Having difficulty spitting the housing to remove Hard Drive
Toshiba Series 2800 Satelite. Error message "No Hard Drive" :-) I must check this for a friend.
  • Cuzinjak Nov 27, 2007
    Thank you for your help with this problem. Guess what? When I looked in the appropriate place, there was no Hard Drive!!!?
    This is the rest of the story: my friend is a doctor and his hard drive contained personal information which had been deleted but needed to be wiped. Apparently the Tech forgot to replace it. :-)
    ALL of my experience is with desktops so your help was doubly welcome.
    Regards,
    Cuzinjak
    Brigadier General:
  • 6,966 Answers
This is indicative that your motherboard through the BIOS/CMOS is not auto-detecting the presence of a hard drive. Though this should be automatically done, you can try manually detecting by going to the CMOS/BIOS setup and verify that it can be physically detected. If not then you would need to replace the defective hard drive.
Most Toshiba hard drives are inside a slot either on the side or front. To gain access, you need to turn over the laptop and look for a panel/lid covering that is lacked in place by7 1 or 2 small screws. After removing the plastic covering, the HD would be exposed and should be relatively easy to remove. In vertain versions/models, the HD might also have a locking small screw or a pry open lever or bar.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Nov 27, 2007
  • Louie  Role
    Louie Role Nov 27, 2007
    Hi again,
    Appreciate the rating and glad to be of assistance.
    Cheers.
Hitachi HTS547564A9E384 ATA hard drive failure on toshiba satelite
The hard disk is about to fail completely. I suggest you backup your data before the hard disk fails completely.
Dec 29, 2012 | Computers & Internet
When i boot up my laptop i am getting the error message, "operating system not found." Can you please give me advice on what to do to fix my laptop? Toshiba laptop and im scared i may lose the things
Your hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Nov 30, 2012 | Toshiba Computers & Internet
Toshiba satellite notebook error 10-FC06-000D system windows vista
When dealing with this error (10-FC06-000D) message in Toshiba unit is very comment in the L300 series, I don't know if Toshiba is using cheaper hard drives or what but I see a lot of them with the same problem. If you have a Toshiba unit got to their website to check if your unit is still under manufacture warranty if it is you have some options send it to Toshiba direct they should cover the shipping but I'm not to sure, or take it in to any Best Buy or Future shop stores with your proof of purchase and they will send it out for you. This is a hardware problem that is related to the hard drive, I wiped the hard drive and all it's boot records still unable to reinstall the OS OK, I finally decided to use a test hard drive to reinstall the OS worked fine so there is something wrong with the hard drive that most likely would need to be replaced
Sep 11, 2012 | Toshiba Satellite P35-S611 Notebook
How to fix error loading operating system on toshiba satelite m115 laptop
Go into the BIOS and check if the BIOS detects the hard disk. If not then most likely the hard disk has failed and the hard disk needs to be replaced then Windows needs to be installed on the new hard drive plus the Toshiba M115 device drivers and your programs/software.
Feb 02, 2012 | Toshiba Satellite M115-S1061 Notebook
Toshiba Satelite Asos screen is blank after logon
This indicates a hard drive problem, but! first remove the hard drive and re-seat it back in place, "sometimes it goes out of position" and is enough to restart it, if no change! use your recovery disc to reload windows. Now! if it fails to load up chances are it is probably a bad hard drive, but I recommend having it tested before replacement of the hardware.
Apr 01, 2011 | Toshiba Satelite 5205-S505 Notebook
Hi, im having problem with my hard drive, dell inspiron 1525. when i boot my laptop i got this message " to resolve this issue, try to reseat the drive". I badly need your help. thank you
The laptop is having difficulty connecting the hard drive. The hard drive may be faulty, but you don't know until you re-seat the hard drive.
Remove the hard drive from the laptop and insert it back, do this a few times to ensure the hard drive makes proper connection to the laptop's motherboard and then boot up the laptop.
If you are still getting this error message then you probably have a faulty hard disk, then this need to be replaced and Windows installed on the new hard disk with the Dell laptop's device drivers and your programs to get a working laptop again.
Please let me know how things turn out.
Oct 30, 2010 | Computers & Internet
I was trying to do a recovery on my pc when an error message popped up saying that the disk couldn't be read after conducting 10 minutes worth of recovery. I think the problem is the hard drive because...
Easy--you remove the old hard drive and put in a new one.
On the bottom of the computer there are several little compartments. One houses the hard drive. You unscrew the door and remove the drive. This could be a SATA or a PATA hard drive. You can tell when you remove it. Ask here and we can help you further.
Dec 22, 2009 | Toshiba Satellite A45-S150 Notebook
Cd/dvd problem on toshiba m45-S165 laptop
Is you new hard drive lager than you old on and was the disk drive a factory replacement cause with those disks if you even change just that they will not work
Dec 09, 2008 | Toshiba Satellite A45-S250 Notebook
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
