Question about Sewing Machines
The bobbin thread is loose and bunches up under the material i have a model 1030 and i dont remember where the tenson is
I have a model berinia 1030 the tnesion is to loose and bunches up on the bottom side and i do not no where the twnsion control is.
  • 1 more comment
  • Anonymous Aug 12, 2008
    Your solution was extremely helpful. It fixed my problem and saved me the trouble of going to the sewing machine repair shop. Thank you so much
    Trenice
  • alda347 Sep 12, 2008
    I am using Simplicity model 237. I have the same problem, the bobbin thread is too loose and it bunches up under the garment, i did everything as what the manual says. I adjusted the Thread tension from 0 to 9 but it comes out the same.
  • Anonymous Mar 29, 2014
    My thread bunched up under my project
  • 202 Answers
It is the dial to the right of the take up arm on top. If you go all the way to 10 and nothing happens then you'll need to take it to your nearest technician or Bernina dealership. Also its possible you may have put your bobbin in the bobbincase the wrong way. After putting the bobbin in the case and pulling the thread the bobbin should turn clockwise.
Good luck.
Posted on Nov 27, 2007
I have a Brother VX-1120. I'm not sure if I'm putting the bobbin back in the case correctly because the bottom stich is loose and bunches on the bottom side of the fabric. The thread breaks also.
Posted on Sep 13, 2010
My thread bunches up on my material
On top of the fabric? The problem is either the upper tension is too tight and/or the bobbin tension is too loose.
Under the fabric (thread nesting)? The upper tension could be too loose and/or the bobbin tension is too tight. Also could mean the upper thread is not seated properly in the upper tension disk or it is threaded incorrectly. Remove the thread. RAISE the presser foot. Then rethread from the beginning--verify the thread pathway is correct.
Aug 04, 2016 | Sewing Machines
I'm having trouble properly threading my Elna 1010. Could you please help? The bobbin thread keeps bunching up and breaking
bunching of thread under the material is an indication of insufficient tension of the needle thread
increase the needle tension until the threads meet at the center of the materialbeing sewn
Jul 26, 2016 | Elna Sewing Machines
Bobbin thread bunches up under material
make sure that the bobbin carrier is fixed in properly
make the needle thread tension a lot tighter
Jun 23, 2016 | Sewing Machines
Cotton is loose/looping under material?
Sounds like bird nesting.
The #1 thing is to install a brand new needle (old, worn, nicked, or bent needles can create a lot of havoc).
Remove all the thread from the machine. RAISE the presser foot and rethread from the beginning verifying that it is threaded correctly. Make sure the bobbin is loaded and threaded in the bobbin case properly.
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC
Why Do Get Bunched Up Thread Under My Fabric
8 Tips to Fix Birdnesting in Embroidery
Jan 28, 2016 | Sewing Machines
Can't get Juki tension right
which tension is wrong
if thread is bunching up under material increase the tension of the needle thread if the bottom thread is loose then increase the bobbin thread tension
each thread result for above or below material will indicate which thread to alter the tension on
Jul 02, 2014 | Juki Sewing Machines
Thread to loose under the material
try changing the needle
adjust the top tenison one number or letter higher, using a scrap
piece of cloth to check the stitches till they look normal
clean under the needle plate and in the bobbin area for lint
Dec 02, 2012 | Sewing Machines
Singer 758 model and the thread is bunching up from the bobbin under the material
try changing the needle--flat side goes to the back of machine
rethread the machine top & bobbin--make sure to use every thread guide
make sure bobbin is wound correctly & inserted correctly in the bobbin case
clean under the needle plate & in the bobbin area for lint or loose threads
if you don't have a manual try singer
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number(example 758)
Click search
Apr 10, 2012 | Singer Sewing Machines
The top thread just hangs and knots on bottom of material
try changing the needle-flat side goes to the back of the machine
check to see if the thread has come off the thread take up lever
try rethreading the machine top thread & bobbin
clean under the needle plate area & also in the bobbin area for lint or loose threads
Feb 20, 2012 | Sewing Machines
When i sew the bobbin thread bunches up. what to do?
remove the thread and bobbin.
take out your manual and follow the exact instructions for threading and inserting bobbin.
If this does not help check the tension on the top(the number should be about mid way).
If it is too low it will bunch up on the bottom.
Nov 12, 2011 | Brother LS-1217 Mechanical Sewing Machine
Thread is bunching up unside of the material does not catch bobbin thread
This sounds like the tension is not set properly for what you are sewing.
Oct 23, 2008 | Kenmore 11206 / 11306 / 11506 / 11606
Sewing Machines Logo
3,350 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
