Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpood LSR8233EQ0 washing macine
We can see that the belt is shot. What is the easiest way to replace this?
  • Oldmill Feb 23, 2008
    So if this model doesn't have a belt. Then what do I see that looks like a belt?
  • 196 Answers
I'm not sure how to respond because this type of washing machine does not use a belt.
Posted on Jan 02, 2008
Want wash or spin
I need more info about the machine. Does it make any noise when the start button is pressed, if you can hear the motor turning then more than likely your belt is either after slipping off the drum or breaking. you should be able to access the belt either by the back of the macine or the top to see if the belt is broke or just after slipping. Another problem it could be is that the capacitor in your macine could have blown. To test this you press start, open the door of the machine, spin the drum by hand and close the door before the drum comes to a stop, if the drum continues to rotate after you close the door then you know it is the capacitor that is blown, this needs to be replaced either by an electrician or a specialist as it is possibe to connect the capacitor wrong and the result would be the capacitor exploding damaging your hand. Always plug out the machine before opening the top or back of the machine.
Dec 28, 2013 | Whirlpool Estate TAWS750PQ 27-Inch Washer
My Whirlpool LSR8233EQ0 washing machine making loud whining and banging noises during spin cycle only...any ideas on what to replace?
Two possibilites would be a loose agitator (some agitators can betightened from the top, check for tightness)If you can't tighten the agitator from the top, turn the machine over ( you will probably need to disconect water hoses first) and check the underside. From here you should be able to determine if the agitator is loose or more likely you've got a loose drive belt.
Nov 16, 2011 | Whirlpool Washing Machines
I have a top loading Maytag Performa washing machine and the tub doesn't spin
You will need to replace the belt on the machine. This is a fairly easy job, just go to an appliance repair shop, tell them the model number and they will get you a new belt. Then lay teh macine on its side and replace the belt. There should be a routing diagram on the washer, and if not you can get on online.
Mar 19, 2011 | Maytag Washing Machines
Whirlpool LSR8233EQ0- The load is still wet after spin cycle
Inner tub loose or bearing or stem is bent. Check belt for oil or wear.
Oct 20, 2009 | Washing Machines
I need to replace the belt. What is the easiest
tip machine on it's side, than remove the bottom panel, you will now have access to the belt.
Jun 22, 2009 | GE Washing Machines
Screaching on all spin cycles
lean it back take off the belt turn the pump in both directions by hand. then motor and transmission pulley.unplug it first! my moneys on the pump :)
Jun 13, 2009 | Maytag Performa PAV2200
Washing macine balance
Adjust the legs on the washer that seems to be the problem. Or you could have broken the hinges and springs on the tub itself. The easiest thing to try is the legs first they just twist like a screw
Feb 09, 2009 | Kenmore Washing Machines
The washer doesn't spin out the water. Clothes come out soaked?
if it washes ,,check your lid switch,,if it doesnt wash and spin check your motor coupling...onthejob
Jan 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
213 people viewed this question
Dan Webster
Dan Webster
Sal De
