Question about LG KG800 Cellular Phone
LG and Vista
I cannot sync my phone using usb... is it because of Vista?
  • KeithRosa Nov 28, 2007
    What program do I use?
  • Leavy Dec 10, 2007
    I need Lg kg800 drivers for vista
  • 4,102 Answers
Hi vista shouldnt be the problem do you have the software for your phone installed on your comp as i have come across loads of problems with people not having the right software for their phone let me know if this is the case.
The one problem i did have with the usb port is when i was trying to use one of the ports i kept getting errors and i tried everything to solve it but to no luck,
Then the next day i plugged the usb into another port and found that it worked and to this day that one prot wont accept my phone but the other will, i dont know why but using the other port worked.
Let me know how you get on ok
Posted on Nov 27, 2007
  • paul proctor Nov 28, 2007
    Hi you could try getting the software off lg site itself if you dont have the software on your comp for your phone you will come across problems i will have a look for you and post back when i find anything ok let me know how you get on
Looking for USB Software for LG Rhythm
If you're using Vista run Windows Update with the phone plugged into your computer via USB. You should see an optional update appear pertaining to an LG driver or mobile phone driver (can't remember exactly what it says).
If you're using XP, download Microsoft Active Sync 4.5 and then run Windows Update with the phone plugged into your computer.
Jul 14, 2009 | LG VX8300 Cellular Phone
Can I sync my LG VU with Microsoft Outlook? If
Hi, you're right you'll need usb cable however bluetooth can be used as well.The usb cable is supplied with the phone. Vista use the new Windows Contact and Windows Calendar,but you can use MS Outlook if installed and you'll need MS IE v6.
Rate me if helped.Thanks.
Jun 18, 2009 | LG Vu CU920 Cellular Phone
How do I sync with Microsoft Outlook calendar and contacts?
Apr 14, 2009 | LG Vu CU920 Cellular Phone
Cell phone (LG KP199) to PC (Win XP) USB data transfer problem
When you connect your phone to the PC, it shows two options for connecting: Mass Storage and Cell phone. Select mass storage.
For connecting in Cell phone mode you need to have the PC Suite for this model which as on date is not available.
You can use any third party softwares like mobimb, Mobtime Cellphone manager etc. for connecting to PC.
Dec 30, 2008 | LG KP200 Cellular Phone
LG KP500 not synching with computer
the only way I can get this to work is to treat the memory card as a storage device (like a memory stick) On the phone go to settings, connectivity, usb connection then select mass storage.then transfer the MP3 files using copy and paste in My Computer You can then create playlists or use the music player as normal.
Dec 28, 2008 | LG KU990 Viewty
I can't Syncronize my Vista laptop to open LG Mobile sync
may be it does not support vista
the software needs to be updated
Sep 06, 2008 | LG Shine KE970 Cellular Phone
Can not connect using LG Mobile Sync
Hi all,
I went through the same trouble. After a small investigation I've found that the USB driver wasn't install. I just ran the setup and it worked imediatly C:\Program Files\LGE GSM PC Sync\USB Setup\LGUSBModemDriver_ML_WHQL_Ver_4.6.exe
Hope it could help!
Feb 03, 2008 | LG Shine KE970 Cellular Phone
Sync Manager Problme with Vista with LG CU500
The problem is a driver issue. It is strictly a LG/Verizon problem, and not Windows. What you should is hook up your phone your computer LG USB cable and using the Music Essentials CD-ROM.
Install the latest version of BitPim where  you can find at .
"I hooked up my phone to my computer via the USB cable, and opened BitPim. Much to my dismay, bitpim did not find the COM for the LG Modem".
However, Vista popped up the window in the taskbar telling me that new hardware was detected but could not be installed. I went to Start > Search > Device Manager
Once the Device Manager is opened up, you should see an unknown hardware profile for the USB cable/phone. In my case, Vista seemed to recognize the fact that it was a LG USB Modem, but didn't have the driver. Anyway, right click on the unknown driver and select "update driver software." Surprisingly, Vista will tell you it found a driver. Unfortunately, when when you go to install the driver 2 new unknown drivers will appear.
To fix the 2 unknown drivers, all you have to do is insert the VCAST Music Essentials disk into your disk drive, and point Windows in the direction of the files for the drivers on the VCast Music Essentials CD (in my case, the D: drive).
Windows finished the install, and from their BitPim recognized the cable on COM5.
That should work.
Jan 22, 2008 | Cell Phones
How can I get my Vista laptop to open LG Mobile Sync Ver 1.0?
lg k500e is not compatible with vista as most things at the moment unfortunatly
Dec 11, 2007 | LG Prada KE850 Cellular Phone
I have the same problem like everyone else in this forum! here is the solution:
1. The USB modem driver came with the CD may or will not work, so get the latest drivers for it.
2. Before install the new drivers, change your phone setting under " setting -> USB connection -> from MASS STORAGE to DATA LINK.
3. Plug the usb cable to the phone and to your PC, it should do anything or give any message if it does just cancel it for now.
4. Install the new USB driver you just download, while install it will said something like " does not work with XP " just click OK don't panic.
5. After it finished installed you will see by the clock that it find the USB LG blah blah...and ding ding sound if you have sound on.
6. Now go back to LG Sync software and click on Connect & choose LG modem com port whatever it there.
7. You're done !!!
Here the link where to get the new USB driver:
Yeah the link is all Italian ...don't panic, I couldn't read it either LOL...just click on the picture where you see the phone and the PC with wrap around with arrow, then follow instruction will be in English.
Good Luck!
Keep posting good answer that you find and help out other just like US!
Sep 20, 2007 | LG Prada KE850 Cellular Phone
LG KG800 Cellular Phone Logo
100 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
