Question about Hotpoint Washing Machines
Hotpoint tall fridge rlfm171p how do i remove the thermostat it on the top front panel of fridge, no apparent screws or visible means of removing facia panel?
    Top Expert:
  • Hotpoint Master
  • 779 Answers
Posted on Mar 15, 2019
  • 90 Answers
SOURCE: taking cover off dryer
open door and look for screws going up into top
Posted on Jan 06, 2008
pishta68
  • 594 Answers
SOURCE: How to disassemble case.
Pry the metal spring clip in the base of the hotshow toward the rear of the camera with a pocketknife, itll pop out and there will be 4 small screws under there, Ill put a buck on that bet. The hotshoe needs some good anchors to support some beefy flash units so it has screws to hold it down, metal hotshoe to metal chassis.
Posted on Feb 07, 2008
  • 90 Answers
SOURCE: How to remove top panel and front facia on a Hotpoint Aquarius WDF451 washing machine
Un plug it. There should be small screws either at the bottom of the panel on the front or there is separate panel that comes off the top back. If the back is one solid piece top to bottom, then the control panel lifts out and hinges up when the two small cross tip screws are removed from the bottom outside corners of the control panel..
Posted on Feb 10, 2008
  • 1462 Answers
SOURCE: How do I remove cover from fridge temperature control panel?
lever off the thermostat knob and you will often find fixing screws behind. also, fixing screws are often hidden behind little blanking plugs which lever out to expose the screw head
Posted on Jul 21, 2008
SOURCE: How to remove a back panel of maytag neptune dryer?
Catriver was right on the mark. Took a little bit of doing but I was able to fix the problem myself within 30 mins, and saved some money. Many thanks. I'd like to expand Catriver's solution a bit.
I found a layer of lint on the inside bottom of my dryer. With the face off of the dryer, it proved to be a good time to vacuum the lint out and reduce the potential of fire.
Posted on Sep 07, 2008
How to remove top on hotpoint dryer HTDX100EM6WW
Open the door and look upward at the lid under the front edge of the top panel. You will see either 2 or possibly 4 screws that face upward and are screwed into the top pane. Remove screws and lift front of top panel. May be tabs hooked at back near control panel on some models. Top just lifts off.
Feb 21, 2015 | Hotpoint Dryers
I cant get the back off hotpoint aquarius wma56 to change bearings
the back does not come off but the front does.
remove top lid ( two hex head screws on side of lid, under plastic covers)
take out dispenser drawer. reveils 3 screws
remove screws and slid front panel to the right (reveils 2 scrwes left and right)*
remove bottom kick strip ( reveils 2 more screws)*
undo door seal retainer, and remove 2 screws holding on door lock.
now remove 4 screws holding on front panel.*
panel now lifts up and off.
Jun 25, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
How Do you take the top off the Washing Machine Hotpoint WMA40
you need to remove the screws at the kick panel on the lower front panel by the floor, then the top cover screws are under top cover inside machine remove these and top will lift up
Dec 24, 2009 | Hotpoint WMA40 Front Load Washer
Hotpoint fridge freezer icing up freezer and fridge does not work
Does your model have independent thermostats for the fridge & freezer???
If not, could be that you will need to change the Thermostat.
These are not expensive - around £10 if you buy on the Internet.
Easy to fit yourself...just turn off the power, remove the power plug from the wall, then unscrew the 'stat unit from inside near the top of the fridge (some are attached to the interior light) and remove the screw holding the thermostat tube to the rear wall.
Often the thermostat gets a small hole somewhere in the long tube, which then lets all the gas escape, making the stat useless.
You can see these small holes in the pipe if you use a magnifying eyeglass, like the kind Jewellers use.
Nov 17, 2009 | Freezers
How to I remove the drum from a Hotpoint WM64 washing machine? I need to change the bearings.
Remove top cover and rear panel.
Remove belt and drum drive pulley.Remove clamp that secures door seal
Remove top control console panel.
Remove door lock.
Remove screws top and bottom holding front panel, remove front panel.
Remove spring clips holding plastic drum front, lift to one side plastic drum front cover.
Tap drum shaft to remove drum from container, remove bearings.
Please rate my solution.
Thanks.
Sep 04, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
to remove top, remove plastic luggs on each side carefully with a knife under which ther is a screw, this screw has a special head, this can be found in a screw driver attachment set avilable from any diy shop
Sep 10, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Model WMA 42
The 2 screws securing the top are located behind 2 plastic covers on the front top, remove these 2 covers and the screws are located there, you will need a torx screwdriver to remove the screws.
Sep 08, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Jul 21, 2008 | Refrigerators
Replacing thermostat
thats very easy first unplug the stove lift the top it should stay up with the arms extended,pull the arms out of the slot and remove oven top , gently pull knobs off , remove all hidden screws behind knobs, remove the front panel held in place by 2-3 screws on top and under panel, remove 2 screws holding existing thermostat unplug 2 wire thermost follow capillary to sensing bulb which is inside the oven unless it broke off it should be there, im asuming thats why you are replacing it ,remove sensing bulb from 2 brackets holding it in place make sure its perfectly straight because it has to pass through a small hole, installaton is the opposite of removal good luck.
Dec 28, 2007 | Hotpoint RGB524 Gas Kitchen Range
SAMSUNG RS21DCNS
speaking from memory: remove the middle translucent section held by one screw at top and clips. you will then see the additional screws you need to undo
May 07, 2007 | Samsung RS2630SH Side by Side Refrigerator
Open Questions:
Washing Machines Logo
26 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
