Do you mean the JVC Logo keeps appearing?
If so, call JVC for the software update. I believe it may even be posted on their site. You can check in the TV menu to verify. You should have F108 or higher.
If the update doesnt apply, you need a Digital PWB for the TV because it is defective.
Apr 24, 2009 | JVC LT-32E478 TV
JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
You most definately have bad capacitors in the power supply. try and get it repaired as soon as possible, not an expensive repair that iv'e seen.
Feb 04, 2009 | JVC LT-32P679 32 in. LCD TV
Hi , I have the same problem with my LT-42X688,so i called the service of my extended warranty provider . the TV technician just left and told me the motherboard is the problem. he said its the third one this week he has seen with the same symptoms. he ordered the motherboard and i've got to wait 5 to 7 work days before the part will be in . I will keep you posted when the guy will return.
Jan 02, 2009 | JVC LT-42X688 42 in. LCD HDTV
No video input -- all ports -- for JVC LT-37X688
JVC may allow warranty exception or some accomodation for 15 days out. You have 2 seperate issues
1. White lines spreading is probably a video process problem. I think this TV has 3 Boards inside. Middle one is most likely suspect followed by the one on the Right
2. HDMI input not working is because they were turned OFF. JVC TV's have a sensor that will shut off the HDMI if the TV's back cover is removed. This must be reset in the Service Menu.
Nov 16, 2008 | JVC LT-37X688 37 in. LCD HDTV
After power outage, TV screen is blank
It sounds funny but, unplug the set for 30 seconds to allow the TV to reset then see if the problem still is there.
Apr 10, 2007 | JVC LT-26WP84 26 in. LCD Television
42 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
