SOURCE: Will not start wash cycle
Check the door switch.if the door swith is defective
the machine will not start sometimes you can get
it to start by closing it several times till it catches
but if it completely shot then that wont work you
could pull the plug jump the switch and clost the
door and plug it back in the pause llight should
go out
SOURCE: dish washer 665.13824k601
LOCK LIGHT STAYS ON AND WILL NOT START. I HAVE TURNED THE POWER OF AT ELECTRICK PANEL AND IT STARTED ONE TIME. BUT DID NOT START ANYMORE.
HELP
SOURCE: my check engine check light keeps blinking
The 02 sensor after the the converter is telling you there is a fuel mixtue problem and the converter isn't burning it off. The cat converter itself can be the problem. Have it inspected.
SOURCE: My neptune washer is stuck in pause mode I can't s...
Karen,
Power it down by pulling the 120VAC power cord to the washer then plug back in and see if it will progress with the wash cycle. Which machine do you own the FAV6800A LED console display or the FAB9800A LCD console.
If still no good I will have you try to get into Service Mode but let’s see if a power cycle will clear the issue…….Rich
You will need the Service Manual for reference. Sears Parts Direct for reference.
Hello, kaamia
I
am trying to help you out here. Maybe this will help some? I am know on
Fixya as the cleanup expert pro. Which means I spend my own personal
time to seek out customers that maybe have not had there problem yet
solved by the other fantastic great experts. I do this on my own for
free. Think of me as a Specialized Trouble Shooter.
I have found
out that it appears that lots of customers appreciate my efforts and
help. So, I thought I would take some of my own personal time to
see if I can help you. Even though this Informational site may not have
your exact model or brand, But this site will help you a lot. Here is
the site link about everything you want to know about washing machines and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Please
if this helped you at all, if you can find the time and in your heart
to rate my help and some kind words written would be appreciated for my
free help, I would appreciate it. Like I said I
just try to help, If anything this is good information for future
problems. If you felt that my free help was a waist of time for you, I'm
sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.
Here
is also my direct link to my own pages of other areas of my expertise
for other problems you might have in Automotive, Appliance, and
Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
Thanks Mike
Hey friend, thank you for your post!
I understand that the start button on your Frigidaire washer continues to flash. This could be indication that the control panel has been paused or is miscommunicating. I would recommend performing a reset on your washer and you can do that by flipping the household circuit breaker off for roughly ten minutes. If you continue to receive blinking lights your control panel may need to be replaced. This however is not a simple DIY job and I would advise you to contact a professional technician for proper repairs. If you do not have a professional contact I would suggest looking over your manufacturer's website. Hopefully this helps to some degree. -Matt
WAKE THE WASHER BY PRESSING ANY BUTTON.
WAIT 5 SECONDS.
PRESS AND HOLD THE START AND PAUSE/CANCEL BUTTONS
SIMULTANEOUSLY.
ALL LED'S WILL GO BLANK AND AFTER A FEW SECONDS THE CONTROL
WILL SIGNAL THE STORED CODE USING AUDIBLE BEEPS AND BLINKING LED'S. THE CONTROL
WILL REPEATEDLY SIGNAL THE CODE, AS LONG AS THE START AND PAUSE/CANCEL BUTTONS
ARE PRESSED. A TWO-SECOND PAUSE BETWEEN REPEATS AFFORDS YOU THE ABILITY TO MAKE
ACCURATE COUNTS TO IDENTIFY THE CORRECT ERROR CODES.
PLEASE NOTE THE FOLLOWING: ON A SMALL NUMBER OF WASHERS WITH
SERIAL
NUMBER PREFIX XC4, IF THE PREVIOUS PROCEDURE DOES NOT PREFORM
AS
SPECIFIED, FOLLOW THE OPTION BELOW:
* FOLLOW ALL PREVIOUS STEPS BUT INSTEAD OF PRESSING START AND
PAUSE/CANCEL BUTTONS, PRESS AND HOLD OPTIONS AND PAUSE/CANCEL BUTTONS."
*THE CONTROL WILL PAUSE FOR 2 SECONDS, THEN REPEAT THE CODE AS
LONG AS THE TWO BUTTONS ARE PRESSED AND HELD."
NOTE: A LETTER APPEARING IN THE CODE STANDS FOR A NUMBER HIGHER
THAN NINE: A=10 B=11 C=12
D=13 E=14 F=15
"EXAMPLE CODE F1: THE FIRST
DIGIT WOULD BE 15 AND THE SECOND WOULD BE 1. IF THIS CODE WOULD APPEAR ON A
WASHER IN THE GOOD MODEL LINE, THE FIVE INDICATOR LIGHTS WOULD BLINK FIFTEEN
TIMES AND THE START INDICATOR LIGHT WOULD
