Question about Baumatic Washing Machines
I have a Baumatic BDIF631 and I need to replace the Thermistor? where is it located?
    Top Expert:
  • Baumatic Master
  • 779 Answers
Hi. We have a baumatic bdw13 built in dishwasher, which is showing error code E6 (thermistor fault). Please could you tell me where the thermistor is located a whether it is easy to replace? Thanks
Hello Kristy!
A thermistor is a temperature sensitive resistor that "opens" (opposite of short) when it reaches a certain temperature and is installed to protect electrical equipment down stream. Why not just a fuse?, you may ask. Good question. A thermistor can tolerate a brief current overload that would blow a fuse, allowing continued operation following transient high-current events like motor start up.
While thermistors sometimes simply decide it's time to join their relatives in thermistor heaven, or wherever dead thermistors go, it usually means there is a steady, excessive load (failing motor?) in the circuit requiring attention.
Where yours is located is a mystery but I would guess it's under the machine near the motor. While I have attacked these issues myself, this sounds like a job for the big kids, especially since thermistors seldom just die.
All the best.
Nov 23, 2014 | Dishwashers
Freezer works refrige doesnt
Sounds like the thermistor is bad. Several ways to test.
1: Place the end of the thermistor that is located inside the refrigerator into a glass of slushy water and read the ohms resistance on the plug end which is located on the back of the refrigerator. Google the ohms resistance chart for Dometic thermistors and compare your readings to the chart. If they are not in range then the thermistor is bad and needs to be replaced.
2: Unplug the thermistor from the circuit board. It will be the harness that has only two wires going into a hard plastic plug. Leave it unplugged for 24 hours and check the temp inside the refrigerator. If the temp has dropped then the thermistor is bad and needs to be replaced.
To replace the thermistor remove the thermistor sensor end from the plastic clip. Remove the plastic grommet from the back wall of the refrigerator. Tape the new plug end to the sensor head of the old thermistor and gently guide it through the hole. Once the taped head/plug passes through the hole you may complete pulling the new thermistor through from the back side. Only pull enough to allow you to plug the new thermistor in. Un-tape the plug end from the head and plug the thermistor in to the circuit board. Reinstall the cover over the circuit board and reinstall the access pane. There will be some sealing putty on the old thermistor harness. Remove that and gently press it back into the hole around the new thermistor harness inside the refrigerator and reinstall the plastic grommet. Install the sensor end into the plastic clip and install the plastic clip between the first and second fins. The higher up on the fin the colder the temp will be inside the refrigerator.
Apr 12, 2014 | Dometic RM2852 Refrigerator
Domatic RM 2852 refrigerator compartment won't cool
1: Place the end of the thermistor that is located inside the refrigerator into a glass of slushy water and read the ohms resistance on the plug end which is located on the back of the refrigerator. Compare your readings to the chart. If they are not in range then the thermistor is bad and needs to be replaced.
Aug 15, 2013 | Dometic RM2852 Refrigerator
What microwave replaces the btm25ss baumatic builtin microwave. i need one the same size.help?
Contact Baumatic and ask if they have a "drop-in replacement".
Their contact information will be on your owner's manual or the dealer where you bought it should know.
Apr 08, 2013 | Baumatic BTM25SS Convection Microwave Oven
Need to replace the thermistor on my Savin 9945 DPE Copier- how do I access the thermistor unit? Where would it be located on the machine?
replacement of parts of copier is done by a technician, well if you could follow this you can replace the thermistor. open the right side and the front cove, the fuser is located on top of the OPC carriage unit, push the blue level going to the right side while pulling the fuser unit. after removing the fuser unit remove its the top and bottom cover. the two thermistors is located on top near the fixing separation claw beside the two thermal fuses. Good luck!
Aug 26, 2011 | Savin Office Equipment & Supplies
I have a Samsung Gas dryer DV337AGW/XAA. I have an error code that looks like a capital E with the top bar left off and 5. Went through the troubleshooting check list and no fix.
The error code is actually tS which means thermistor short circuit is sensed. The thermistor is located located on the blower housing and it requires the removal of the front panel to access it. Check for clogged lint screen and restricted vent system if the thermistor is found shorted or open then replace it.
Click on the link below on how to remove the front panel and get to the blower housing then locate and replace the thermistor with part number 35001191 or DC32-00007A.
Feel free to update us about the result and/or if you need further advice.
Jun 17, 2011 | Samsung Dryers
My Baumatic B180W-B oven does not heat up. The
If the oven is electrically heated, then more than likely, the oven element has failed.
This is located behind a removeable cover at the rear of the oven.
Feb 21, 2010 | Baumatic B187 Electric Single Oven
Where can i buy new Baumatic 7.3 GL cooker hood halogen lights at a good price
FIRST TURN OFF THE POWER TO THE HOOD UNIT THEN LOCATE THE BULBS AND REMOVE TAKE THEM TO THE LOCAL DIY STORE TO FIND REPLACEMENTS IF NOT FOUND THERE YOU CAN GO TO AN ELECTRICAL AND PLUMMERS SUPPLY STORE , GOOD HUNTING.
Nov 17, 2009 | Baumatic F60 Stainless Steel Kitchen Hood
Where can I get a replacement thermostat that iscompatible with the one in my Baumatic bf230ss fridge/freezer?
Locate the model and serial number on the fridge/freezer write it down then look in the yellow pages for a refridgeration supply business in your area,they should be able to help you obtain a replacement thermostat.
Sep 21, 2009 | Baumatic BF230 Top Freezer Refrigerator
Washing Machines Logo
Top Baumatic Washing Machines Experts
jimorris77
TriciaGirl
Level 1 Expert
Marvin
Marvin
Are you a Baumatic Washing Machine Expert? Answer questions, earn points and help others
