Question about Toshiba Satellite A75-S211 Notebook
Port using loader 2 comp port won't open
  • 89 Answers
Re: port - Toshiba Satellite A75-S211 Notebook PC Laptops
Why not???
Posted on Jan 11, 2008
0 characters
3 Points
LG laptop usb ports not working
do you have the program needed to get what you have on your flash drive? If you don't have a photo program or pdf program or what ever to open it, it won't work. try connecting something else that uses USB port to it and see if that works, then you will know if its a program problem or your computer. if its the computer, you can replace it.
May 07, 2012 | PC Laptops
Dvd won't play
Go to default programs set your DVD player to open and auto start all video. So that when you place a DVD or CD in the drive it will auto load without you having to keep right clicking and opening the video. What may be happening is you may be clicking to open to many times and it has to catch up to open the video possibly. I would go that route and see if this fixes the matter. John
Apr 14, 2012 | Dell PC Laptops
Pc won't accept printer via usb connection
So why won't it accept the printer? Is the printer and your operating system on the computer compatible? Did you install the printer and drivers? Are you sure the USB Port works?
Have you tried a different USB Port?
Click Start/Control Panel and look for Printers. Open it and make sure you don't have more than one instance of the printer installed. If you do, then you're confusing the computer. You can also check to see if more than one of the same printer is installed by opening a word document, then click File, then Print, and when the print window opens up click the Down Arrow on the line that shows the printer name. This will show you all other installed printers.
Mar 25, 2012 | PC Laptops
Usb port won't recognize mouse
the usb port may be damaged or bad solder connections, do a system restore taking the it back before the problem occured. "long shot"
Mar 19, 2012 | Toshiba satellite c660
Toshiba Satellite L305D-S5882 has two RAM ports for 1GB &2 GB DDR2 800MHZ, one got spoiled, am now using 2GB RAM, can this single port operate with 4GB RAM?
Unfortunately, the slots on this motherboard are limited to a max of 2 GB each. You won't be able to use a 4 GB DDR2 800MHz memory stick with this computer. (This limit is due to the way the circuitry/programming of the board was designed.)
I wish that I had better news for you. You might be better off installing a Unix based OS which uses less memory or searching for a new laptop. Just remember to save your files on a different drive before making any changes.
Jan 30, 2012 | Toshiba PC Laptops
Aspire 5100 wont save when i shut down
It appears that the C dirve is using 98% of space. Let us try to delete some temporary files, to do so, click Start Menu> Run> type %temp% and hit enter. It will open the temporary folder, delete all the files listed in this folder. Now, again click Start> Run> type prefetch and hit enter, it will open the prefetch folder, delete all the files listed on it. It should take care of the issue.
May 20, 2010 | Acer Aspire 5100 Notebook
Power Surge on Hub Port
Don't Use existing USB Portn On your Comp if u want USB port then install PCI USB Card From the PCI USB card you can use your USB Device what ever you want to use
May 29, 2009 | Compaq NX6110 TFT XGA Notebook
Buzzing/humming sound when mic is inserted while on AC power
if its not usb mic you will have the humming
if it is a usb mic the port that you connected to needs a mic to be further away from comp your picking up a static charge from comp to mic
May 26, 2008 | IBM ThinkPad T30 2366 Notebook
My Com Port keeps on failing, which causes Loader 2 for my ViewSat Dish , not work and that is a problem because i need to enter a code into the cable frommy computer.
On the loader program go to fileicon then auto find com port or just try each comport setting example com port 1 comport 2 and so on till it works hope i gave you a fixya:)
May 05, 2008 | Acer Ferrari 5005-5832 Notebook
Toshiba Satellite A75-S211 Notebook Logo
14 people viewed this question
Top Toshiba PC Laptops Experts
Brian Sullivan
Brian Sullivan
john smith
Are you a Toshiba PC Laptop Expert? Answer questions, earn points and help others
