Question about Mitsubishi WT-46809 46" Rear Projection Television
Mitsubishi TV My TV was working fine until about a month ago, When I first turn it on, it has horizontal lines but after 10 minutes the picture is fine, can someone tell me what is going on or how I can fix it? Thanks in avance
  • 179 Answers
The fluid in the crt lens leaks onto the circuit boards..check for any wet areas or any gooey globs on the boards
Posted on Nov 29, 2007
TV works fine for a while, then the picture disappears.
I would just replace the TV, the parts are not going to be made to repair this. The set is just to old.
May 12, 2017 | Mitsubishi VS-5077/78 TV
the vertical drive ic that drives the yoke for vertical sweep has blown.
sometimes it is solder problems like sharp and toshiba had.
the part is 10$ the pc board will label it ,the yoke is the coil setup on the picture tube.if you follow the wiring half goes to the horizontal drive,and the others to the vertical section.the chip drives the coil directly.there are VERY high voltages in there ,even turned off. the pix tube cap on top is 30000v. like a stun gun.the horizontal drive 2000 volts and the main power supply 165 volts dc high need a special setup to discharge the picture tube.
May 15, 2009 | Mitsubishi CK-35308 35" TV
Horizontal Line through middle of TV screen
This is usually a bad elect capasitor or a bad solder connection on the vertical IC, The capasitors will be close to the vert chip..Sometimes you can clear problem with a light tap on the TV, if so then suspect bad solder.
Mar 31, 2009 | Televison & Video
Scrambled picture
Which caps on which boards as that sounds like a issue with the signal and FMT PCB. The v26 chassis like yours has problems with bad caps on the DM, Signal, FMT and the PWB and terminal
Jun 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Tv picture blinks on and off
Sounds like a cracked solder joint. I would check the flyback mounts , then the horizontal and verticle deflection ciruit componnents for cracked solder joints.
Jan 04, 2008 | Televison & Video
Red screen
sounds like a picture tube problem its a problem that probably cant be fixed only by a professional
Nov 30, 2007 | Sony KP-51HW40 51" Rear Projection...
Sound but no picture
Basic repair for skilled TV repairman = solder connections on
vertical output IC.........Can be done in home.....T.
Nov 28, 2007 | Sony KV-35S42 35" TV
Red lines, green lines, now static!
Uneven colors with multicolored lines in the center of the picture and/or flashing, C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002)
Nov 27, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Curved horizontal lines in picture
Its Sounds like Convergence Circuit,If you take the Back off and look on the right side you should see a Board with Big black Ics Mounted beside a Large Heatsink,Mark the wires where they go and Make sure the POWER is Off Pull the Board out and Inspect the Connections from the ICS,you find Circle Breaks,They need to Be resoldered and That should fix the Set....
Jul 20, 2007 | Samsung PCK5315RX TV
Mitsubishi WT-46809 46" Rear Projection Television Logo
41 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
