Question about Hobart Food Mixers
I have a Hobart 4346 mixer grinder it mixed and grinds good just when you put it on mix only it makes a loud clunking noise
SOURCE:
  • 274 Answers
SOURCE: Grinding Noise
If it's metallic sound you are loosing teeth on a gear or two.  This is caused by lack of lubricant or simply fatigue of the material of the gears.  Don't use it, you can get metal flakes in your food.
Take it in to a repair shop and have it fixed.  The money spent is well worth it because if done correctly will last another 12 years.
Posted on Oct 23, 2007
  • 25 Answers
SOURCE: kitchenaid mixer mades a high pitch squeak when mixing
Take it to a local repair shop and they should be able to fix it in no time.
Posted on Mar 26, 2008
ricardok45
  • 135 Answers
SOURCE: KitchenAid 600, Stand Mixer -
Hi. Stop using your mixer. If your mixer is still covered by warranty, call Kitchenaid Customer Service, they are very good with warranty repairs.
If your mixer is out of warranty, remove the silver band that surrounds the top of mixer. Remove the top cover. At the front of the mixer, locate the transmission housing which is now exposed. Examine this housing carefully for cracks. If you find cracks anywhere in this housing, you have found the under-engineered plastic transmission housing. Kitchenaid's replacement housing is made of metal. Your plastic housing has no business being in a mixer that is marketed as being able to mix bread dough. It cannot!
If you're confident that you can make the repairs yourself, go to the Kitchenaid website and download the parts drawings. Remove the Trans. housing, remove the worm gear shaft assembly which is driven by the motor.. Remove and save as much grease as necessary to thoroughly inspect the worm gear. Inspect the worm shaft bearings. Look for cracks, or missing pieces on the bearings. Look for crunched cogs on all gears. Be prepared to wait at least a month for your parts to arrive after you order them. The replacement grease should be Shell Darina 2, or Chevron FM ALC EP 2.
If you're not confident about repairing this yourself, call Kitchenaid and determine the nearest "approved" repair shop.
You may be able to pressure Kitchenaid to pay for the damaged parts in your mixer. They are still installing these plastic Trans. housing on new mixers. Insist on a metal cover when replacing. Apparently, Kitchenaid feels no shame in their manufacturing process, and will not issue a recall notice for these housings. They are substandard at best.
If you found this solution helpful, please rate it. Good luck! ricardok45.
Posted on Feb 13, 2009
  • 109 Answers
SOURCE: Hobart Mixer bowl won't go up
If the worm screw is turning but not lifting the bowl, the bowl lift nut is stripped.
H600 part number is 24198.
To change it, you need to undo the screws down the right side yoke slide to release the yoke. You will need to lift the yoke to reach some of them. If you have some wood place it under the yoke and over the legs to protect the paint. On top of the yoke are two blots holding the keeper plate over the nut. One is the stop screw for bowl height. Don't loose this setting. remove the slide, edge the yoke forward a bit to free the worm. Run the old nut down the worm and off the bottom. When you run the new nut on, all the excess grease and metal shavings will start to build up. Clean as you go, or better still, brush with solvent or similar to clean the worm threads . relubricate, run the nut up above the yoke, reload the yoke and attach keeper plate, reload slide.
To adjust slide, snug screw near bottom keeping slide close to yoke, run yoke to top and tighten top screw just enough to hold slide in place, lower yoke to bottom, gently tap top of slide in a 1/16" and tighten top screw. Run yoke to top of slide. It should start to bind slightly in the last 2 inches of travel, which will stop the bowl from dropping in use. Tighten remaining screws.
Posted on Aug 08, 2009
hslincoln
  • 235 Answers
SOURCE: Kitchenaid mixer motor makes loud grinding,
lgardash, Are you sure it's the motor or could it be the transmission?
It 'sounds' like you've got some transmission gear issues, and a situation similar to my wife's mixer, which we got new in Dec 2006. (Within a week of her first using it, she contacted KA Customer Care and the only 'care' they offered was an explanation that the new KA Pro Mixer gears are all metal and to expect it to be louder than previous models that used a plastic gear (to fail). Well, there's an acceptable level of noise, and an unacceptable level (you don't need to be a mechanical engineer to know when something doesn't sound right) and it seems that my wife's new mixer's operating noise level was always unacceptable. It finally 'died' this past October.) OK I've vented enough on KA... now what might be your problem(s)?
It could be as simple as thorough normal use the gears have shifted slightly in the transmission and the gear teeth are making different contact, hence the grinding/squeaky noise. The higher the speed, the louder, higher pitched sound you'll get. Alas, the noise may also be indicative of a potential gear failure (after our mixers increasing noisiness, the bevel gear broke and the mixer 'froze').
If your mixer is under warranty, contact Kitchenaid. If it's out of warranty, then take it apart and do a diagnostic exam of the gearing. Whatever you find you should be able to fix yourself. Be sure to have the Kitchenaid Part Manual (Part No. 8212278 Rev D) on hand if you attempt to disassemble yourself. It also lists all the parts so that you can determine, which parts, if any have failed. You'd think that the Kitchenaid name would warranty their mixers for a lifetime... So much for quality in America today!
I hope this helps, and good luck! - Howard, Burke, VA
Posted on Nov 03, 2009
Kitchen Aid HDPro 5 quart bowl lift mixer is making clunking, rattle type noise when mixing anything heavier than egg whites.
You are probably going to have to remove the top housing and look and listen while it is running. Does it lose drive when it is being noisy? You need to remove the back cover, the silver band with Kitchen Aid on it and that will expose the 4 screws holding the housing on. Remember fingers and tools OUT while it is plugged in or running. I can't be a lot more help to you, we don't have that model in NZ.
Mar 07, 2014 | KitchenAid Professional Heavy Duty Series...
How to pull auger drive shaft for Hobart 4346 mixer-grinder?
The oil seal is the resistance you feel. take a soft mallet or hammer with a soft drift and gently but firmly tap the stub shaft and it will drive out the oil seal in the hopper direction.The lower skirt of the tapered bearing is what contacts the seal so go slow.
Worked for me.
Jan 23, 2013 | Hobart 4346 Meat Grinder Mixer Chopper...
Need to adjust clutch on hobart 4346 meat grinder how do you do it?
On the 4346 mixer/grinder the clutch can't be adjusted. It is a Moorse clutch and will need to be replaced. If you ate handy buy the rebuild kit for the bottom end from Hobart. It's not cheap but once it's done it will last for years. Hope this helps, Food luck
Dec 16, 2012 | Hobart 4346 Meat Grinder Mixer Chopper...
What can you use for a hobart h600
The Hobart H600 is a 2 horse power, 60 quart mixer, it can be used for many things in the kitchen. It can be used to make about any kind of food that needs mixed, wiped or kneaded. It works well in a pizzeria for all facets of making pizza from the dough, to shredding the cheese with an attachment, to a restaurant that makes mashed potatoes and fresh bread, to a full service bakery.
However, the biggest thing that you need to know is the capacity of the machine. As overloading the machine can cause damage that may be costly and take a technician to fix. I do not know what attachments you currently have so I will go over a few of them.
The main attachments are a Wire whip, Flat beater, and Dough hook. There are three different types a "D" wire whip (has many wires and is evenly spaced) this is used to whip egg whites, whipping whip cream, etc. The "C Wing" (has six tines in it) is used for items that are heavy for the D wire whip, like whipping potatoes or icing. The last is the "I" whip is similar to the D wire whip just with less tines. The flat beater is used to mashing or mixing examples are mashed potatoes before they are whipped, cake mixes that do not require whipping, batters and icing. The Dough hook is used for kneading dough examples are pizza dough, bread dough, etc.
The biggest thing when using your mixer is to know its capacity for the material that you are mixing. All though this is one of the bigger machines it still has limits. You should refer to this the following link for the capacity of your machine:
https://my.hobartcorp.com/resourcecenter/ProductDocumentation/F-7701.pdf
There are also a few attachments that can be put on to the No. 12 attachment hub. A few of these are a vegetable slicer-grater and meat grinder.
Mar 04, 2011 | Hobart H600 Stand Mixer
Makes clunking noise when mixing or using attachments. Gear slipping?
Hello Angelfyro72,
Does the machine make the same noise when there is nothing attached to it at all? I have a few suggestions but I need to know this first. I do not believe that it is a gear but actually in the backend of the unit. Please post back to this discussion thread.
Thank you for chosing FixYa.com
Mar 03, 2011 | KitchenAid Food Mixers
I bought a used Hobart A200 20 quart stand mixer that hesitates or 'gets stuck' when mixing dough or other thick (hard to mix) material. When running without a load, or only a light load it doesn't stick...
First of all, I want to say that it is common for people to overload the A200 mixer when mixing dough. The owner's manual gives an extensive chart for various substances typical of what people may mix. Depending on the consistency of the dough, the maximum batch size varies, but as an example: 9 lbs. max with 40% absorption ratio thin pizza dough, 1st gear only, 5 minutes maximum mix time. I remember this particular batch size/specification because as a technician who works on these mixers frequently, I had a customer attempting to mix 20+ lbs. of that 40% pizza dough for much more than 5 minutes and didn't understand why the mixer would stall and why his mixer was so hot he could nearly cook eggs on it's transmission case. So, a word of caution (9 lbs. at 40% A.R. is approx. 7 lbs. flour, plus the water) about overloading these. If used to mix reasonable batches, they are excellent mixers and will last a lifetime (I regularly service 40-50 year old A200 model mixers that run very well).
If you don't hear any grinding when it's stalled (which would indicated stripped gears, damaged keys, etc. in the transmission) I would say you are overloading it. Many people want to say the motor is weak when the mixer stalls, but unless the motor has been repeatedly and severely overheated to the point of shorting some of the motor's windings, that's not the case. I suggest finding the recommended capacity chart from Hobart and abiding by it and you'll love your new mixer for years.
Jan 04, 2011 | Hobart A200 Stand Mixer
Kitchenaid professional....
It sounds like you need to change the brushes. You can look up your parts manual online here and then buy them online. Should be under $10.
Aug 16, 2008 | KitchenAid KSM50PR Professional Series...
N50 with loud noise in operation
if you just had it serviced i would take it back to them.heres the site for an exploded parts view. http://www.hobartservice.com/Manuals/ to repair this yourself is a task if your not familiar with this mixer.i work for hobart and can give you any other info you may need.
Dec 16, 2007 | Hobart N50 Stand Mixer
Food Mixers Logo
60 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
Steve Allison
Steve Allison
Bruce Showalter
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
